Fred.Stucklen(at)UTCPower Guest
Posted: Tue Nov 04, 2008 5:33 am Post subject: Gas Cap "O" Rings |
Listers,
I'm looking for a source of gas cap "O" rings that are low temperature equivalents to the
Brown "O" rings that are supplied with kits and new gas caps.
The brown variety that Van supplies do not work well in temps below 15* F.. At low
temps, the gas cap is impossible to remove. The brown "O" ring seems to not contract
and allow the gas cap to be lifted.
Years ago I found a local "O" ring source, but it has since gone out of business... Does
anyone have another source?
Fred Stucklen
RV-7A N924RV 75 Hrs [quote][b]
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
wdleonard(at)gmail.com Guest
Posted: Tue Nov 04, 2008 5:48 am Post subject: Gas Cap "O" Rings |
Try McMaster Carr. They have a large selection of o-rings in a variety of materials.
Dave Leonard
On Tue, Nov 4, 2008 at 5:32 AM, Stucklen, Frederic W UTPWR <Fred.Stucklen(at)utcpower.com (Fred.Stucklen(at)utcpower.com)> wrote:
Fred Stucklen
RV-7A N924RV 75 Hrs
David Leonard
Turbo Rotary RV-6 N4VY
http://N4VY.RotaryRoster.net
http://RotaryRoster.net
Kellym
Posted: Tue Nov 04, 2008 6:04 am Post subject: Gas Cap "O" Rings |
The O-rings should be MS29512 series, for static applications with
hydocarbon fuels, made to Mil-P-5315 spec, which are rated for -65 to
+200 degrees, and black in color. I don't know what material Van uses.
David Leonard wrote:
Quote: | Try McMaster Carr. They have a large selection of o-rings in a
Dave Leonard
<Fred.Stucklen(at)utcpower.com <mailto:Fred.Stucklen(at)utcpower.com>> wrote:
Listers,
*Fred Stucklen*
RV-7A N924RV 75 Hrs
David Leonard
KCHD |
rv9jim(at)juno.com Guest
Posted: Tue Nov 04, 2008 6:23 am Post subject: Gas Cap "O" Rings |
Hi Fred,
I sell O-Rings at my shop (all kinds). The Viton (available in
brown or black) is rated from -65*F to +500*F. The best reason for the
brown version is to avoid confusion of materials. All the rest of the
O-Rings are black and hard to tell the difference in materials. Such as
Buna, Butyl, Ethylene Propylene. So the brown helps. Any material at
the temps of around 15*F and lower are going to be stiffer than at higher
temps. I use a wooden dowel (with calibrations at 5-10-15 gallons) with
a steel pin (nail with out head) inserted on one end. I use it to lift
the lock on the cap. At that point, you grip the cap and lift. If it
comes out with a lot of effort, I would make up a device to "hook" on to
the cap to pull it from the tank.
Is that confusing enough??
Jim Nelson
RV9-A
Click here and choose from thousands of high quality used cars.
http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3oE0bmQByYhqqwhMEsVvhS8QRLDS76yF8shf0JT9u8UggS19/
rmkeith(at)gwi.net Guest
Posted: Tue Nov 04, 2008 4:48 pm Post subject: Gas Cap "O" Rings |
The o rings are 2-325 viton-75 a softer compound might help. Buna-N is also an acceptable compound and can be found with a Shore hardness of 70.
Russ Keith
RV9A 90%DONE $10,000 left to go I think
Posted: Tue Nov 04, 2008 5:24 pm Post subject: Gas Cap "O" Rings |
15* F.. At low
to not contract
*Fred Stucklen*
RV-7A N924RV 75 Hrs
I'll pass on a tip someone else gave me:
http://allorings.com/
The size is 2-325 (1 7/8" ID) in Buna-n.
They will sell a bag of 10 for $10, but the assortment on the primary
web page includes something like a half-dozen of that size plus a LOT of
other sizes in a nice box, p/n 70D, for the same price. Total with
shipping is around $20. I've been using a pair & running autogas for
about a year with no ill effects (originals swelled up badly on autogas).
YMMV, etc etc.
Charlie
ghinman(at)mts.net Guest
Posted: Wed Nov 05, 2008 6:34 am Post subject: Gas Cap "O" Rings |
Fred
At low temps,Lift the lock of the gas cap and let it sit
for 15min or so,befor removing the cap.
The ring will have time to relax making it easier to remove.
George H. Inman
ghinman(at)mts.net
chaskuss(at)yahoo.com Guest
Posted: Wed Nov 05, 2008 8:10 am Post subject: Gas Cap "O" Rings |
Buna N will work fine with 100LL, but Viton is a better choice, if you plan on using Auto Fuel. The additives in unleaded auto fuels will cause Buna N (aka Nitrile) to shrink over time.
Charlie Kuss
--- On Tue, 11/4/08, Russ & Marilyn <rmkeith(at)gwi.net> wrote:
[quote] From: Russ & Marilyn <rmkeith(at)gwi.net>
Subject: Re: Gas Cap "O" Rings
To: rv-list(at)matronics.com
Date: Tuesday, November 4, 2008, 7:44 PM
Russ Keith
