		Lew Gallagher
				 Posted: Fri Oct 24, 2008 5:37 am    Post subject: Filling seatbelt countersink in canopy? |
				OK, I've spent way too much time searching for this answer.  What do you think of glassing over the heads of the seatbelt countersunk screws in the canopy?  Are others making this permanent?  Will it crack over time?  Just seal the screw and paint the screw head?
 Later, - Lew
  _________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
		AirMike
				 Posted: Fri Oct 24, 2008 6:41 pm    Post subject: Filling seatbelt countersink in canopy? |
				Don't give it a second thought. Just glass it, epoxy, or cover it up. Just keep in mind that you will need to put your headliner in and it might be easier to perforate it when you install the headliner and just punch the two bolts thru.
  _________________ See you OSH '18
Q/B - sold. |
		Tim Olson
				 Posted: Fri Oct 24, 2008 7:06 pm    Post subject: Filling seatbelt countersink in canopy? |
				I don't know, but I found usefulness in removing my seat belts
 about 1.5 years after I started flying, to do some additional
 bracket making for some lights.  I'd hate to think of what
 those screws would do if glassed in and you ever had to try to
 remove them.  They don't look that bad on the outside, do they?
 I never thought so.
 AirMike wrote:
  OSH '08 or Bust (busted) be there in "09
  Q/B Kit - wiring and FWF
  http://forums.matronics.com/viewtopic.php?p 10190#210190
		dlm46007(at)cox.net Guest
				 Posted: Fri Oct 24, 2008 7:51 pm    Post subject: Filling seatbelt countersink in canopy? |
				Just be prepared to repair the canopy surface should you ever decide to
 change/repair your belt system.
				 Posted: Sat Oct 25, 2008 5:03 am    Post subject: Filling seatbelt countersink in canopy? |
				David McNeill wrote:
 I'm not there yet (but getting close) so explain in detail, if you will,
 why bonding that screw into the cabin top keeps you from unbolting the
 harness from the inside.  If it's the fact that the screw wants to turn
 ..... I think you could just take a small chisel and smack some
 'indents' around the circumference of the screw head.  Help me
 understand here.
 Linn
		Lew Gallagher
				 Posted: Sat Oct 25, 2008 5:13 am    Post subject: Re: Filling seatbelt countersink in canopy? |
				Thanks for the responses, guys.  I'm closing in on paint preparation and altho there aren't many pictures of the tops of canopies, I couldn't remember seeing a single screw head on the surface of the roof.  Now's the time to do it, if I'm going to.
 Since the nut is on the inside, I thought folks were glassing in the screw so that just a stud is in the inside -- then you could always change out belts or whatever.  Maybe burr up the edges of the flat head so that when glassed in, it wouldn't turn ... or "smack some indents" if you will!
 By the way, I'm dealing with recently diagnosed prostate cancer and I think the average age of our group indicates this may be a commonality -- so contact me off line if you want to take advantage of my research. lewgall(at)charter.net
 Later, - Lew
		Tim Olson
				 Posted: Sat Oct 25, 2008 5:35 am    Post subject: Filling seatbelt countersink in canopy? |
				I just really don't see indents holding that screw necessarily
 tightly so that it wouldn't just rip the fiberglass and crack
 all the paint if you ever turned the nut.
 I left my screw unpainted, unashamed of it being there.  But,
 you could always paint the screw the same color as the cabin
 top and it would be barely noticeable.  Or, cover it with a
 waterproof white plastic sticker and you'd just see the outline
 of the screwhead.
 Not covering it makes it a very very minor cosmetic issue.
 Covering it makes it a maintenance issue that may cause you to
 some day have to repaint the cabin top.  It's also high enough
 up that it's very hard to see when the plane is on gear.
 But enough from me on it.  Everyone can choose as they feel
 best, and then they deal with the choices later if they
 have to...it's the beauty of building it your own way....your
 choices aren't someone else's problems, and vice versa.
 Lew Gallagher wrote:
  <lewgall(at)charter.net>
  Later, - Lew
