Afterfxllc(at)aol.com Guest
Posted: Wed Nov 05, 2008 1:16 pm Post subject: D100 compass |
Have fun crawling thru the airplane to install and service it but hey you know what's best for you. If you watch what you are doing you can keep the wires away from it and it works. The manual warns against ppl putting it on top of the battery because someone would do it but putting it in the tail is overkill.
Jeff
AOL Search: Your one stop for directions, recipes and all other Holiday needs. [url=http://pr.atwola.com/promoclk/100000075x1212792382x1200798498/aol?redir=http://searchblog.aol.com/2008/11/04/happy-holidays-from-aol-search/?ncid=emlcntussear00000001 ]Search Now[/url].
Gig Giacona
Posted: Wed Nov 05, 2008 4:09 pm Post subject: Re: D100 compass |
Is that the Amp shunt two inches to the right of it?
Afterfxllc(at)aol.com wrote: | Have fun crawling thru the airplane to install and service it but hey you know what's best for you. If you watch what you are doing you can keep the wires away from it and it works. The manual warns against ppl putting it on top of the battery because someone would do it but putting it in the tail is overkill.
Jeff
601XL Under Construction
Posted: Wed Nov 05, 2008 4:16 pm Post subject: D100 compass |
Get over yourself
Gig Giacona
Posted: Wed Nov 05, 2008 4:50 pm Post subject: Re: D100 compass |
Wow, I was just asking.
DO NOT ARCHIVE
Posted: Wed Nov 05, 2008 5:05 pm Post subject: D100 compass |
Gig
Sorry I'm having a very bad day and your question was taken as a smart remark... I really thought the coils would be the main problem but the compass doesn't fluctuate at all. I leave 6 inches of shielded wire just in case I have a problem. I'm trying to dig up the other photo's but they are in 3 different pc's The center stick XL has it in a slightly different place.
Jeff
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Wed Nov 05, 2008 5:06 pm Post subject: Re: D100 compass |
A lot has been said, but here's what I did and why. I finally mounted mine near the rear access panel at the back of the plane. I first hooked the unit up and connected to the Dynon before permanently mounting it. I had an inexpensive magnetic compass that I used to verify the heading of the plane. This also validated the magnetic alignment of my workshop on our plat. The plane was setting parallel to the building. I planned on putting the electronic magnet behind the passenger seat. I couldn't find anywhere in that area that it read accurately. The flap torque tube was causing a lot of magnetic interference (ferrous), and when I got it far enough from the flap controls the steel tube framing of the step started taking over. My final location in the back of the plane is very convenient and easily reached and there was no measurable deviation due to local magnetic fields.
Dan 601XL Dempsey (should be test running my engine soon)
_________________ Scratch building XL with Corvair Engine |
