cjhukill(at)cox.net Guest
Posted: Sun Nov 02, 2008 8:04 am Post subject: Baggage door bowed |
Upon fitting my baggage door to the fuselage to drill the hinge, I find that the door has a pronounced outward bow,
at the top, in the middle, so that the door's top edge isn't flush.
With a strait edge, I can see the door is bowed out about 1/8 inch.
To make matters worst, the QB fuselage has about a 1/16 inch bow IN the same area (center, top edge of door). The fuselage may push out some when the top is attached, but the bow in the door will still be un-acceptable. The bow probably came about due to the dimpling process, but I didn't notice until fitting. Can I tweak the door to try to straiten it, or do I need to build a new one, this time with some precautions to prevent it from warping?
Obviously I may as well try to fix the door. Has anyone else had this issue, and how did you straiten the door? I'm thinking about ripping a 2x4 on the bandsaw,with a reverse curve to it, thus creating a male /female template, then squeezing the top of the door between the pieces. Anyone else have any experience with this, or any ideas?
Chris Hukill
Posted: Sun Nov 02, 2008 8:11 am Post subject: Baggage door bowed |
ChrisStop by today I ll show you what I didRick
Sent via BlackBerry by AT&T
Date: Sun, 2 Nov 2008 08:00:25 -0800
Subject: RV10-List: Baggage door bowed
Upon fitting my baggage door to the = fuselage to=20 drill the hinge, I find that the door has a pronounced=20outward bow,
at the top, in the middle, so that the = door's top=20 edge isn't flush.
With a strait edge, I can see the door = is bowed=20out about 1/8 inch.
To make matters worst, the QB fuselage = has about=20 a 1/16 inch bow IN the same area = (center,=20 top edge of door). The fuselage may push out some when the top is = attached, but=20 the bow in the door will still be un-acceptable. The bow probably came = about due=20 to the dimpling process, but I didn't notice until fitting. Can I tweak = the door=20 to try to straiten it, or do I need to build a new one, this time with = some=20 precautions to prevent it from warping?
Obviously I may as well try to fix the = door. Has=20 anyone else had this issue, and how did you straiten the door? I'm = thinking=20 about ripping a 2x4 on the bandsaw,with a reverse curve to it, = thus=20 creating a male /female template, then squeezing the top of the door = between the=20 pieces. Anyone else have any experience with this, or any = ideas?
Chris Hukill
| Quote: | | _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D _-=3D -- Please Support Your Lists This Month -- _-=3D (And Get Some AWESOME FREE Gifts!) _-=3D _-=3D November is the Annual List Fund Raiser. Click on _-=3D the Contribution link below to find out more about _-=3D this year's Terrific Free Incentive Gifts! _-=3D _-=3D List Contribution Web Site: _-=3D _-=3D --> http://www.matronics.com/contribution _-=3D _-=3D Thank you for your generous support! _-=3D _-=3D -Matt Dralle, List Admin. _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - The RV10-List Email Forum - _-=3D Use the Matronics List Features Navigator to browse _-=3D the many List utilities such as List Un/Subscription, _-=3D Archive Search & Download, 7-Day Browse, Chat, FAQ, _-=3D Photoshare, and much much more: _-=3D _-=3D --> http://www.matronics.com/Navigator?RV10-List _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - MATRONICS WEB FORUMS - _-=3D Same great content also available via the Web Forums! _-=3D _-=3D --> http://forums.matronics.com _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D |
