hurstkr(at)redzone.com.au Guest
Posted: Mon Nov 17, 2008 3:55 am Post subject: Elevator Trim |
Just wondering if anybody has installed the trim wheel available at
www.PerihelionDesign.com/moreproducts.htm second item down the page.
If so, would be interested to know how you have found it.
This device turns the electric MAC elevator trim from a time based control
to a positional control like in Cessnas etc.
Cheers
Kingsley in Oz
Posted: Mon Nov 17, 2008 4:12 am Post subject: Elevator Trim |
Kingsley Hurst wrote:
<hurstkr(at)redzone.com.au>
control to a positional control like in Cessnas etc.
Cheers
Kingsley in Oz
Sounds like a very good plan,Kingsley. The MAC/Europa trim control is
very fierce.
Graham
Posted: Mon Nov 17, 2008 4:35 am Post subject: Elevator Trim |
| Quote: | Sounds like a very good plan,Kingsley. The MAC/Europa trim control is very
fierce.
Graham
Yes Graham, it reads good but I don't yet know the physical size of it or
it's cost.
I would prefer the wheel to the standard set-up not that I am saying there
is anything wrong with the latter. . . I already have it installed !
Hope you're keeping well Ole mate!
Kingsley
paul.the.aviator(at)gmail Guest
Posted: Mon Nov 17, 2008 5:04 am Post subject: Elevator Trim |
Hi Kingsley,
I can echo Grahams comment about the trim, but I approached the
problem a little differently. Matt Dralle, the guy who runs this
forum sells a small device that allows you to adjust the speed of the
MAC servo. It works really nicely and I can recommend it.
Regards, Paul
Posted: Mon Nov 17, 2008 9:47 am Post subject: Elevator Trim |
Hi Kingsley
Here is another interesting item that would probably work on a Europa:
http://www.steinair.com/trim.htm
Ron Parigoris
frans(at)paardnatuurlijk. Guest
malannx(at)bigpond.com Guest
Posted: Tue Nov 18, 2008 3:37 pm Post subject: Elevator Trim |
| Quote: | <hurstkr(at)redzone.com.au (hurstkr(at)redzone.com.au)>
Cheers
Kingsley in Oz
I would endorse the 3rd product down which I believe is in the trim wheel product.
I have one on my Esqual and the finesse of control is brilliant. It will adjust the trim that finely that you can hardly see the trim tab move. Before fitting it was nearly impossible to set the trim accurately as the motor would overrun past the required setting. I also use the last products on the page to control heater vents-again brilliant.
Malcolm Ferguson Esqual VH-ECO
