nail13zg(at)centurytel.ne Guest
Posted: Wed Nov 05, 2008 9:42 am Post subject: Dual Bing Carbs Hookup |
Does anyone have specifics on how to hook up the dual bing carbs on the
Stratus Subaru engine to a single cable throttle, including cable part
numbers etc. Building a Kitfox 5
Trey Moran
KF 5
| | - The Matronics Stratus-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Stratus-List |
gkrysztopik(at)satx.rr.co Guest
Posted: Wed Nov 05, 2008 10:24 am Post subject: Dual Bing Carbs Hookup |
I used a cable splitter from Lockwood Aviation and bicycle cables.
Larry has a nice setup on his Zenith www.macsmachine.com
gary
Trey Moran wrote:
<nail13zg(at)centurytel.net>
the Stratus Subaru engine to a single cable throttle, including cable
part numbers etc. Building a Kitfox 5
Trey Moran
KF 5
Gary Krysztopik
www.ZWheelz.com
San Antonio, TX
Posted: Wed Nov 05, 2008 2:35 pm Post subject: Dual Bing Carbs Hookup |
Hi Trey,
I changed my dual-cable throttle setup to single cable sheath and a
music wire within and a connection that joins both Bings in a common link.
It's been working fine for 4 years now. Pictures on my sites engine and
controls pages show how it's hooked up. If you need more information,
just ask. Mine is also the Stratus, so it's informational specific.
See links,
www.macsmachine.com/html/subaruengine.htm
www.macsmachine.com/html/controllinkages.htm
http://www.macsmachine.com/images/controllinkages/full/throttlelink.gif
http://www.macsmachine.com/images/controllinkages/full/panelinflight(2).gif
My throttles on the panel side are common friction adjustable cables.
Trey Moran wrote:
Trey Moran
KF 5
Posted: Fri Nov 07, 2008 5:34 pm Post subject: Dual Bing Carbs Hookup |
Larry,
I am intrigued by how you hooked the two carbs using one cable. Can't figure
it out from the pictures. Can you give me a few details? Did you use any of
the Rotax hardware? Did you do the same thing for the choke?
Trey
Posted: Sat Nov 08, 2008 7:47 am Post subject: Dual Bing Carbs Hookup |
Hi Trey,
I put the linkage arms to the inside between the bings and made a
linkage that connects both carbs at the linkage.
see link and note the solid tubes connected by a bent flex link, seen
between oil filler and alternator.
http://www.macsmachine.com/images/controllinkages/full/abingcarbscable.gif
The firewall linkage shown is the way I connected a A-820 friction
throttle with wire p/n 05-09436 control to my firewall mounted arms
each side and it allows the cable to push further without serious
bending of the larger throttle wire.
The collet fastener you see holding onto the throttle wire is called a
.078 wire grip and it allows you to
shorten the throttle wire and sheath p/n and attach the wire to the
linkage. p/n 05-16001 at aircraft spruce.
Then see the .065 music wire connection between the firewall mounted arm
and the carburetor. It uses the sheath as a guide
http://www.macsmachine.com/images/controllinkages/full/throttlewire.gif
The pieces I made look like these two assemblies. Connecting link
between carbs and wire connection. See link.
http://www.macsmachine.com/images/controllinkages/full/Binglinkdwg.gif
The following link is my enrichment connection and it retains two cables
as before. Some call it a choke, but it pulls both cables.
http://www.macsmachine.com/images/controllinkages/full/choke2to1clamp.gif
This is really simple and works really well without any springs for the
throttle arms to get in the way. Works like any Cessna throttle.
Hope this helps a bit,
Larry McFarland
Larry,
figure it out from the pictures. Can you give me a few details? Did
you use any of the Rotax hardware? Did you do the same thing for the
choke?
Trey
Posted: Tue Nov 11, 2008 8:21 am Post subject: Dual Bing Carbs Hookup |
Hi Larry,
Thanks for the individual pics with explanations. That really helps. One
last question (I hope). Where did you get the throttle arm that allows you
to push for power? Right now, my throttle arms are spring loaded to the idle
position (based on fact that the spring holds the arm against the idle set
screw) and any direct cable connection to the arm is a "pull to add power"
connection.
Trey
Posted: Tue Nov 11, 2008 9:04 am Post subject: Dual Bing Carbs Hookup |
Mine came that way too but I reversed them. I had to get new throttle
arms and a shorter starter. I would prefer, and it is aircraft
convention, to have springs pull throttle on as default if cable breaks
or slips.
gary
Trey Moran wrote:
Hi Larry,
One last question (I hope). Where did you get the throttle arm that
allows you to push for power? Right now, my throttle arms are spring
loaded to the idle position (based on fact that the spring holds the
arm against the idle set screw) and any direct cable connection to the
arm is a "pull to add power" connection.
Trey
frank.hinde(at)hp.com Guest
