panamared5(at)brier.net Guest
Posted: Wed Oct 15, 2008 3:52 am Post subject: Fuel in the Oil |
I just got my oil analysis back and I was told that I have 2.3 % fuel in the
oil and the value should be less than 1%.
I have an IO 360 A1A, and I mostly use unleaded auto fuel. Blackstone labs
thinks I should check the injectors on the engine and any other source of
fuel.
Any ideas on what to check for, and what might be causing the problem?
Bob
RV6 "Wicked Witch of the West"
n801bh(at)netzero.com Guest
Posted: Wed Oct 15, 2008 5:25 am Post subject: Fuel in the Oil |
If you are running a mechanical fuel pump there might be a slight leak internally past the diaphram. I have seen that happen before several times, if not it has to be in the injector area somewhere. To have that much fuel get past the rings and into the oil would be a long shot for sure. Keep us posted and how this turns out.
tailwinds and do not archive
Ben Haas
N801BH
www.haaspowerair.com
-- "Panama Red" <panamared5(at)brier.net> wrote:
--> RV-List message posted by: "Panama Red" <panamared5(at)brier.net>
fuel.
Bob
RV6 "Wicked ========================================================================================================================  sp; -Matt Dralle, List Ad=====================================
[url=_blank]Click here for free information on nursing degrees, up to $150/hour[/url]
sportav8r(at)gmail.com Guest
Posted: Wed Oct 15, 2008 6:03 am Post subject: Fuel in the Oil |
I'm having to look harder and harder to find un-ethanol-ed unleaded auto gas around here, Bob. Just dumped 15 gallons out of the plane that the wife bought for me at the deep discount Kroger station, because I saw signs on the pump later that week that said may contain 10% ethanol. Did the water test, and sure enough- positive for corn squeezin's. Not until after I dumped the first jerry can from the wing tanks into my pickup truck tank did I think about the residual 100 LL that was mixed in there from a September cross-country. I hope I have not ruined my cat converter; I have another dozen gallons of premium gasohol / 100 LL mix that I can only burn in the motorcycles and lawnmowers ;-(
Be careful about the ethanol - it's making inroads in our region, and it's time for the high vapor pressure winter mix to hit the market, too.
-Bill B
On Tue, Oct 14, 2008 at 8:22 PM, Panama Red <panamared5(at)brier.net (panamared5(at)brier.net)> wrote:
[quote]--> RV-List message posted by: "Panama Red" <panamared5(at)brier.net (panamared5(at)brier.net)>
I just got my oil analysis back and I was told that I have 2.3 % fuel in the oil and the value should be less than 1%.
I have an IO 360 A1A, and I mostly use unleaded auto fuel. Blackstone labs thinks I should check the injectors on the engine and any other source of fuel.
Bob
chaskuss(at)yahoo.com Guest
Posted: Wed Oct 15, 2008 10:05 am Post subject: Fuel in the Oil |
Bill,
While the lead will coat the catalytic converter and the oxygen sensors, it's affect will be only temporary. Once you put pure unleaded back into the car, the lead will burn off of the cat and the oxygen sensor.
Charlie Kuss
--- On Wed, 10/15/08, Bill Boyd <sportav8r(at)gmail.com> wrote:
| Quote: | From: Bill Boyd <sportav8r(at)gmail.com>
Subject: Re: Fuel in the Oil
To: rv-list(at)matronics.com
Date: Wednesday, October 15, 2008, 10:02 AM
that the wife
I saw signs on
Did the water
Not until after I
from a September
I have another
only burn in the
market, too.
-Bill B
have 2.3 % fuel in
any other source of
> fuel.
> Thanks
> Bob
