cookflys(at)yahoo.com Guest
Posted: Mon Oct 27, 2008 5:30 pm Post subject: exhaust in cabin |
Finished building and statred flying this summer a mod ll. With the weather turning cooler I flew with the doors closed a couple of days ago and I am getting an exhaust smell. Could this be comming from the bungee access area?
Charles Cook
Mod ll 582 Atl
msm_9949(at)yahoo.com Guest
Posted: Mon Oct 27, 2008 9:10 pm Post subject: exhaust in cabin |
Could be. Or from around cowling/firewall seal. Get a CO detector if you don't have one already. Cheap insurance.
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1
--- On Mon, 10/27/08, charles cook <cookflys(at)yahoo.com> wrote:
Quote: | From: charles cook <cookflys(at)yahoo.com>
Subject: exhaust in cabin
Date: Monday, October 27, 2008, 9:29 PM
Charles Cook
Mod ll 582 Atl
Guy Buchanan
Posted: Mon Oct 27, 2008 9:37 pm Post subject: exhaust in cabin |
At 06:29 PM 10/27/2008, you wrote:
Quote: | Could this be comming from the bungee access area?
I would think so. I have mine sealed.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Tom Jones
Posted: Tue Oct 28, 2008 4:42 am Post subject: Re: exhaust in cabin |
[quote="cookflys(at)yahoo.com"]Finished building and statred flying this summer a mod ll. With the weather turning cooler I flew with the doors closed a couple of days ago and I am getting an exhaust smell. Could this be comming from the bungee access area?
Charles Cook
Mod ll 582 Atl
On my first flight I had no sealing around the buggees and had exhaust smell in the cabin. I stuffed foam rubber in the openging and that stopped the smell. Carbon monoxide is oder less so I have a CO detector too.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
LarryM
Posted: Tue Oct 28, 2008 8:55 am Post subject: Re: exhaust in cabin |
Tom,
I have the same problem. I sealed up my old bungee opening, as I have a grove gear, and it didn't help. I then extended the exhaust pipe. You can go as long as you want - post muffler. That reduced it, but this is now about the 4 or 5 th winter I'm fighting this. We had been opening the door on a regular basis to get fresh air. We are not very well sealed either Cabin air wise. I am going to try 2 things, 1st - I'm going to baffle the part of the gear that goes under the fuselage - like a deflector. If that doesn't work, I'll extend the exhaust into a thin wall tube extending to at least the end of the cockpit - sort of like the Canadian Tiger Moths.
I find the whole deal puzzling, as are cabin is still rather breezy.
larry
kitfoxnick
Joined: 13 Apr 2008 Posts: 33 Location: Northern Maryland
Posted: Tue Oct 28, 2008 10:33 am Post subject: Re: exhaust in cabin |
I had the same problem in my IV with a 912 ul. I first extended the tail piece. While this was a little better it didn't solve the problem in fact it created another problem. After a few hours the muffler developed a crack from the added unsupported weight. I cut the stock exhaust pipe parrellel with the fuselage and since then I have no CO issues.
Nick W.
P.s. My bungee holes are not sealed.
_________________ Nick Weiskopf
Norrisville, MD
kitfox !V-1200
Rotax 912ul |
Float Flyr
Posted: Tue Oct 28, 2008 1:42 pm Post subject: exhaust in cabin |
Have a look at a Piper Aztec. Yes I know it's a bit like comparing chalk
and cheese but the exhausts they use on the Aztec are called extruders.
Basically it is an open tube about three times the diameter of the exhaust
pipe. That tube is lined up with the slipstream and the exhaust pipe
projects a few inches into the tube. The idea is the exhaust, CO and noise
is enveloped in a layer of cold air without causing any back pressure. They
say the Aztec is one of the quietest piston planes around the extruders may
be the reason.
The DHC beaver also uses an extruder it makes a pretty good noise but it is
a radial engine so it's supposed to let you know its working!
Noel Loveys
AME Intern, RPP
Kitfox III-A,
Aerocet 1100 floats
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Tue Oct 28, 2008 1:46 pm Post subject: exhaust in cabin |
I always love the topic of "unsupported tailpipes" because it gives
me a chance to display what did, and imagine what could have, happen
(ed) if you leave your pipes unsupported, especially if you extend
them to any degree. I was dumb enough to do both, and got lucky when
it didn't progress any further than what is pictured. You can see
that the (then) open exhaust licked at the firesleeve-covered fuel
line and the motormount, and got behind the flange of the battery
box...the black item at the left of the picture. Three weeks later,
the battery gave out, and I investigated and found the battery had
melted from the heat. Here's a shameless plug for Odyssey
batteries...took a lickin' and kept on tickin'
The last picture is of a stainless steel heat deflector that I built,
just in case the problem should ever occur again, and it also shows
how I supported the tail pipes.
This is a Jabiru installation, but a similar deflector/support method
could be used on other engines.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 579.1hrs +
Sensenich 62x46
flying again (17 hrs) after rebuild, and new Electroair direct-fire
ignition system
have no CO issues.
Nick W.
kitfox !V-1200
Rotax 912ul
http://forums.matronics.com/viewtopic.php?p 10816#210816
Description: |
Filesize: |
129.76 KB |
Viewed: |
686 Time(s) |
Description: |
Filesize: |
102.93 KB |
Viewed: |
688 Time(s) |
Description: |
Filesize: |
135.66 KB |
Viewed: |
725 Time(s) |
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
matronics(at)bob.brennan. Guest
Lynn Matteson
Posted: Tue Oct 28, 2008 2:20 pm Post subject: exhaust in cabin |
My flight instructor has similar devices on his Widgeon, and he calls
them "augmenters."
Lynn Matteson
Kitfox IV Speedster
Sensenich 62x46
ignition system
chalk
extruders.
exhaust
and noise
pressure. They
extruders may
be the reason.
but it is
Noel Loveys
AME Intern, RPP
Kitfox III-A,
Aerocet 1100 floats
N369LM |
Lynn Matteson
Posted: Tue Oct 28, 2008 2:51 pm Post subject: exhaust in cabin |
Sounds like a good plan, Bob.
Just for the record, I saw an even better method of supporting a
tailpipe when I was at Oshkosh this past summer. This idea came from
an award-winning (I believe) Hatz biplane.
There are two of these hangers on each pipe...you can just barely see
the mounting bracket for the second one. His is way better than the
"rubber strap" hangar like I used on mine, and someday I'll change
them out for this type of hanger....completely fireproof. It's just a
length of SS cable, a nicopress sleeve, a hose clamp, and a short
length of SS tubing...simplicity itself! I just got to thinking that
you could even leave off the SS tubing, and use another nicopress
sleeve for the two loops of SS cable to run through, and clamp that
to the pipe. That would bring the two hangers a bit closer together,
but it might work in some circumstances.
Lynn Matteson
Kitfox IV Speedster
Sensenich 62x46
ignition system
On Oct 28, 2008, at 6:14 PM, Bob Brennan wrote:
Quote: |
<matronics(at)bob.brennan.name>
Unsupported long tailpipes can indeed be a problem. Mine has extra
springs,
safety wired just in case, and it is *always* part of my pre-flight
to grab
my extra-long tailpipe and give it a good shake.
Bob Brennan - N717GB
Description: |
Filesize: |
417.29 KB |
Viewed: |
692 Time(s) |
N369LM |
gary.algate(at)sandvik.co Guest
Posted: Tue Oct 28, 2008 5:48 pm Post subject: exhaust in cabin |
Gents
be careful when modifying the 582 exhaust (especially with extractor type extensions) as they are a timed exhaust system which relies on pressure pulses to assist in charging the cylinders with fresh fuel/air mix. If you reduce the pressure on the outlet I'm sure that will have an effect on performance. This is not a problem with 4 stroke engines.
Gary
Gary Algate
SMC, Exploration
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
"Noel Loveys" <noelloveys(at)yahoo.ca>
Sent by: owner-kitfox-list-server(at)matronics.com
29/10/2008 08:23 AM
Please respond to
kitfox-list(at)matronics.com To
<kitfox-list(at)matronics.com> cc
Subject
RE: Re: exhaust in cabin
--> Kitfox-List message posted by: "Noel Loveys" <noelloveys(at)yahoo.ca>
be the reason.
Noel Loveys
AME Intern, RPP
Kitfox III-A,
Aerocet 1100 floats
Float Flyr
Posted: Wed Oct 29, 2008 5:06 am Post subject: exhaust in cabin |
Regardless what they are called (I may have been wrong...again ) it is my
experience they work well without increasing back pressure. They are light,
simple to construct and will take care of the CO entering the cabin I'm not
sure if they will also help reduce staining on the bottom of the plane.
The Widgeon is a beautiful plane especially for this neck of the woods.
Noel
Kitfox III-A
patreilly43(at)hotmail.co Guest
Posted: Wed Oct 29, 2008 7:01 am Post subject: exhaust in cabin |
Would the tube C as described C have extractor properties. Seems there wouldn't be any extractor properties as long as the large extension tube was the same diameter for it's entire length C thus not creating a venturi effect.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Subject: RE: Re: exhaust in cabin
Date: Wed C 29 Oct 2008 11:18:02 +0930
Gents
Gary
Gary Algate
SMC C Exploration
This e-mail is confidential and it is intended only for the addressees. Any review C dissemination C distribution C or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error C kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
"Noel Loveys" <noelloveys(at)yahoo.ca> Sent by: owner-kitfox-list-server(at)matronics.com
29/10/2008 08:23 AM
Please respond to
To
Subject
projects a few inches into the tube. The idea is the exhaust C CO and noise
be the reason.
Noel Loveys
AME Intern C RPP
Kitfox III-A C
Aerocet 1100 floats
Guy Buchanan
Posted: Wed Oct 29, 2008 8:10 am Post subject: exhaust in cabin |
At 07:59 AM 10/29/2008, you wrote:
Quote: | Would the tube, as described, have extractor properties. Seems there wouldn't be any extractor properties as long as the large extension tube was the same diameter for it's entire length, thus not creating a venturi effect. |
The tubes I've seen on large aircraft serve two purposes: 1) to decrease noise; and 2) to entrain engine cooling air in the cowl and encourage it's exhaust, thus increasing the delta-p across the cylinders and thereby increasing cooling, or reducing inlet size requirements and thereby reducing drag. (See Speed With Economy by Kent Paser.)
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Deceased K-IV 1200
Posted: Wed Oct 29, 2008 1:57 pm Post subject: exhaust in cabin |
After thinking about it C the large pipe opening is obstructed be the smaller exhaust pipe so the exhaust end of the large pipe would be significantly bigger than the opening. Would this create a venturi effect C act as an extractor and reduce back pressure enough to detrimentally affect cylinder loading? Anybody try it yet with the 582 C because the concept sounds good to me to reduce noise and possible exhaust gas entry to cabin.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Wed C 29 Oct 2008 09:03:21 -0700
At 07:59 AM 10/29/2008 C you wrote:
Quote: | Would the tube C as described C have extractor properties. Seems there wouldn't be any extractor properties as long as the large extension tube was the same diameter for it's entire length C thus not creating a venturi effect. |
The tubes I've seen on large aircraft serve two purposes: 1) to decrease noise; and 2) to entrain engine cooling air in the cowl and encourage it's exhaust C thus increasing the delta-p across the cylinders and thereby increasing cooling C or reducing inlet size requirements and thereby reducing drag. (See Speed With Economy by Kent Paser.)
Guy Buchanan
San Diego C CA
K-IV 1200 / 582-C / Warp / 100% done C thanks mostly to Bob Ducar. [quote]
target=_blank>http://www.matronics.com/Navigator?Kitfox-List
=_blank>http://www.matronics.com/contribution
brubakermal(at)yahoo.com Guest
Posted: Wed Oct 29, 2008 4:39 pm Post subject: exhaust in cabin |
my exaust leeks at the joint it was cut to fit the cowling (582) I put little trim piece under the cowling to help draw the fumes out by low pressure vacuum is works very well. is there anyone there that can re cut and weld a new elbow for me??
--- On Wed, 10/29/08, patrick reilly <patreilly43(at)hotmail.com> wrote:
[quote]From: patrick reilly <patreilly43(at)hotmail.com>
Date: Wednesday, October 29, 2008, 9:55 PM
#yiv1487376370 .hmmessage P { margin:0px;padding:0px;} #yiv1487376370 { FONT-SIZE:10pt;FONT-FAMILY:Tahoma;} After thinking about it, the large pipe opening is obstructed be the smaller exhaust pipe so the exhaust end of the large pipe would be significantly bigger than the opening. Would this create a venturi effect, act as an extractor and reduce back pressure enough to detrimentally affect cylinder loading? Anybody try it yet with the 582, because the concept sounds good to me to reduce noise and possible exhaust gas entry to cabin.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Date: Wed, 29 Oct 2008 09:03:21 -0700
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote] target=_blank>http://www.matronics.com/Navigator?Kitfox-Listttp://forums.matronics.com=_blank>http://www.matronics.com/contribution[b]
