ideaz1(at)sbcglobal.net Guest
Posted: Thu Nov 13, 2008 7:36 am Post subject: Cable Tensions for 601XL? |
Hi Juan,
I agree again with you regarding the maintenance issue of cables and I do
think this is a good reason for using pushrods as they are easy to check. A
little feel of the aileron on pre flight will tell you if there is something
loose or worn as you can feel the play. If a cable is loose from stretching
it may still have tension an you wont feel the difference. Are cable users
going to do a tension test every time they fly? I know I wouldn't so I
choose to make that problem not a possibility for me. Simple choice.
I do also believe (am I right?, I hope so.) that the bigger issue is balance
of the ailerons on this plane. As designed there is NO balancing of these
control surfaces. This drastically limits the operating speed ( and creates
most of the heavy feel of the ailerons). This web site has some very good
info and explanation on the subject PLEASE CHECK IT OUT!
http://www.theaerodrome.com/forum/aircraft/32996-balanced-ailerons.html
Ailerons are balanced in two main ways, with weight and air pressure. Both
methods require the hinge point to be somewhere behind the leading edge of
the control surface. The XL as designed is just forward of the leading edge
and therefore cannot be balanced as is. The simplest fix (if I may use that
term) is to extend the lower skin enough to add weights to it (look at a
Cessna, this is how my 150's ailerons are balanced). The result is that
control pressure remains the same throughout the speed range of the
aircraft. Another simple method (using pressure) would be to add spades to
the ailerons.
At least this should be food for your thoughts. At best you may get a
better(safer) aircraft.
Dirk
notsew_evets(at)frontiern Guest
Posted: Thu Nov 13, 2008 7:48 am Post subject: Cable Tensions for 601XL? |
I m thinking of a simple under the aileron mass balance.
There are a lot of airplanes that have a small hanging "spade" type
balance and it works. With the 601 ailerons being so light I m sure it
wouldn take much lead (Forward) of the hinge line to get that neutral
condition...
SW
Joe Kidd
Posted: Thu Nov 13, 2008 9:16 am Post subject: Cable Tensions for 601XL? |
Have you considered a casting instead of the milled part? You'd only need access to a CNC router to achieve that, then a geared head or knee mill to finish out the part. Would love to help you more but only have a South Bend 9A lathe and don't have a milling machine yet. However, I have done a bit of casting and have found that most regional casting compainies of fabrication shop's are more than up to such a challange.
JWS
Sent: Thursday, November 13, 2008 10:45:12 AM
Subject: Re: Cable Tensions for 601XL?
--> Zenith-List message posted by: "Sabrina" <chicago2paris(at)msn.com (chicago2paris(at)msn.com)>
Attached are renderings of a part. Given its size, is there anyone on the list with the capability of machining it to very close tolerances from a CATIA part file. I don't have cash, but I do have access to Engelhard silver to barter with. I am told that it would take a 5 axis CNC mill. I am hoping that it could be machined from a 530 x 600 x 180mm billet on a 3 axis mill white side up, flipped [quote][b]
ihab.awad(at)gmail.com Guest
Posted: Thu Nov 13, 2008 9:35 am Post subject: Cable Tensions for 601XL? |
On Thu, Nov 13, 2008 at 8:45 AM, Sabrina <chicago2paris(at)msn.com> wrote:
| Quote: | Attached are renderings of a part. Given its size, is there anyone on the list with the capability
What are your tolerances? Given that you don't mind the material,
would it be adequate to make it in a 3D printer out of plastic? Some
hint of what you need it for might give people a clue as to how they
could help -- like, is this a wind tunnel model?
Ihab
Ihab A.B. Awad, Palo Alto, CA
Posted: Thu Nov 13, 2008 10:37 am Post subject: Cable Tensions for 601XL? |
On Thu, Nov 13, 2008 at 10:05 AM, Sabrina <chicago2paris(at)msn.com> wrote:
| Quote: | If a 3D printer could punch out just 1, much less 120 of the attached Q parts, I would be forever grateful.
One thought could be to 3D print a *negative* of the part, then use it
as a mold for 120 fiberglass layups. I guess it depends on your
budget. Also, depending on your needs, 120 slabs of metal in a 3 meter
sphere could be way heavy; if you made them out of fiberglass then
stuck the borders together with epoxy or whatever, you could end up
with a lightweight yet strong part. As in, "Use the monocoque, Luke."
Ihab
tjs22t(at)verizon.net Guest
Posted: Thu Nov 13, 2008 10:55 am Post subject: Cable Tensions for 601XL? |
For some of the old timers on the list might I make a request: if you're going to leave a topic please change the subject line - the reason should be obvious.
thank you
jeff do not archive
>I was going to use the part to create a mold to make the "green" portion of the
| Quote: | rendering. 120 of those green portions assemble into a 3 meter sphere. The
gray portion was added to give a flat surface during milling of the top, green
surface. Tolerances are important but not vital. If a 3D printer could punch
JAPhillipsGA(at)aol.com Guest
Posted: Thu Nov 13, 2008 3:20 pm Post subject: Cable Tensions for 601XL? |
What strap? What modification? I have not heard of this. Please inform me. Bill
Get the Moviefone Toolbar. Showtimes, theaters, movie news &ir=http://toolbar.aol.com/moviefone/download.html?ncid=emlcntusdown00000001) [quote][b]
Posted: Thu Nov 13, 2008 3:23 pm Post subject: Cable Tensions for 601XL? |
It had to be connected to a covair motor, right?
Get the Moviefone Toolbar.00000075x1212774565x1200812037/aol?redir=http://toolbar.aol.com/moviefone/download.html?ncid=emlcntusdown00000001) [quote][b]
jaybannist(at)cs.com Guest
Posted: Thu Nov 13, 2008 3:48 pm Post subject: Cable Tensions for 601XL? |
Bill,
I'm assuming that this "strap" was added to versions earlier than mine. It is included in my drawings dated 08/05; page 6-T-3. It is Part No. 6T3-8, and is called a "Bent Strip". It is .040", 6061-T6, 20mm wide, 100mm long, with the ends bent up to a 95 deg angle to the base, the base being 62mm long. It is riveted to the Elevator Center Channel (6T3-2) with three A5 rivets; to the Upper Elevator Horn (6T3-4) base leg with an AS5 (stainless steel) rivet and to the base leg of the Lower Elevator Horn (6T3-5) with an AS5 rivet. Let me know if you need more information.
Jay in Dallas
hills(at)sunflower.com Guest
Posted: Thu Nov 13, 2008 4:11 pm Post subject: Cable Tensions for 601XL? |
Actually, it was a new prop, it broke off after 2 hours of operation,
A manufactures defect caused it to flutter (for a while) then fatigue and
break
Roger
Flydog1966(at)aol.com Guest
Posted: Thu Nov 13, 2008 4:55 pm Post subject: Cable Tensions for 601XL? |
OK, OK, help me get off the Zenith list and onto the 701 list!
The problem I'm having is I click on the list I'm interested in,I get the verification e-mail where I'm supposed to click on the link. Problem is it is not bold? or blue? like other links I've seen. I click on it anyway, and nothing happens. Yes,"disable links" is "off"
Phil
In a message dated 11/13/2008 7:12:49 P.M. Eastern Standard Time, hills(at)sunflower.com writes:
[quote]--> Zenith-List message posted by: "Roger & Lina Hill" <hills(at)sunflower.com>
break
Roger
-----Original Message-----
[mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Juan Vega
Sent: Thursday, November 13, 2008 8:13 AM
To: zenith-list(at)matronics.com; zenith-list(at)matronics.com
Subject: RE: Re: Cable Tensions for 601XL?
--> Zenith-List message posted by: Juan Vega <amyvega2005(at)earthlink.net>
next time balance the prop, people tend to forget that little part.
jeyoung65(at)aol.com Guest
Posted: Thu Nov 13, 2008 5:21 pm Post subject: Cable Tensions for 601XL? |
Noo to worry, in the 1950 we were going to put it in aircrafts.
Posted: Fri Nov 14, 2008 1:21 pm Post subject: Cable Tensions for 601XL? |
Jay, thanks for the info. I finished my XL over three years ago and built the tail feathers back in '03 so I don't remember this. I need to check my plans and look to see if I did this mod. Thanks, Bill of Georgia
Get the Moviefone Toolbar. Showtimes, theaters, movie news & more!
