Tach Question
Troy Maynor
PostPosted: Mon Nov 17, 2008 4:50 pm    Post subject: Tach Question Reply with quote
Hi Folks,
Anyone ever hook up the recommended tach that goes with a Rotax 912 in
parallel with one that's part of an engine monitor? My panel was built and
wired a few years ago with the Mitchell tach in addition to an Audio Flight
Avionic engine monitoring system. I am now wiring the engine to firewall and
want to use both. Do I need diodes or something?
Troy Maynor
N120EU Europa Monowheel Classic
Left to finish:
Seats, engine install underway, some wiring.
Weaverville, NC USA
winmail.dat
 Filename:  winmail.dat
 Filesize:  1.75 KB
 Downloaded:  248 Time(s)
craigb(at)onthenet.com.au
PostPosted: Tue Nov 18, 2008 1:11 am    Post subject: Tach Question Reply with quote
A lot of the new tachs are able to work happily from an inductive pickup
clipped to or wrapped around the HT cables, I have one that is so sensitive
you dont even need
the pickup touching the HT lead, if it is one of a simmilar sensitivity you
may find it works
ok if you just heat shrink or tape the pickup parallel to the one you have
already
have. other than that i cant see a reason not to splice it in.
craig
