silverbirch1(at)netzero.n Guest
Posted: Wed Nov 12, 2008 2:30 pm Post subject: Zenith750-List Digest: 3 Msgs - 11/11/08 |
Stefan, -- I am building a CH750 from a kit. I have built on the horizontal stabilizer. In fitting the skin I found that the cutouts for the front brackets were about 10mm too far apart. They need to be trimmed inboard about 4mm each to fit over the front brackets.
I have also built up the elevator and trim tab. The manual discusses where to drill and mount the horn angle (75T3-6) in the elevator skeleton section (75-TA3), page 6. The exact location of the horn angle on the spar is critical since it must be flush with the upper horn (75T3-7) and lower horn (75TA- . The upper and lower horns are predrilled. If the horn angle is already drilled to A5, as instructed, there is little room for adjustment when attaching the elevator horns. The horns should likely be clecoed to the skeleton and the horn angle positioned before the horn angle is drilled, at least to A5 size.
Thank you for your web site Stefan.
_____________________________________________________________
Compete with the big boys. Click here to find products to benefit your business.
| | - The Matronics Zenith750-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Zenith750-List |
Stefan
Posted: Fri Nov 14, 2008 5:21 pm Post subject: Re: CH750 kit |
Appreciate the feedback. There are some issues with the current manual. Will have a correction page up on the website tonight.
Stefan
