Mike Schnabel
Joined: 27 Jan 2006 Posts: 114 Location: Manchester, TN
Posted: Sun Mar 12, 2006 7:41 am Post subject: Grass strip turf question |
Gentlemen,
Finally spring is nearing, and the rain has stayed away long enough for ground preparation on my grass runway. We have been working the ground the last few months, and have disked and dragged to what is now a very nice level surface.
My question: its now time to decide what grass to attempt to grow that is best suited for a runway (if it really makes much difference). Does anyone have an opinion?
Thanks in advance for sharing your thoughts!
Mike S
Firestar2 503
Manchester TN
Bring photos to life! New PhotoMail makes sharing a breeze.
Posted: Sun Mar 12, 2006 7:49 am Post subject: Grass strip turf question |
| Mike S
Mike:
I'm not a grass man, but I am lucky enough to have a little grass
strip.
I can't remember what kind of seed I sewed after tilling, but never
put any more on it after the initial planting. My strip is surrounded
by and was part of the hay fields/pastures of the farm.
I'd check with the local country agent or the man at the feed/seed
store, and go with his recommendations. For me, all I want is
something to cover the dirt and keep the dust and errosion down.
No matter what you put on it, it will grow too fast in the summer.
MKIII
_________________ John Hauck
Titus, Alabama |
tkrolfe(at)usadatanet.net Guest
Posted: Sun Mar 12, 2006 8:14 am Post subject: Grass strip turf question |
Mike Schnabel wrote:
Gentlemen,
Mike S
Firestar2 503
Manchester TN
Mike,
Ask your local Agway dealer about "Shortcut" grass.
Terry - FireFly #95
rsanoa
Joined: 10 Jan 2006 Posts: 71 Location: Bell Buckle,TN
Posted: Sun Mar 12, 2006 8:27 am Post subject: Grass strip turf question |
All,
On subject of strips and runways, I nominate John H. and his Kolb for this. A Kolb is a perfect vehicle for it. Forget grass. Many years ago while doing some airshow work, we had an act known as the worlds smallest airport. A J3 cub would take off and land on top of an automobile. Of course the auto had to be moving. A couple of 20-22 ft.wood channels were fastened on top of a car, with a couple of properly placed wheel "wells" up at the end. The Cub was placed on top in position and the car driven to take off speed and the pilot just gave it full throttle and lifted off. Came in over the car at landing speed and carefully dropped into the wheel wells, throttled back, and there he was. Kolb visibility and landing speed perfect for this. Johns experience in dropping helicopters into tight landing spaces makes him the logical candidate to do it first with a Kolb. Who will volunteer to go down and videotape?
do not archive.
John Hauck <jhauck(at)elmore.rr.com> wrote:
Mike:
strip.
MKIII
Use Photomail to share photos without annoying attachments.
_________________ Ray S.Anderson |
Posted: Sun Mar 12, 2006 8:31 am Post subject: Grass strip turf question |
At 07:40 AM 3/12/06 -0800, you wrote:
have an opinion?
Mike,
After moving to Winchester, IN and moving into a new home, I had to figure
out what lawn seed to use. I talked to a fellow who baby sits I22 about
what grass to use. He had a home landing strip and recommended Manhattan
II. It is a dwarf perennial rye grass. If you are not going to graze your
strip and you are going to mow it, this may be the grass for you.
I Googled the web and found a source at:
http://www.ryegrasses.com/info/turfseed/manhattan.html
The latest variety is Manhattan IV. I have used this grass to establish a
new lawn around the house. It is a little pricey, but I believe it is well
worth it, just for the difference in mowing expense. When I get my runway
levelled, I will be using it on the runway too.
Jack B. Hart FF004
Winchester, IN
Posted: Sun Mar 12, 2006 8:49 am Post subject: Grass strip turf question |
Kolb for this.
Ray Anderson
Ray:
Maybe we ought to get some of the younger folks to try that. Maybe
someone in the 20's or 30's.
Do we have anyone on the Kolb List that young? or will we have to go
with a 40 year old?
DO NOT ARCHIVE
Titus, Alabama |
herbgh
Kirk Smith
Posted: Sun Mar 12, 2006 11:37 am Post subject: Grass strip turf question |
I just let the weeds that grow here naturally come up and mowed them.
Bill Vincent
Posted: Sun Mar 12, 2006 12:51 pm Post subject: Re: Grass strip turf question |
Hi Gang
I agree with Kirk, but personally, I think you should plant any type of grass that deer dislike (maybe even plant astro turf
The deer on the runway that I fly from usually come out at dusk, they used to run when they heard me coming in for a landing, but now they just stand there and stick their tongues out at me...four times last year I had to abort my landing because they were either standing in the way or they were running across the runway in front of me, I am thinking it is the clover in the grass they like.
_________________ Bill Vincent
Firestar II
Upper Peninsula of Michigan |
biglar
Posted: Sun Mar 12, 2006 2:25 pm Post subject: Grass strip turf question |
Yah, but those're Yooper deer. Do not Archive.
Larry Bourne
Palm Springs, CA
Building Kolb Mk III
N78LB Vamoose
www.gogittum.com
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
Kirk Smith
Posted: Sun Mar 12, 2006 3:45 pm Post subject: Grass strip turf question |
n79rt(at)kilocharlie.us Guest
Posted: Sun Mar 12, 2006 7:05 pm Post subject: Grass strip turf question |
Gentlemen,
Mike S
Firestar2 503
Manchester TN
We use Bermuda here in central Mississippi; it's durable & grows low &
fairly slow. Cuts down on mowing a lot if we can keep the dallas grass &
other weeds off it. One or two treatments a season with MSMA helps a lot.
Be sure to check on whether the grass you choose will thrive in your
climate. One of the founding members of our strip did a lot of research,
found some expensive custom breed that's great for runways, bought a lot
of it & it all died. Seems it was bred for northern climes & 'couldn't
take the heat.'
Denny Rowe
Joined: 10 Jan 2006 Posts: 89 Location: Leechburg, PA
Posted: Sun Mar 12, 2006 9:54 pm Post subject: Grass strip turf question |
Mike,
I bought Timithy (hay) seed from a local farmer. Several farmers sell it
around here for $20-$25 a bushel.
You may have the deer problems with it that someone mentioned as they do
like it but it is dirt cheap and that makes it easy to overseed so it comes
in thick, it also came up nice and quick.
You might want to check with the local farmers.
Denny
ultrastarrick(at)yahoo.co Guest
Posted: Mon Mar 13, 2006 6:45 am Post subject: Grass strip turf question |
Go to your local golf coarse and see which farway grass they use for your area.
or the greans which would be shorter and a finer blade but may not be as derable as the farway grass
Mike Schnabel <tnfirestar2(at)yahoo.com> wrote:
Gentlemen,
Mike S
Firestar2 503
Manchester TN
