nuckollsr(at)cox.net Guest
Posted: Thu Mar 09, 2006 6:57 am Post subject: Marketing research question Annunciated Parameters List |
Just for grins, I'll toss the question out to the list.
From of the list items below, what additional or alternative
points of interest might be important enough to light a light
and/or blow in your ear?
The wish list now stands at:
Main Volts Lo
Aux Volts Lo
Left Fuel Lo
Right Fuel Lo
Oil Pres Lo
Canopy Latch
OAT Warn
Pitot Heat
Coolant Temp
Coolant Pres
Coolant Low
Oil Temp
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
mark.steitle(at)austin.ut Guest
Posted: Thu Mar 09, 2006 9:33 am Post subject: Marketing research question Annunciated Parameters List |
This seems a good time to bring this up. My Chevy p/u has a cool little
"message center" that tells me that its time to change oil, or that the
cargo light is on, etc. It is about 1.5" square. I was wondering if it
would be possible to adapt this to experimental a/c use as a compact
annunciator? I don't have a clue as to how it works, but I thought that
it may be possible to get one from GM, or out of a wreck, and then
program a PIC to provide customized alerts for various things of
interest. It appears to use some sort of LED panel with yellow
lettering. So, does this sound plausible? Has anyone on the list done
this? Am I nuts?
Mark S.
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Thu Mar 09, 2006 9:48 am Post subject: Marketing research question Annunciated Parameters List |
How about a simple "Master ON" reminder?
Bret
_________________ Bret Smith
RV-9A (Emp) |
khorton01(at)rogers.com Guest
Posted: Thu Mar 09, 2006 1:05 pm Post subject: Marketing research question Annunciated Parameters List |
Fuel Pres Lo
Engine (output from an engine monitor, to tell you to look at it to
see what problem it has found).
Kevin Horton
On 9 Mar 2006, at 09:56, Robert L. Nuckolls, III wrote:
<nuckollsr(at)cox.net>
Main Volts Lo
Aux Volts Lo
Left Fuel Lo
Right Fuel Lo
Oil Pres Lo
Canopy Latch
OAT Warn
Pitot Heat
Coolant Temp
Coolant Pres
Coolant Low
Oil Temp
schamber(at)glasgow-ky.co Guest
Posted: Thu Mar 09, 2006 5:21 pm Post subject: Marketing research question Annunciated Parameters List |
gear
Jerry Cochran
Joined: 10 Jan 2006 Posts: 111 Location: Wilsonville, OR
Posted: Fri Mar 10, 2006 12:20 pm Post subject: Marketing research question Annunciated Parameters List |
I would love to have fuel pressure.
Jerry
Subject: RE: Marketing research question Annunciated
Parameters List
| Quote: | From of the list items below, what additional or alternative
Main Volts Lo
Aux Volts Lo
Left Fuel Lo
Right Fuel Lo
Oil Pres Lo
Canopy Latch
OAT Warn
Pitot Heat
Coolant Temp
Coolant Pres
Coolant Low
Oil Temp
highflight1(at)gmail.com Guest
