Rear Heat Duct (Scat Tube) - SOLUTION
Goto page Previous  1, 2
partner14
PostPosted: Mon Oct 13, 2008 9:34 pm    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
You are a riot!!!!!!!!!!!!!!!!!! Drop by some time and I'll take you through the shop. They have about 3 times the equipment Van's has. Just fly into Mather.... the ole AFB.
--- On Mon, 10/13/08, Rick Sked <ricksked(at)embarqmail.com> wrote:
[quote]From: Rick Sked <ricksked(at)embarqmail.com>
Subject: Re: Re: Rear Heat Duct (Scat Tube) - SOLUTION
Date: Monday, October 13, 2008, 7:18 PM
[quote]--> RV10-List message posted by: Rick Sked <ricksked(at)embarqmail.com> Ummm... yeah...how much do those 12 year old welders get an hour? do not archive ---
Don A. McDonald
40636
msausen
PostPosted: Tue Oct 14, 2008 2:53 am    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
BTW if anyone is interested in what you can do with the Andair valve and extension, here is a picture. I just set the scat tube in to take a picture but you can see that it clears the valve no problem. I secured the faceplate and valve handle with extension to the tunnel cover. When it's in place and screwed down the tunnel cover will not let the extension disengage from the valve.
Michael
 Filesize:  76.27 KB
 Viewed:  214 Time(s)
 Filesize:  50.91 KB
 Viewed:  213 Time(s)
 Filesize:  48.55 KB
 Viewed:  222 Time(s)
johngoodman
PostPosted: Tue Oct 14, 2008 6:05 am    Post subject: Re: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
Don,
I definitely want one. I'll send my mailing address in an e-mail. As far as the other issues brought up I'm a little puzzled. For instance, I noticed a disparaging remark about Van's supplied fuel valve. Is there something wrong with it? Does it leak or something? Is it missing a selection option? I suspect that it's simply "not pretty." In which case, a new handle ought to solve the problem for most of us.
The fuel heating issue that Tim brought up got my attention. I could see a small amount of heat transfer at the current location of the scat tube, but the fuel is only exposed for a second or two at the valve. To me the fuel filter, fuel pump, and flowscan attached directly to the belly skin would be far more significant. I'm assuming that the tunnel heat issue has never really gone away.
The advantage of your device is that twice as much air flow is allowed around the fuel valve - unless somebody has perfected a way to squash the scat tube on both sides of the valve stem. Because of the increased flow, the folks in the back would probably want it on a shorter period of time.
John
dlm46007(at)cox.net
PostPosted: Tue Oct 14, 2008 7:26 am    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
IIRC the vans valve does not lock in a given position; no positive detent
for left or right or off. It could be nudged and inadvertently to off or to
some intermediate position in flight?
msausen
PostPosted: Tue Oct 14, 2008 9:20 am    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
I've also heard that in the past they have leaked over time. I believe some people were replacing the seals in it proactively with better ones.
Michael
Tim Olson
PostPosted: Tue Oct 14, 2008 10:11 am    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
I don't think I've ever heard of them leaking over time on the
RV-10's, but I know that if you put tons of interior covering
on your doors they may not hold up the door. (this is true)
To save mine from being compressed all the time, I had a
special canopy cover made that allows me to park it with
the doors open and have the plane covered. (tongue in cheek,
beware, this is actually NOT true, for those who haven't
figured that out)
RV Builder (Michael Sausen) wrote:
<rvbuilder(at)sausen.net>
better ones.
Michael
jesse(at)saintaviation.co
PostPosted: Tue Oct 14, 2008 10:34 am    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
I have seen some of these weaker than others, but I don't think it is
a leak. Van's has been pretty good about replacing them if/when they
fall short of the mark.
All that said, I don't think I've had a problem in a while, so they
may have changed sources.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
figured that out)
> better ones.
> Michael
planesmith(at)hotmail.com
PostPosted: Tue Oct 14, 2008 12:00 pm    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
Too Cool!
Is the canopy cover available with zip-in screen doors? It would be great for those hot days at air shows:)
Vern Smith (#324 finishing)
> Date: Tue C 14 Oct 2008 13:10:29 -0500
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>
To save mine from being compressed all the time C I had a
the doors open and have the plane covered. (tongue in cheek C
beware C this is actually NOT true C for those who haven't
figured that out)
See how Windows connects the people C information C and fun that are part of your life. See Now [quote][b]
PostPosted: Tue Oct 14, 2008 5:41 pm    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
John,
The disparaging remark came from me...and about half of the flying RV's out there. You can search Vansairforce list and read about the shortcomings or the lack of them. Seems the valve has a Dr. Jekyll and Mr. Hyde reputation. It either outlasts the the airframe or it leaks in 30 to 40 hours. I mean really, look at that valve. I wouldn't trust it on my icemaker, which did $20k in water damage to my house at one time. The Andair is my choice and you decide for yourself what you want controlling the fuel. If you have had the chance to examine both there would be no question which you would choose. But then again....some guys love the (cough, gag) Vans valve, including Van, but you need to consider the Dutch factor there, you know, if it leaks I still have 5000 of them in the warehouse and we recommend them all the way up till they are all sold! Smile
Rick Sked
40185
johngoodman
PostPosted: Wed Oct 15, 2008 7:28 am    Post subject: Re: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
Rick,
I have started doing my homework on it right now. I've gone to our local RV hangar and took a good look at the Andairs that were there, still in the box and some installed. I definitely think the Andair is an excellent looking valve and has a very nice feel to it. I was also told by one of experienced builders that the Vans valve has been known to stick at one tank position, or the other. The leak issue is also mentioned. A quick browse through the VAF forums reveals that the standard brass/nylon valve can wear to create the above situations but it is not common. Most folks believe the valve is extremely reliable - albeit ugly.
So now I have a dilemma. IF I switch over, it looks like I would have to re-plumb my fuel lines. I'm also guessing that it would mount differently than the Van's valve requiring removal of the old bracket and fabrication of a new one. It appears the scat tube issue that I was hoping to solve with Don's device is still there, so would Don's device work? The extension on the Andair looks like a solution but it's an additional layer of complexity and would cost more to buy than the replacement cost of Van's valve.
If only Van had found a better way to get the scat tube to the back seats, I would still be in ignorant bliss......
John
ricksked(at)embarqmail.co wrote:
John,
Rick Sked
40185
Sad
PostPosted: Wed Oct 15, 2008 11:22 am    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
John,
For sure you will need to modify your install if you already plumbed for the weathervane. I only intalled the mount before electing to use the Andair. My install was pretty simple using the braided stainless lines instead of the hard aluminum. This allowed me to route the lines to one side of the tunnel and the scat along the other but it still needed to flatten it a little a little. My valve stands up in the tunnel withthe assistance of the aluminum line that goes to the fuel pump. The valve is secured when the figerglass console is installed and the mounting screws for the valve go through the plate and console and into the nutplates on the valve. very secure and stable mount using the glass console. It's about 1/4" thick at the point where the valve mounts.
Rick Sked
40185
jump2(at)sbcglobal.net
PostPosted: Wed Oct 15, 2008 11:59 am    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
Hey Rick here is the solution one of our local RV10 builder has. Don't install a back Heat outlet.
Patrick Thyssen
PS: It's a cheap fix
Date: Wednesday, October 15, 2008, 2:21 PM
[quote]--> RV10-List message posted by: Rick Sked <ricksked(at)embarqmail.com> John, For sure you will need to modify your install if you already plumbed for the weathervane. I only intalled the mount before electing to use the Andair. My install was pretty simple using the braided stainless lines instead of the hard aluminum. This allowed me to route the lines to one side of the tunnel and the scat along the other but it still needed to flatten it a little a little. My valve stands up in the tunnel withthe assistance of the aluminum line that goes to the fuel pump. The valve is secured when the figerglass console is installed and the mounting screws for the valve go through the plate and console and into the nutplates on the valve. very secure and stable mount using the glass console. It's about 1/4" thick at the point where the valve mounts. Rick Sked 40185 ---
PostPosted: Wed Oct 15, 2008 12:25 pm    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
Yeah but it get so chilly here in Las Vegas...I really don't plan much back seat pass. So I did give that some consideration...Tim on the other hand has his girls and it is REALLY cold in his part of the country.
Tim Olson
PostPosted: Wed Oct 15, 2008 12:45 pm    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
Smile Yeah, we use it all the time. On the way to Philly we had
it on this last week. I actually like using the rear heat
more often than the front. It allows them to be warm,
and you to get warmth without that direct leg-heat that
tends to put me to sleep. It also keeps the heat from
blowing up under the panel. I remember back to my flyoff
time, flying along at 10F, but I could see that the internal
temp of my GRT EIS was like 110F, and that box doesn't get
that warm on it's own. The head from the inlet was rising
up to the panel.
On a continued topic, I would really recommend that everyone
put in defroster fans on their RV-10's, regardless of their
climate. Even if you don't need defrost, it will help keep
the hot air from collecting under your forward fuselage
behind the panel.
Rick Sked wrote:
[quote] Yeah but it get so chilly here in Las Vegas...I really don't plan much
Page 2 of 2
