aaaron(at)tvp.com.au Guest
Posted: Thu Nov 13, 2008 11:19 pm Post subject: Prestolite vs B&C |
After going to a lot of trouble to get the weight of my Mustang down I'm running out of options to get my CG further forward. The only solution I can think of is taking off my B&C starter and re-installing the original Prestolite starter which I guess weighs about 10-15lbs more than the B&C. Assuming it will fit in my cowling, are there any major disadvantages (advantages?) in using the Prestolite. Thanks. Allan
nuckolls.bob(at)cox.net Guest
Posted: Fri Nov 14, 2008 7:25 am Post subject: Prestolite vs B&C |
At 06:17 PM 11/14/2008 +1100, you wrote:
| Quote: | After going to a lot of trouble to get the weight of my Mustang down I'm
They're certainly a known quantity. Tho shalt
not fly a tail-heavy airplane lest ye discover
that you have but mere seconds to regret it.
A guy has to do what a guy has to do.
What airplane are you working with and what
combination of installation decisions painted
you into this corner?
peter(at)sportingaero.com Guest
Posted: Fri Nov 14, 2008 9:35 am Post subject: Prestolite vs B&C |
A guy called Mark Landoll (405-392-3847 from Sport Aviation) used to sell a harmonic dampener that bolted to the crankshaft and weighed 15+lb. It might help with the cg issues and also make the engine run more smoothly? I believe a B&C starter is around 9lb lighter than a Prestolite, but the cg of a Prestolite is a couple of inches further aft.
Peter
Posted: Fri Nov 14, 2008 12:05 pm Post subject: Prestolite vs B&C |
Bob, it's a Mustang II. The CG is within the allowable range as long as
I manage my fuel properly and don't carry any meaningful baggage.
However, I suspect the rear CG is making my handling on landing more
difficult. As for the combination of decisions .. I bought the plane as
a part completed project with wet wings (rather than a single forward
mounted fuel tank). I've relocated the battery to the firewall (using an
odyssey PC625 - I might be able to add a second battery there or maybe a
heavier one but really like the odyssey). I have a CS prop (a fair bit
more weight forward). The only thing I regret is making a slick and
very lightweight carbon fibre cowling whereas I could have made a much
cheaper and heavier fibreglass cowl:)
Allan
Allan
ainut(at)hiwaay.net Guest
Posted: Fri Nov 14, 2008 12:28 pm Post subject: Prestolite vs B&C |
Posted: Fri Nov 14, 2008 6:17 pm Post subject: Prestolite vs B&C |
Pretty good idea, and he also sells a simple steel ring of about the
same weight that's a lot less expensive than the damper (had one on my
1st RV-4).
BTW, if you need a Prestolite, I think I've got one on the shelf. Email
me off list & I'll try to come up with a price.
Charlie
Peter
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Fri Nov 14, 2008 7:42 pm Post subject: Prestolite vs B&C |
In a message dated 11/14/2008 1:21:17 A.M. Central Standard Time, aaaron(at)tvp.com.au writes:
| Quote: | | The only solution I can think of is taking off my B&C starter and re-installing the original Prestolite starter which I guess weighs about 10-15lbs more than the B&C. |
I replaced a Delco starter (similar to Prestolite if not the same thing) with a Sky-tec which really screwed up the W&B on my O-320/wood prop RV-6A exactly as you describe. After hearing many recommendations on the RV-list and elsewhere over the years, I added a Landoll Ring (a little over $100) to my ring gear to balance things back out, but will need to get everything dynamically balanced before I know the full effects of the Ring.
Copied from the Yeller Pages:
MARK LANDOLL 405-392-3847 405-685-0239 landollskydoll2001(at)yahoo.com ([email]%20landollskydoll2001(at)yahoo.com[/email]) STARTERS, MASS/DAMPING RINGS, ALTERNATORS
Mark Phillips
Columbia, TN
http://websites.expercraft.com/n51pw/
_________________ From The PossumWorks... |
Posted: Fri Nov 14, 2008 9:22 pm Post subject: Prestolite vs B&C |
