Posted: Sun Nov 09, 2008 9:28 am Post subject: Still "fighting" with Audio Ground |
One has to be very careful with Audio grounds, to avoid unwanted “noise”, and I’m still “fighting” with this.
I am finishing my Intercom wiring and I have what I think to be my last question about this subject:
I have to connect 3 shielded wires (Radio Receive Audio, Radio Transmit Audio and Nav Audio) from the SL-30 Comm/Nav Radio to the Intercom, and I wonder if I should connect the shields to audio ground on both ends (Radio and Intercom) or only one side (which one?)?
Carlos
nuckolls.bob(at)cox.net Guest
Posted: Sun Nov 09, 2008 10:10 am Post subject: Still "fighting" with Audio Ground |
At 05:26 PM 11/9/2008 +0000, you wrote:
| Quote: | One has to be very careful with Audio grounds, to avoid unwanted noise ,
and I m still fighting with this.
What do the installation instructions show?
See page 13 of . . .
http://www.aeroelectric.com/DIY/Audio_Isolation_Amplifier.pdf
Here I show a combination of shielded wires where
some instances use the shield for both noise
mitigation -AND- part of a signal pathway . . .
i.e. shields connected at both ends. In others
the are not used to serve any purpose other than
noise mitigation.
Make sure that your installation instructions
do not show specific connections to both ends.
If not, ground once to either end. It doesn't
matter which on a small installation like the
panel of an S.E. aircraft.
