		herbgh(at)nctc.com Guest
				 Posted: Sun Nov 16, 2008 10:03 am    Post subject: Performance of the mark III with 912 or   jabiru? |
				Jerry
      Seems that the Titan cannot run a long enough prop to make the
 912 a good alternative?   Basically...Jabs do well on clean planes.
 titans,Sonex etc.....Redriven 912's  are well suited to any plane
 where they can swing a long and more efficient prop.. Herb
    ps   a Jab is absolutely unsuited to a Kolb MkIII or Cobra...
 At 11:45 AM 11/16/2008, you wrote:
  	  | Quote: | 	 		  Rick,
 I appreciate your informed input.  I can't speak for Jabs/Rotax
 4-cycle engines on Kolbs, but I can on Titans.  The arguments from
 both sides, I've found, change nobody's mind, typically generating
 more heat than light.  That said, I had both a Jab 2200 and a 3300
 on my Titan and found performance comparable to reported performance
 of comparable 912s (of course the 100 hp 912 had fewer horses than
 the 128 hp Jab), and had slightly less fuel burn.  Every sport pilot
 here in Madera flies behind/in front of a Jab, with one also flying
 behind a 912S.  I could be a little biased, I've owned five Jab
 engines, and if buying another engine, that's prolly what I'd buy
 again, for various reasons, but I wouldn't hesitate to own a Rotax
 either.  For sure, very early Jabs had teething problems and didn't
 produce near the power claimed, but that was long ago and far, far
 in the past.  And, none of us have had to land out because of an
 engine problem.
 Now, back to my cellar....
 Jerry
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Mon Nov 17, 2008 12:43 pm    Post subject: Performance of the mark III with 912 or   jabiru? |
				At 07:01 AM 11/17/08 -0800, you wrote:
 Jerry,
 There was nothing imprecise or unqualified about my statement, I did my
 research very well before I decided which engine to put on my Kolb.  When
 someone asks a question, I give them good information in a very clear and
 direct manner.   Maybe you did not want to hear what I had to say, but my
 information was not unqualified or imprecise...
 Mike,
 You are not precise.  From before:
 "The 912 is a better engine on a Kolb, PERIOD.  If you ended up with the
 inferior Jabiru on your Kolb, then I'm sorry for you, but that is no reason
 to try to get others to make the same mistake."
 You used the word "Kolb" and the implication is that nothing but a 912 is a
 good engine.  That rules out all lower hp Rotax and/or any other engine
 mounted on a Kolb and this implies that a lot us who fly Kolbs are using
 inferior engines.  You may not want to hear this, but I really enjoy flying
 my Kolb FireFly with out a 912 mounted on it.
 Fly safe!
 Jack B. Hart FF004
 Winchester, IN
				 Posted: Mon Nov 17, 2008 3:09 pm    Post subject: Performance of the mark III with 912 or   jabiru? |
				Now that we've beat that one to death.... back to SEAFOAM!
 BB, puny 3 cylinder suzuki, redrive  (and it actually flies!)
 On 17, Nov 2008, at 3:43 PM, Jack B. Hart wrote:
  <jbhart(at)onlyinternet.net>
 > Jerry,
 > did my
  Kolb.  When
  clear and
  but my
  Mike,
  with the
  no reason
  912 is a
  engine
  using
  enjoy flying
  Fly safe!
  Jack B. Hart FF004
  Winchester, IN
