Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27016 Location: Livermore CA USA
Posted: Mon Oct 20, 2008 4:12 pm Post subject: Interior Painting - Powercoating? When? |
Fellow RV-er's,
There is a powercoating shop here in my town that has an oven large enough to put my whole RV-8 fuselage into it. I've been considering just having the whole inside powercoated for the durability, and sweet look. Lots of guys powercoat the instrument panel and obviously most of the steel parts come from Van's powercoated. But what are the upsides and downsides of powercoating all of the interior parts. I've used Variprime on most of the backsides of the interior parts, but I've left the occupant facing parts bare in prep for the powercoating. Will the powercoat chip off easily on the bend-y pieces?
And when's the right time to take it down to the powercoaters? I would like to have most things riveted that need riveting before the coating like the forward deck over the instrument panel and the aft turtledeck, but these get riveted on pretty late in the building process. I would like to have all of the wiring and controls installed or at least fabbed and trial fitted before coating to avoid scratches. But again, once things are wired, is coating going to make a mess? Its not like the harnesses can really be removed once their installed...
The other concern is the heat necessary to bake on the powercoating. I think its upwards of 450 degrees F. What impact will that temperature have on the various parts that go into the fuselage such as the aeronuts, plastic bushings, clamps, etc?
I'm in quite a dilemma over this. I really want to wait as long as possible to avoid scratches and chips in the powercoating, but I don't want to wait too long and not be able to disassemble things to the point of making a good looking job. For example, the rear floor boards should probably be riveted down, but any screwed in panels should be removed. But riveting the floorboards is something I'd probably prefer to do the day before test flying...
Thanks for any insight...
RV-8 # 82880
Trutrak Auto Pilot Servo and Aileron Electric Trim Install
_________________ Matt Dralle
rv9jim(at)juno.com Guest
Posted: Mon Oct 20, 2008 5:27 pm Post subject: Interior Painting - Powercoating? When? |
Matt,
I think the weight will be to much. I used a water based
urethane and it is tough as nails. Its a flat white and has sruvived my
build in good condition.
Jim Nelson
RV9-A
____________________________________________________________
Click here to become a professional counselor in less time than you think.
http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3oJto2G96RmFCUjVA6drwRYWWQWmapQcPlBGnBEOWZf7RpG7/
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Mon Oct 20, 2008 5:52 pm Post subject: Interior Painting - Powercoating? When? |
Matt,
I agree with Jim. I think it would be a significant weight increase to
powder coat.
Dale Ensing
RV-6A
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
sbuc(at)hiwaay.net Guest
Posted: Mon Oct 20, 2008 6:03 pm Post subject: Interior Painting - Powercoating? When? |
Dale Ensing wrote:
Matt,
powder coat.
What impact would the powder coat oven (450*?) have on the heat treating
of the aluminum alloy?
There are several good paints that work very nicely in the interior of
our planes.
Sam Buchanan
btemplin(at)templinelectr Guest
Posted: Mon Oct 20, 2008 6:42 pm Post subject: Interior Painting - Powercoating? When? |
Disturbing the heat treatment is the problem with powder coat for something like this. 43.13 4-54b says:
"Reheating of 2017 and 2024 alloys above 212 °F tend to impair the original heat treatment. Therefore, reheating above 212 °F, including the baking of primers, is not acceptable without subsequent complete and correct heat treatment."
I have a decent sized powder coating setup in my garage and I powder coat LOTS of stuff for aircraft, but I do always try to be mindful of this. I asked a good friend who is in the heat treating business if this was fact or fiction. He indicated that it could start the change the heat treatment of those alloys and he would avoid doing it.
For some little bracket or whatever it should be fine, but I don't think I'd do it on the airframe.
Brad
Dale Ensing wrote:
> Matt,
> powder coat.
our planes.
Sam Buchanan
dauscj(at)nb.net Guest
Posted: Tue Oct 21, 2008 3:01 am Post subject: Interior Painting - Powercoating? When? |
Matt,
I own/operate a powdercoating facility. There are many low E or low cure
powders on the market (300 deg. F. temp for 12 minute cure) that would help
with the heat treat issues. My biggest concern is weight. I would guess
15-25 lbs. With the lower cure temp I don't think distortion or artificially
aging (heat treat) would be a big concern (the aluminum will age by itself
over time any way). Some other concerns are the thickness; if you have any
parts that fit together I am sure they will not. You could have the coater
mask off these areas or have them give you some high temp. tape and you do
it your self. Make sure the coater properly pretreats (degrease and etch and
dry) your fuselage before applying the powder. Lastly, if for some reason
your aircraft ever gets real hot the powder will burn and the fumes that
powder gives off are very unpleasant. Oh, one more thing, powder hides
cracks very well.
Just a few things to consider,
Chuck
RV6A FWF
chaskuss(at)yahoo.com Guest
Posted: Tue Oct 21, 2008 6:58 am Post subject: Interior Painting - Powercoating? When? |
Matt,
The big issue with powder coating or paint is the quality of the prep work. If the shop doesn't do great prep work, you will have a real mess on your hands.
Charlie Kuss
--- On Mon, 10/20/08, Matt Dralle <dralle(at)matronics.com> wrote:
| Quote: | From: Matt Dralle <dralle(at)matronics.com>
Subject: Interior Painting - Powercoating? When?
To: rv-list(at)matronics.com, rv8-list(at)matronics.com
Date: Monday, October 20, 2008, 8:11 PM
Fellow RV-er's,
clamps, etc?
RV-8 # 82880
AV8ORJWC
Posted: Tue Oct 21, 2008 8:57 am Post subject: Interior Painting - Powercoating? When? |
Chuck closed with the most important point. Powdercoat makes the
inspection of welds and crack propagation a real BEAR. Consider that
when Pro/Con (weighing) the durability to environmentals and increased
gross weight. Sure looks pretty though.
John Cox
IA
Posted: Tue Oct 21, 2008 1:20 pm Post subject: Interior Painting - Powercoating? When? |
Thanks for all the great feedback on powercoating the interior! I think I'm going to skip powercoating the interior based on everyone's feedback.
I had a conversation with my local body shop guy who I've know for nearly 20 years. He was very willing to take on the project and basically said that we could work out an arrangement where I could do most of the supervised prep work in his shop and then he would simply supply the paint and the skill in applying it. Sounds like a good deal to me. He has a really nice, large sealed paint booth that the -8 will fit right into. He has completely repainted two cars for me in the past and his skill is superb. He was saying that he recently painted a guys Rotoway helecopter.
Still, the "when" is a question mark. I want to delay as long as possible, but I don't want to wait too long and have to completely disassemble everything or worse yet *wish* that I could disassemble things for paint.
RV-8 #82880
At 05:11 PM 10/20/2008 Monday, you wrote:
Fellow RV-er's,
RV-8 # 82880
Posted: Tue Oct 21, 2008 1:46 pm Post subject: Interior Painting - Powercoating? When? |
Matt Dralle wrote:
| Quote: | Still, the "when" is a question mark. I want to delay as long as possible, but I don't want to wait too long and have to completely disassemble everything or worse yet *wish* that I could disassemble things for paint.
I think everyone wrestles with this one! When I painted my Pitts, I did
it before it was assembled ..... much easier to handle the 'smaller'
pieces in the paint booth. I'll probably paint the -10 the same way.
My shop is at home and the airport about a mile away, and I've pondered
getting the Sheriff to lead me as I taxi down the road .... or after a
part is painted, move that part to the airport for assembly. I have
friends that still have their plane painted in primer years after they
started flying ..... you hate to take a flying pland apart for paint,
and painting it assembled means some places won't get paint .... and
primer without paint MAY allow corrosion. So, at this point I'll have
everything in base coat color when it's assembled to fly .... and it may
have the trim at that point also.
Linn
| Quote: | Matt Dralle
RV-8 #82880
pbesing(at)yahoo.com Guest
Posted: Wed Oct 22, 2008 6:52 am Post subject: Interior Painting - Powercoating? When? |
As far as painting the interior I would wait as long as possible. I found that I was in and out of the aircraft, tools, screws, etc can really scratch up an interior quick. You can mask the panel and wiring, etc...just be sure you have all of your interior mods, drilling, etc done. I've been doing some mods to my RV-4 and will repaint the interior soon, but I'm waiting as long as possible until I get everything done.
Paul Besing
RV-4 N73DD
Arizona
winkels(at)charter.net Guest
Posted: Wed Oct 22, 2008 5:58 pm Post subject: Interior Painting - Powercoating? When? |
Matt, I have had several steel and aluminum parts powder coated on my RV-7,
and I asked my powder coater about the limitations of powder coating. He
said he would be very hesitant to powder coat anything thinner than about
.063" aluminum because the heat can cause deformation, especially in larger
parts. I am no expert, but I don't think it would be advisable to place your
assembled fuselage into a 400 degree oven!!! I certainly wouldn't do it.
Also, powder coating can add considerably more weight than priming/painting.
By the way, I had my assembled brake pedals powder coated with excellent
results. My instrument panel will also get powder coated (before the
instruments are installed, of course . Other than the slider canopy latch
hook, that's about the extent of aluminum parts I'll powder coat. Of the
steel parts powder coated, I've done the tailwheel spring and fork assembly,
slider canopy frame and roll bar, and canopy latch handle, but that's about
it.
Hope this helps,
Paul
