gus
Posted: Mon Nov 10, 2008 4:47 pm Post subject: CH701 nose wheel bearing |
I am looking for ideas to improve the bearing on my nose wheel strut. I have many versions , what works best?
Brady
Posted: Tue Nov 11, 2008 9:24 am Post subject: Re: CH701 nose wheel bearing |
Gus,
What is wrong with the design in the plans?
_________________ Brady McCormick
Poulsbo, WA
www.magnificentmachine.com |
gus
Posted: Tue Nov 11, 2008 12:46 pm Post subject: Re: CH701 nose wheel bearing |
I am interested in learning what others have done with the metal to metal contact. It seems to me this design will wear fast and not be very smooth.
Brady
Posted: Tue Nov 11, 2008 1:00 pm Post subject: Re: CH701 nose wheel bearing |
There should be no metal to metal, the strut rides in a nylon block bearing.
How old are your plans?
Poulsbo, WA
JohnDRead(at)aol.com Guest
Posted: Tue Nov 11, 2008 1:05 pm Post subject: CH701 nose wheel bearing |
I think it is a ball bearing unit.
John Read
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 11/11/2008 1:47:22 P.M. Mountain Standard Time, gusjohnson008(at)gmail.com writes:
| Quote: | --> Zenith701801-List message posted by: "gus" <gusjohnson008(at)gmail.com>
http://forums.matronics.com/viewtopic.php?p=213561#213561
AOL Search: Your one stop for directions, recipes and all other H1200798498/aol?redir=http://searchblog.aol.com/2008/11/04/happy-holidays-from-aol-search/?ncid=emlcntussear00000001 ">Search Now.
Brady
Posted: Tue Nov 11, 2008 2:32 pm Post subject: Re: CH701 nose wheel bearing |
The bearing that the strut rides in is Nylon.
I understood that to be the bearing he was talking about.
The Nose Wheel bearing is a ball bearing.
I think he said "nose wheel strut" bearing.
Poulsbo, WA
gus
Posted: Tue Nov 11, 2008 5:25 pm Post subject: Re: CH701 nose wheel bearing |
yes a nylon block , thats what I have seen. My drawings are dated 09/01. Do the block specs include the "gear extended self centering ramps? Are drawings available for the nylon version? Thanks for the help.
Posted: Tue Nov 11, 2008 5:43 pm Post subject: CH701 nose wheel bearing |
The attached photo is actually from an HD (Larry McFarland's?) but the
design on my 701 looks the same and I'll be adding the nylon. Basically add
nylon plates with V notches inside and parallel to the aluminum angle.
-- Craig
88.86 KB |
780 Time(s) |
Posted: Tue Nov 11, 2008 5:50 pm Post subject: CH701 nose wheel bearing |
Even the latest plans (7-L-1 dated 04/2006) show the V notch as bare
aluminum (7F8-6 dated 06/2005). I sent a picture in another message showing
how to add nylon V notches.
-- Craig
gus
Posted: Wed Nov 12, 2008 5:43 pm Post subject: Re: CH701 nose wheel bearing |
The pictures look good. I have some 1/4" Nylatron sheet stock, that should fit well. Thanks for the pictures.
gus
Posted: Mon Nov 17, 2008 6:40 am Post subject: Re: CH701 nose wheel bearing |
In order to get full bearing contact I'm considering lathe turning two bushings , these would require opening the 2" up to 2 1/4" on 7.F.8.4 ,7.F.8.5 and 7.F.7.4 . I would leave a flange on these bushings to allow bolting or riveting in place . They would also need a saw cut to allow them to fit over the nose gear strut assy. 7.L.1.1. My concern with the method in the photo is after the nylon wears a little , we will be back to metal on metal. What are your thoughts on this method ? Thanks Gus
