paul(at)eucleides.com Guest
Posted: Sun Oct 26, 2008 9:12 pm Post subject: Zinc Chromate Paint / AC 43-4a |
Well well, I guess Zinc Chromate primer is available, just not in retail stores
<http://www.aircraftspruce.com/catalog/cspages/ptizincchromateprimer.php>
I could only find a scanned version of AC 43-4a.
<http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/a7ffc0f8b6216a43862569b5005081ed/$FILE/AC%2043-4a%20.pdf>
Certainly the FAA should have an original someplace because I found the section on
corrosion pertaining to Avionics in parts 1 and 2:
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/BE991FB487CD318586256CE100677049?OpenDocument>
Paul A. Franz, P.E.
PAF Consulting Engineers
Office 425.440.9505
Cell 425.241.1618
Float Flyr
Posted: Mon Oct 27, 2008 1:33 pm Post subject: Zinc Chromate Paint / AC 43-4a |
You need to find -1A/2B. It is also available for perusing in print form,
although I'm not sure what the cost is. I got mine when I was in school
studying aircraft maintenance and I'll certainolly echoLynns thoughts that
it is a great basis to have in the print form.
Well worth the $$ even if it is over $100 now which I doubt.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
