Factory tested ??
Iberplanes
PostPosted: Mon Oct 13, 2008 8:11 am    Post subject: Factory tested ?? Reply with quote
Hello gang,
do we know for sure if our jabirus are factory tested? I´ve removed one spark plug per cylinder in order to spray it with oil to keep it OK for my long term storage and i´ve founded dirty as if the were used. Anyone with the same case here?
many thanks ,
Alberto Martin
www.iberplanes.es
Igualada - Barcelona - Spain
Zodiac 601 XL Builder
Serial: 6-7011
Tail Kit: Finished
Wings: Not Started
Fuselage: Ordered
Engine: Jabiru 3300
Alberto Martin
601 XL - Jabiru 3300
http://www.iberplanes.es
challgren(at)mac.com
PostPosted: Mon Oct 13, 2008 8:40 am    Post subject: Factory tested ?? Reply with quote
Yes, they are tested at the factory. There should have been a tag on the engine indicating that.
Stan
On Oct 13, 2008, at 10:11 , Iberplanes IGL wrote:
[quote]Hello gang,
many thanks ,
Alberto Martin
www.iberplanes.es
JohnDRead(at)aol.com
PostPosted: Mon Oct 13, 2008 8:56 am    Post subject: Factory tested ?? Reply with quote
Mine came with a red tag indicating it had been run and was drained of oil. I also got a test run chart.
John Read
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 10/13/2008 10:12:29 A.M. Mountain Daylight Time, iberplanes(at)gmail.com writes:
Hello gang,
many thanks ,
Alberto Martin
www.iberplanes.es
Serial: 6-7011
Tail Kit: Finished
Wings: Not Started
Fuselage: Ordered
Engine: Jabiru 3300
st href="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
New MapQuest Local shows what's happening at your destination. Dining, Movies, Events, News & more. Try it out!
Iberplanes
PostPosted: Mon Oct 13, 2008 10:46 am    Post subject: Factory tested ?? Reply with quote
Ok, thanks for your answers. I believe the tag is under the engine, right? I have opened it the other way around so the cylinders are on the top and the plugs easily removed if I need to. I´ll check if I can get the tag.
THANKS!!!
Alberto Martin
www.iberplanes.es
Serial: 6-7011
Tail Kit: Finished
Wings: Not Started
Fuselage: Ordered
Engine: Jabiru 3300
Alberto Martin
Jim McCormick
PostPosted: Tue Oct 14, 2008 9:37 am    Post subject: Factory tested ?? Reply with quote
Well Since the engines are run in for an hour and then treated with storage oil, you will see a “dirty” spark plug when you remove them before you start the engine for the first time.
So if the engine wasn't run at the factory your plugs would look brand new.
Jim McCormick
On 10/13/08 9:11 AM, "Iberplanes IGL" <[url=iberplanes(at)gmail.com]iberplanes(at)gmail.com[/url]> wrote:
[quote]Hello gang,
many thanks ,
Iberplanes
PostPosted: Tue Oct 14, 2008 9:57 am    Post subject: Factory tested ?? Reply with quote
Alberto Martin
imap8ntr(at)cox.net
PostPosted: Tue Oct 14, 2008 1:16 pm    Post subject: Factory tested ?? Reply with quote
Jim,
I got a question about setting up a prop for the 3300A engine with the economy tuning kit installed. As I see it all one has to do is assure that the ground run RPM at full throttle is over 2800 RPM and that the inflight RPM full throttle straight and level doesnt go above 3150-3300. If these specs are followed we can be assured that we are running full rich/full power upon takeoff and lean in cruise. Does this sound right to you?
Ivan
DaveG601XL
PostPosted: Wed Oct 15, 2008 5:28 am    Post subject: Re: Factory tested ?? Reply with quote
Ivan,
Ground static and max in-flight RPM's do not guarantee that you have the right size jets for correct mixture. Although, being way off the correct mixture will likely cause you to fall short of any RPM targets you have.
Jet sizes aside for now, your static RPM will vary greatly depending on your prop. I have the Senenich wooden W64ZK49 prop in my 601XL and it gives me a static RPM around 2650. Max level flight RPM is around 3150. Other people with the same airframe/prop/engine combination get different results due to the inherent variations.
For in-flight confirmation of mixtures, having EGT information is very helpful. The Jabiru factory documentation says that the EGT target for takeoff is 1184F and the cruise target is 1256F. If I remember, Pete from Jabiru recommends takeoff EGT's in the 1200-1250 F range and cruise EGT's in the 1350-1400F range. Depending on whether you are above or below these targets will tell you that you need to lean or richen your mixture.
The variation between cylinders will confuse the matter a bit as you may see some cylinders will be above the target and some will be below it. I have spent a good part of my phase I flight test period trying to find the 'sweet spot.'
Good luck,
David Gallagher
Cincinnati, OH area
japhillipsga(at)aol.com
PostPosted: Wed Oct 15, 2008 8:02 am    Post subject: Factory tested ?? Reply with quote
Al, I was told that the 3300 I bought was "run in" already and did not require a breakin period. Bill
imap8ntr(at)cox.net
PostPosted: Wed Oct 15, 2008 9:53 am    Post subject: Factory tested ?? Reply with quote
Dave
Thanks for the info. My carb tuning and jets should be just perfect since
they were tuned at the factory with no problem. So the only variable now is
geting the prop pitch just right again as it was before it was removed to
perform maintenance. I got my target RPM's from the SB on the "Economy
tuning."
By "sweet spot" do you mean peak EGT?
Ivan
jeromedelamare(at)free.fr
PostPosted: Wed Oct 15, 2008 10:31 am    Post subject: Factory tested ?? Reply with quote
Ivan,
Depending on the serial number of your engine, I am not so sure that the
factory tuning is "just perfect".
You should follow the service bulletin : JSB018-1 Engine Tuning
Jérôme
../My carb tuning and jets should be just perfect since
they were tuned at the factory with no problem/...
imap8ntr(at)cox.net
PostPosted: Wed Oct 15, 2008 10:35 am    Post subject: Factory tested ?? Reply with quote
I understand. My serial number engine came complete with the "economy
tuning kit" installed. This was confirmed by Pete.
thanks
Ivan
DaveG601XL
PostPosted: Wed Oct 15, 2008 10:45 am    Post subject: Re: Factory tested ?? Reply with quote
Ivan,
If you say your jets were tuned at the factory, then I guess you are flying a Jabiru airplane. (I do not know what you have) The jets that Jabiru installs onn the production line are meant to work the best for their Jabiru airframes and may, or may not, be optimum for other installations. When they built my 3300 engine, they did not know what type of airplane it would go in. As it happens, I put it in a Zodiac 601XL with a fixed pitch wooden prop. In this application, the load that the engine sees in flight is much different than on a Jabiru airframe. As Pete at Jabiru USA said up front, and I have confirmed through flight testing, the jets in my 3300 engine were too large (rich). I have had to go down one size in both the main and needle jets to get the right mixture.
As to finding the 'sweet spot,' that is too complex a discussion to just attach to this thread. The 601XL installation has all sorts of turbulent airflow into the carb which causes all sorts of variability in mixture to the individual cylinders. I am close to publishing the results of my testing in a separate post in the near future.
Good luck,
David Gallagher
Cincinnati, OH area
imap8ntr(at)cox.net
PostPosted: Wed Oct 15, 2008 10:56 am    Post subject: Factory tested ?? Reply with quote
Thanks Dave,
Sorry I did not mention that my application is an S-LSA J-250. All was set
at the factory. I had to have my prop removed so when it was placed back on
the Sensenich ground adjustable pitch is not exactly as it was before. I
put a mark on the dial before removing it but the numbers are so close that
even a bit off changes the pitch-RPM a lot. I so have RPM figures from hours
of flying so I am just trying to match those again which did just fine for
the plane as set at the factory.
Ivan
Lynn Matteson
PostPosted: Thu Oct 16, 2008 2:47 am    Post subject: Factory tested ?? Reply with quote
Maybe we should all use the method that the Matronics Kitfox List
uses......include our name, airplane model, engine model, prop size,
and status, i.e. if we are building or flying, in our signatures.
That way, all the info is there for others to see, and we don't have
to remember to include it each time we make a comment about our plane
and how it is set up.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 562 hrs, temporarily grounded; igniton parts will arrive
Friday; flight soon after.
On Oct 15, 2008, at 2:56 PM, Ivan wrote:
Thanks Dave,
Lynn
Kitfox IV-Jabiru 2200
N369LM
Iberplanes
PostPosted: Thu Oct 16, 2008 3:41 am    Post subject: Factory tested ?? Reply with quote
Well, that idea was also before on the zenith list due to all the post on accidents. Some builders blamed others and wrongly accused them as "other AC brands competitors" when a crash was posted.
In my sign, I think, you can get a nice idea about me. Anyway on the Zenith list only a few builder have done that modification
Take care,
Alberto Martin
www.iberplanes.es
Serial: 6-7011
Tail Kit: Finished
Wings: Not Started
Fuselage: Ordered
Engine: Jabiru 3300
Alberto Martin
jcrowder(at)lpbroadband.n
PostPosted: Thu Oct 16, 2008 7:36 pm    Post subject: Factory tested ?? Reply with quote
Lynn,
I think this is a great idea. I find I can't keep track of this information
and it is very useful when reading and attempting to make use of it.
Jim Crowder
Kitfox 5
Currently installing 3300a Jabiru
[quote] --
Lynn Matteson
PostPosted: Thu Oct 16, 2008 8:09 pm    Post subject: Factory tested ?? Reply with quote
Thanks, Jim...it wasn't my idea, but it seems to help people keep
track of who is flying or building what. In the Kitfox group we have
a couple of moderators who also suggest that we add the words "do
not archive" to posts that are merely non-informative in nature, like
mine here. I think that is pointed out in the Matronics rules for
posting. That way when future people who are looking up a subject
find a post of say someone who just had a first flight, they won't
find a gazillion messages saying "way to go man" or some such
messages. I usually put "do not archive" right in my signature, then
when I'm ready to send the message, I can decide whether or not my
comment, suggestion, or question is worth keeping for the ages, and
can edit out the last line (the do not archive), or decide that this
isn't worth reading in the future, and leave the "do not archive"
intact. If you or others are not aware, Matronics has a system in
place that sees the "do not archive" line anywhere in the message,
and will not put that particular message in the archives. It helps
keep the number of archived messages down to just informative stuff,
and eliminates the fodder. This group is pretty new and therefore low
in number of posts, but when it gets bigger, I think Matronics will
want it moderated too.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 568hrs
Sensenich 62x46
flying again after engine rebuild, and new Electroair direct-fire
ignition system
On Oct 16, 2008, at 11:34 PM, Jim Crowder wrote:
<jcrowder(at)lpbroadband.net>
Lynn,
information
Jim Crowder
Kitfox 5
Lynn
N369LM
