		dalemed
				 Posted: Sat Nov 08, 2008 12:57 pm    Post subject: Cable load on rear rib 7 |
				I'm in the process of attaching the Bellcrank Support and Bellcrank Support Channel to Rear Rib 7.  I can't help but wonder how RR7 supports 70 (+/-10) lbs of cable force (each cable pulling with 30 (+/-5) lbs.).
 It's Saturday or I'd call the factory to ask them if it might be wise to add L angle doublers to the  Bellcrank Support Channel.
 Am I unnecessarily concerned?
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Dale
Zenith Zodiac CH650 |
		leo(at)zuehlfield.com Guest
				 Posted: Sat Nov 08, 2008 1:33 pm    Post subject: Cable load on rear rib 7 |
				dalemed wrote:
 I believe that is only 30 +/- 5 lbs pull on the rib.
  	  | Quote: | 	 		   It's Saturday or I'd call the factory to ask them if it might be wise to add L angle doublers to the  Bellcrank Support Channel.
  Dale
  Flying Cessna 170B
  Building Zenith 601XL
 Leo Gates
 N601Z - CH601HDS TDO
 Rotax 912UL
		Gig Giacona
				 Posted: Sat Nov 08, 2008 1:58 pm    Post subject: Re: Cable load on rear rib 7 |
				I don't think it would create a combined load like that because the other end is also dealing with half of the tension. It is just 30 (+/-5) lbs.
  	  | dalemed wrote: | 	 		  I'm in the process of attaching the Bellcrank Support and Bellcrank Support Channel to Rear Rib 7.  I can't help but wonder how RR7 supports 70 (+/-10) lbs of cable force (each cable pulling with 30 (+/-5) lbs.).
 Am I unnecessarily concerned? |
601XL Under Construction
		pavel569
				 Posted: Sun Nov 09, 2008 5:26 am    Post subject: Re: Cable load on rear rib 7 |
				It seems that very soon we will be questioning every single rivet on the plane that is flying in numbers for years already. Keep building according to plans and we'll be fine, IMHO.
 Before I riveted the rudder together, I just wondered how this sheet of zerozeronothing aluminum can turn the plane. Try to bend your rudder after its done
  _________________ Pavel
CA
Zodiac 601XL
Stratus Subaru EA-81
Tail, flaps, ailerons, wings, fuselage, canopy done ...
"do not archive" |
		bryanmmartin
				 Posted: Sun Nov 09, 2008 11:17 am    Post subject: Cable load on rear rib 7 |
				Yes, you are being unnecessarily concerned. It may look flimsy with just the skeleton laying there in your workbench but you'll be amazed how much more solid everything gets after the skins get riveted on. I've never heard of any problems in that area and the fleet has accumulated thousands of hours. Build it to plans and fight the urge to add structure and weight where none is needed. You would also be amazed at how quickly those little modifications can add excess weight to the final assembly.
 dalemed wrote:
  	  | Quote: | 	 		  I'm in the process of attaching the Bellcrank Support and Bellcrank Support Channel to Rear Rib 7.  I can't help but wonder how RR7 supports 70 (+/-10) lbs of cable force (each cable pulling with 30 (+/-5) lbs.).
 Bryan Martin
 N61BM, CH 601 XL,
 RAM Subaru, Stratus redrive.
 do not archive.
  _________________ --
Bryan Martin
do not archive. |
		dalemed
