pequeajim
Joined: 03 Sep 2006 Posts: 708 Location: New Holland, PA
Posted: Mon Nov 03, 2008 6:26 pm Post subject: Fuel Filters |
What are you all using for fuel filters?
Also, has everyone used the supplied fuel line?
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
catalpaaviation(at)wideba Guest
Posted: Tue Nov 04, 2008 1:17 pm Post subject: Fuel Filters |
Jim
I have used the supplied fuel lines and Z15 filters same as Jabiru, no problems at all.
Anthony Kit32
pequeajim
Posted: Tue Nov 04, 2008 1:21 pm Post subject: Fuel Filters |
Thanks Anthony, what brand are the Z15 filters?
On Tue, Nov 4, 2008 at 4:13 PM, Catalpa aviation <catalpaaviation(at)wideband.net.au (catalpaaviation(at)wideband.net.au)> wrote:
Jim
Anthony Kit32
Posted: Tue Nov 04, 2008 1:38 pm Post subject: Fuel Filters |
Jim
They are just cheap ones from the local auto cheap store, no brand. Same place I obtain oil filters (Z386) and NGK plugs.
As a matter of interest what needle jet, main jets have you fitted and how many turns out for the idle jet?
How’s the election going?
Anthony
pete(at)flylightning.net Guest
Posted: Tue Nov 04, 2008 1:41 pm Post subject: Fuel Filters |
We use Fram G1 filters in our Jabiru LSA installations.
Pete
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Jim Langley
Sent: Tuesday, November 04, 2008 3:21 PM
To: lightning-list(at)matronics.com
Subject: Re: Fuel Filters
Jim
Anthony Kit32
-----Original Message-----
From: owner-lightning-list-server(at)matronics.com (owner-lightning-list-server(at)matronics.com) [mailto:owner-lightning-list-server(at)matronics.com (owner-lightning-list-server(at)matronics.com)] On Behalf Of Jim Langley
Sent: Tuesday, 4 November 2008 1:26 PM
To: lightning-list(at)matronics.com (lightning-list(at)matronics.com)
Subject: Fuel Filters
Also, has everyone used the supplied fuel line? 012345678901234
pequeajim
Posted: Tue Nov 04, 2008 1:47 pm Post subject: Fuel Filters |
Ok, I have Fram G2 paper filters in line right now. I believe that Green Landings uses the G1 filters and the only difference is in the nipple diameter. I have not changed out the jet from stock yet as the engine runs very strong. More flying will determine what to do from there.
None of the polls have closed yet, but Obama looks to be a winner by everything I have seen.
I'm not sure I like ether one of them.
Jim!
On Tue, Nov 4, 2008 at 4:36 PM, Catalpa aviation <catalpaaviation(at)wideband.net.au (catalpaaviation(at)wideband.net.au)> wrote:
Jim
How's the election going?
Anthony
pequeajim
Posted: Tue Nov 04, 2008 1:48 pm Post subject: Fuel Filters |
Ha, Pete, you caught me typing when you sent your message.
I am getting ready to order some of the G1s. I just needed to hear the word from you guys on what you use.
Jim!
On Tue, Nov 4, 2008 at 4:46 PM, Jim Langley <pequeajim(at)gmail.com (pequeajim(at)gmail.com)> wrote:
[quote] Ok, I have Fram G2 paper filters in line right now. I believe that Green Landings uses the G1 filters and the only difference is in the nipple diameter. I have not changed out the jet from stock yet as the engine runs very strong. More flying will determine what to do from there.
Jim!
Jim
Anthony
pennington(at)q.com Guest
Posted: Tue Nov 04, 2008 4:46 pm Post subject: Fuel Filters |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Hello Anthony
I noticed you listed an oil filter for the Jab 3300 as Z386. What brand is that? Is it available in the US?
Gary Pennington
Posted: Tue Nov 04, 2008 5:17 pm Post subject: Fuel Filters |
Hullo Gary
Z386 is a common filter in Aust and can be purchased from any auto shop, Jabiru recommend RYCO. Made in South Africa by G.U.D Filters
Anthony
lbmathias(at)verizon.net Guest
Posted: Tue Nov 04, 2008 5:56 pm Post subject: Fuel Filters |
Gary,
Napa's equivalent to the Ryco Z386 oil filter works just fine in the 3300. I can't remember the part number but it is readily available in the U.S.
Linda
selwyn
Posted: Wed Nov 05, 2008 3:39 am Post subject: Re: Fuel Filters |
The "Z" numbers are all Ryco filter numbers, and tend to be the often quoted filter numbers here, but everybody and his dog makes "equivalents" and sells them through el cheapo automotive outlets. The Z15 is a basic nylon enclosed pleated paper filter designed to get the large lumps out of fuel. http://www.rycofilters.com.au/catalogue/product/part/Z15
The Fram G1 is similar. I have a ryco Z15 as a primary filter on the long range tank of my 4WD which has had about 20,000 km worth of diesel through it and shows no sign of blocking, so it is not a fine filter.
The oil filter may be a little more critical and my feeling is that you would do well to source a high quality equivalent.
On a more general note, why do we have the Z15's in the fuel system anyway? In Jabs they are the main (only?) filter in the fuel system but in the Lightning we have finger filters in the tank pickups which will get out anything likely to block the fuel lines and a gascolator which will get out anything likely to block the jets, what do the Z15's do for us except introduce another source of leaks and blockages?
_________________ Cheers, Selwyn
Kit 66 VH-ELZ |
Clive J
Posted: Wed Nov 05, 2008 4:11 am Post subject: Fuel Filters |
Good question Selwyn, we should only filter what can block jets or
damage pumps. Let the rest pass through.
In my microlight days we used a nylon mesh filter that allowed a certain
size of crud to pass through. Previously folk had used paper filters and
had issues with them as they blocked up at awkward times (when folk were
flying). They also collected water.
A reasonably fine nylon mesh filter was the standard fit for the Rotaxes
that I flew in those days.
I used to back flush it once a year to get rid of what it had caught
when I did the annual. They had a see though case so you could visually
check them anytime you had the covers off.
My Esqual was supplied with nylon mesh filters and that's what I fitted.
My Jabiru has the Ryco supplied one though I'm going to look out for a
nylon one for that too. I don't have a gascolator, I do drain the tanks
before every flight and after every refuel.
Regards, Clive
Esqual 3300
Jabiru SP 2200
Posted: Wed Nov 05, 2008 5:05 am Post subject: Fuel Filters |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Thank you..... to everyone.
Have a great day!
Gary
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
