bughntr(at)comcast.net Guest
Posted: Thu Oct 23, 2008 3:08 pm Post subject: Flaperon End Caps |
I need to replace the end seals/caps on the flaperons on my model II and was looking for any good ideas for material, techniques etc. Have seen wood and/or foam used but was looking for the best ideas.
Bryan Q
Model II
Sbennett3(at)aol.com Guest
Posted: Thu Oct 23, 2008 3:41 pm Post subject: Flaperon End Caps |
Bryan, Try Murle Williams.www.MurleWilliamsAviation.com
In a message dated 10/23/2008 7:09:27 P.M. Eastern Daylight Time, bughntr(at)comcast.net writes:
| Quote: | I need to replace the end seals/caps on the flaperons on my model II and was looking for any good ideas for material, techniques etc. Have seen wood and/or foam used but was looking for the best ideas.
Bryan Q
Model II
f="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronics.com/Navigator?Kitfox-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Play online games for FREE at Games.com! All of your favorites, no registration required and great graphics – [url=http://pr.atwola.com/promoclk/100000075x1211202682x1200689022/aol?redir= http://www.games.com?ncid=emlcntusgame00000001] check it out![/url]
akflyer
Posted: Thu Oct 23, 2008 4:26 pm Post subject: Re: Flaperon End Caps |
We just had to do it a couple weeks ago. A quick trip to the local hobby or craft store and you should be able to pick up some balsa wood blocks. We roughed em in with a band saw, then rounded them out on a belt sander. A quick go around with 220 grit and a hand block sander, seal with epoxy primer, another quick sanding and then top coat to match the plane. We glued them in with T88 or use structural adhesive.
Looks like new and will outlast the foam with only maybe an once weight penalty..
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
mikeperkins
Posted: Fri Oct 24, 2008 5:32 am Post subject: Flaperon End Caps |
I used basswood on my flaperon endcaps. It’s a little harder and more durable than balsawood, but still very easy to sand and shape.
- Mike Perkins
henrysfork1(at)msn.com Guest
Posted: Fri Oct 24, 2008 5:43 am Post subject: Flaperon End Caps |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I used fur and it worked just also.
Dee Young
Model II
n10pg(at)neo.rr.com Guest
Posted: Fri Oct 24, 2008 6:11 am Post subject: Flaperon End Caps |
Did you dye the fur to match the paint?
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Dee Young
Sent: Friday, 24 October, 2008 09:43
Subject: Re: Flaperon End Caps
Dee Young
Model II
Posted: Fri Oct 24, 2008 6:36 am Post subject: Flaperon End Caps |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Pete sorry for the poor spelling and missed words. Some have better educations than others and that short coming shows in my writing skills. I will try to do better in the future.
Dee Young
Model II
N345DY
Michael Logan
Posted: Fri Oct 24, 2008 12:57 pm Post subject: Flaperon End Caps |
Thanks Peter and Dee, we got a good laugh out of that one.
Sent: Friday, October 24, 2008 10:37 AM
Dee Young
Model II
N345DY
_________________ Mike Logan
Fredericksburg, VA |
Float Flyr
Posted: Fri Oct 24, 2008 2:21 pm Post subject: Flaperon End Caps |
I knew the “fur” was a typo but I haven’t been able to think of what yow actually meant.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Michael Logan
Sent: Friday, October 24, 2008 6:28 PM
Subject: RE: Flaperon End Caps
Dee Young
Model II
N345DY
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
planecrazy2020(at)gmail.c Guest
Posted: Fri Oct 24, 2008 2:45 pm Post subject: Flaperon End Caps |
"Douglas Fir"
David
Kitfox, Model III, HKS
On Fri, Oct 24, 2008 at 5:21 PM, Noel Loveys <noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)> wrote:
I knew the "fur" was a typo but I haven't been able to think of what yow actually meant.
Noel
From: owner-kitfox-list-server(at)matronics.com (owner-kitfox-list-server(at)matronics.com) [mailto:owner-kitfox-list-server(at)matronics.com (owner-kitfox-list-server(at)matronics.com)] On Behalf Of Michael Logan
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
From: owner-kitfox-list-server(at)matronics.com (owner-kitfox-list-server(at)matronics.com) [mailto:owner-kitfox-list-server(at)matronics.com (owner-kitfox-list-server(at)matronics.com)] On Behalf Of Dee Young
Dee Young
Model II
N345DY
brubakermal(at)yahoo.com Guest
Posted: Fri Oct 24, 2008 2:47 pm Post subject: Flaperon End Caps |
while my mod 2 has fiberglass over foam the gas drains under the wing only need too leek one time and you run the risk on needing to replace them
--- On Thu, 10/23/08, Bryan Quinton <bughntr(at)comcast.net> wrote:
[quote]From: Bryan Quinton <bughntr(at)comcast.net>
Subject: Flaperon End Caps
Date: Thursday, October 23, 2008, 11:10 PM
Bryan Q
Model II
lcfitt(at)sbcglobal.net Guest
Posted: Fri Oct 24, 2008 4:05 pm Post subject: Flaperon End Caps |
Bryan,
Since the list is so lethargic of late, I thought I might offer a long
winded suggestion. If you are comfortable with fiberglass, this is a trick
I learned while working on the neighbor's Lancair IV.
Cover the inside end of the flaperon (for about an inch) with vinyl tape.
This will likely be the hardest part. Electricians tape does fine. Extend
the tape out a bit. you might want to put some tape on the outside edge as
well to protect the outside suface.
Take a couple of pieces of fiberglass cloth of appropriate size and lay them
on a piece of about 2 mil vinyl film about six inches larger than the
fiberglass cloth on all sides. Pour enough epoxy or polyester resin on it
to fully saturate the cloth. Put another piece of vinyl film on top of the
sandwich and with a squeegee or a flat piece of wood, or a roller, squeegee
as much of the resin out of the cloth as possible. Cut around the
fiberglass to get rid of the excess resin. Wearing gloves, remove the top
layer of vinyl and position the cloth over the end of the flaperon. Remove
the other piece of vinyl film and gently press the cloth into the end of the
flaperon to create a rounded concave shape. You may have to cut some of the
excess cloth away to prevent sag, unless you can work with the flaperon
vertically from a ladder or the back stairs. When this cures, press inward
on the edges, breaking the composite from the tape in the flaperon and
remove. When out, trim to the edge impression of the flaperon and you have
the end piece for the opposite flaperon.
Do the same thing on the other flaperon for the end piece for the first
flaperon. This will give a nice rounded end and it will be very light, but
will need some surface finishing with super fill, bondo or resin and
microballoons. Glue the ends in with epoxy.
This technique works also if a clearance bubble is needed, in a cowl for
instance. Just cut the clearance hole and place the fiberglass sandwich
over the hole from the inside and shape by hand. More than two layers would
be needed on the cowl, though. In this case, prep the inside with sandpaper
to remove surface contamination and allow the bubble to bond to the cowl.
The excess is sanded away with a Dremel and a sandpaper drum and faired in
on the outside with micro. For cutting the flaperon end, a Dremel using a
thin diamond disk does the trick very nicely. In the two and a half years
we spent on the Lancair, we used up three Dremels and lots of diamond disks.
Lowell
Float Flyr
Posted: Fri Oct 24, 2008 6:26 pm Post subject: Flaperon End Caps |
Thanks and I’ll try to spell “you” right the next time.
I guess it comes from living in a country with mostly spruce and birch trees.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of David Jones
Sent: Friday, October 24, 2008 8:14 PM
"Douglas Fir"
David
Noel
Dee Young
Model II
N345DY
23456789 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 0 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 1
| Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 2 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 3 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 4
| Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 5 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 6 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 7 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 8 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 9 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/c | 0 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/c | 1 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/c | 2 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/c | 3 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/c | 4 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/c | 5 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/c | 6 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/c | 7 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/c | 8 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/c | 901234
Kitfox III-A
paul(at)eucleides.com Guest
Posted: Fri Oct 24, 2008 10:33 pm Post subject: Flaperon End Caps |
On Fri, October 24, 2008 6:43 am, Dee Young wrote:
| Quote: | I used fur and it worked just also.
Dee Young
Model II
You've got to be kidding! Fur? I just can't quite visualize that.
Paul A. Franz, P.E.
PAF Consulting Engineers
Office 425.440.9505
Cell 425.241.1618
propellerdesign(at)tele2. Guest
Posted: Fri Oct 24, 2008 11:08 pm Post subject: Flaperon End Caps |
I can,
fur, fura, furu (Pinus sylvestris) scandinavian name
Jan
