Dale Orth
Posted: Sat Oct 25, 2008 1:28 pm Post subject: Free Wheeling Prop |
I hand propped my 912 today and it turned over like their was no compression. I tried to start the Engine and it turned over like all the plugs were missing. Five minutes later I had compression and it ran fine. What's the deal??? Does it have something to do with the slipper clutch???
Could this happen when I'm flying??? I sure could use some help here.
Dale
_________________ Dale
KitFox 7
Las Vegas, Nv
daleorth@embarqmail.com |
Posted: Sat Oct 25, 2008 1:56 pm Post subject: Free Wheeling Prop |
I'm not sure Dale but how long was it stool prior to you propping it ?
I'm thinking if it is a late model perhaps the hydraulics to the valves
had lost pressure.
Bob Harrison G-PTAG 914 Rotax.
Dick Maddux
Posted: Sun Oct 26, 2008 4:07 am Post subject: Free Wheeling Prop |
Dale,
This problem has been mentioned a few times on the Kitfox list. I remember Lowell Fitt telling me about this problem on a cross country trip. He stopped at an airport (maybe an overnight) and then on start the engine swung freely with no compression as yours did. His solution was to run Marvel Mystery oil thru the engine and it freed the valves and the problem was gone. I don't know if the problem was in the valve hydraulics or sticking valves due to avgas. I do know you are not the only one to have this problem as it has been listed on several occasions.
Dick Maddux
Kitfox 4-1200
Rotax 912UL
Pensacola,Fl
A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
ami(at)MCFADYEAN.FREESERV Guest
Posted: Sun Oct 26, 2008 5:44 am Post subject: Free Wheeling Prop |
I've only seen this once before, on an engine that had been overheated
(because of loss of cooling water; the heads had gone loose too, which is a
classic symptom of the overheating). It seemed to run OK otherwise, but blew
out all its oil a few hours later.
Duncan McF.
lgold(at)quantum-associat Guest
Posted: Sun Oct 26, 2008 10:10 pm Post subject: Free Wheeling Prop |
Hi Guys,
Are you starting the engine by hand propping it?
I'm a little confused here. I have a 3-blade Warp Drive prop on my 912 and
was told never to hand prop it because it turns way too fast and will most
assuredly lop off a few fingers.
Les
[quote] --
Dick Maddux
Posted: Mon Oct 27, 2008 3:48 am Post subject: Free Wheeling Prop |
Les,
I believe we were refering to always turning the prop thru by hand in order to check the oil quantity and to get the oil out of the case and into the oil tank prior to engine start. You could readily tell if you had normal compression or a hydraulic lock.
As you say ,you should NEVER hand prop the engine to start it.Although in my Rotax engine class the instructor Dean mentioned that he knew of two cases where it was done and it was successful. Both guys that did it said they would NEVER do it again! (a good way to loose life or limb)
Dick Maddux
Kitfox 4-1200
912UL
Pensacola,Fl
thilo.kind(at)gmx.net Guest
Posted: Mon Oct 27, 2008 1:55 pm Post subject: Free Wheeling Prop |
Hi everybody,
I have a hard time believing, that you can start a 912 by end – you will need at least 300 RPM for the ignition to fire the plugs – that’s a bit too much for hand propping.
Thilo Kind
Zodiac CH 601 HDS with Rotax 912
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Catz631(at)aol.com
Sent: Monday, October 27, 2008 12:48
To: rotaxengines-list(at)matronics.com
Subject: Re: RotaxEngines-List: Free Wheeling Prop
Les,
Dick Maddux
Kitfox 4-1200
912UL
Pensacola,Fl
| Quote: | | http://www.matronics.com/Navigator?RotaxEngines-List | 0123456789
No virus found in this incoming message. Checked by AVG - http://www.avg.com 270.8.3/1744 - Release Date: 24.10.2008 18:08 [quote][b]
Dale Orth
Posted: Tue Oct 28, 2008 6:25 pm Post subject: Re: Free Wheeling Prop |
Thanks Guys,
This is a great Web site. Very informative.
Dale
KitFox 7
Las Vegas, Nv
paul perry
Posted: Sun Nov 02, 2008 3:23 pm Post subject: Re: Free Wheeling Prop |
Dale, I have a 912ul (about 100hrs time) on a kitfox and have had a similar problem the last 2 days. The first time (11/1) I just hand turned the prop and started getting compression about every 3rd blade and kept this up until I could "burp" the oil tank. I then tried starting again and finally it fired but ran very rough for a few minutes before settling down. Then today (11/2) I hand rotated prop and again..no compression at all..this time I removed spark plugs one at a time and rotated prop and it may have been a coincidence, but after removing the first plug which was the bottom on cylinder number 3 (i think) once again I had compression about every 3rd blade. I went ahead and removed the other spark plugs one at a time, rotated prop and then re-installed plugs and nothing else changed..still compression about every 3rd blade. Spark plugs were fine as they were recently replaced (3hrs). Again, when starting the engine ran rough a couple of minutes but smoothed up to normal (a little quicker today than yesterday). Have you found anything else out about your problem? I really don't think I did anything to correct my problem other than turning the prop over and letting it sit a few minutes? Anybody else with ideas/experiences would be appreciated.
Thanks, Paul Perry
Dale Orth
Posted: Sun Nov 02, 2008 6:06 pm Post subject: Re: Free Wheeling Prop |
Hi Guys,
I talked to a Rotax mechanic in Phoenix and he said that carbon deposits on the valves can cause the "no compression" effect when hand propping. He recommended using Marvel Mystery Oil to the fuel to remove Carbon deposits. The previous owner of my plane always used auto fuel and the plane sat for long periods with the sludge from auto fuel building up. Since I'm not sure what I'm getting with Auto fuel I decided to use 100LL Avgas, add Mystery oil & change oil & filter every 25 hrs. I'm also adding Decalin to the Avgas. I was also told to run the engine hard for awhile when using Avgas. I'm using Aeroshell Plus 4 oil. The way I see it spending a little more $$$$ for Oil & additives is cheaper than an early Engine Overhaul. I guess time will tell if this works.
Dale
KitFox 7
Las Vegas, Nv
