Guy Buchanan
Posted: Tue Nov 18, 2008 3:58 pm Post subject: A Fun Flight |
All,
We've been having the usually dreaded Santa Ana winds the
last two days, with winds out of the east (offshore) blowing about
20-40mph. While it makes great weather for burning mobile homes, it
also, the day after, leaves us with 50 - 100 mile visibility under
clear skies and calm winds. The visibility is a particular treat,
since we normally have 5-10 mile visibility in haze due to the warm
marine weather that makes San Diego so popular.
Departing Ramona with no particular destination in mind I
headed north to visit the east LA basin. When the smog's blown out
after a Santa Ana it's a beautiful area, ringed by mountains, 11k' to
the north and 10k' to the east. I decided I'd go to Hemet to check
the restaurant that fairly recently re-opened. Traffic was
non-existent, but I flew at 4500' since I was flying alone.
Despite the warm weather I had a cup of chili and lemonade
for lunch, served by a singing waitress. (Bengals - "All Over the
Place") It cost all of $5, the cheapest flying lunch I've ever had.
(Lessee, $5 + 1.5h (at) $67/hr = $105.50. Perfect!) Departing Hemet I
thought, just for grins, I might see if there were any climbers on
10.8k' San Jacinto: full throttle, hold it at 6200 rpm, lean with
altitude, look for thermals and ridge lift, and the little beezer 582
climbed right up to 11k'. Sure enough there was one hiker on the peak
who offered a friendly wave. From my vantage at 11k' I could see all
the way from Yuma to Edwards AFB to the ocean. Magnificent. It was so
nice I flew all the way back to Ramona at 10.5k' enjoying the iPod in
perfectly smooth, 60 degree, air. As is typical with the 582, I
slam-dunked the descent to keep the EGT's in line. I learned a new
trick, too. The Garmin Pilot III gps gives the vertical speed to the
waypoint. I found I could maintain a perfect glide-slope if I kept
the vertical speed constant. (Easier said than done.)
No I didn't take any pictures. The problem is that they
never come out as good as Michel's. Maybe next time.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Tue Nov 18, 2008 6:34 pm Post subject: Re: A Fun Flight |
Guy, that sounds like a fun time. You mention leaning as you climbed. do you have the Arctic Sparrow cockpit adjustable needles?
Also can you Tell more about the slam dunk method of descending to keep the EGT's in line?
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Guy Buchanan
Posted: Wed Nov 19, 2008 8:23 am Post subject: A Fun Flight |
At 06:34 PM 11/18/2008, you wrote:
| Quote: | You mention leaning as you climbed. do you have the Arctic Sparrow
No, I have the HACman system that varies the float bowl
pressure to achieve moderate leaning. I like it a lot.
| Quote: | Also can you Tell more about the slam dunk method of descending to
With the HACman system you install rich mains, to give you
something to lean off. I run 180's here in San Diego. The mid range
is kept as-is so when you go moderately down hill you end up in the
mid-range jets with the prop pushing the engine and therefore very
lean. The only way to go down hill without getting too lean is to
either go slow, or descend slowly, or pull the throttle way back and
drop like a rock. Usually I do shallow controlled descents, but when
I'm trying to stay with my 912 buddies, or the view is pretty, I
stair-step down, dropping fast near idle, the levelling at cruise
throttle. It drives them crazy!
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
Tom Jones
Posted: Wed Nov 19, 2008 11:50 am Post subject: Re: A Fun Flight |
| Quote: | With the HACman system you install rich mains, to give you
Guy Buchanan |
Thanks for the reply Guy. I have the adjustable "Sparrow needles" and am still learning how to use them to keep the EGT's under control in a descent with partial power.
It is easy...for me anyhow...to get confused and forget how many turns on the needle adjustments I have made then which way to turn the knobs to correct a rough engine when I get it out of wack.
Classic IV
Ellensburg, WA |
gary.algate(at)sandvik.co Guest
Posted: Wed Nov 19, 2008 2:42 pm Post subject: A Fun Flight |
Just for interest sake the IVO In-Flight adjustable prop also gives you good control over EGT's.
By coarsing up in cruise you can lower the EGT's significantly and also by going to a fine pitch in descent helps lower EGT's
Gary Algate
Classic4 Jab2200A
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
"Tom Jones" <nahsikhs(at)elltel.net>
Sent by: owner-kitfox-list-server(at)matronics.com
20/11/2008 06:26 AM
Please respond to
kitfox-list(at)matronics.com To
kitfox-list(at)matronics.com cc
Subject
Re: A Fun Flight
--> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net>
> Guy Buchanan
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p 15170#215170
-Matt Dralle, List Admin.
paul(at)eucleides.com Guest
Posted: Wed Nov 19, 2008 4:01 pm Post subject: A Fun Flight |
On Wed, November 19, 2008 8:12 am, Guy Buchanan wrote:
A prop clutch has been mentioned a few times on the list here. Wouldn't that solve
this problem and also make less engine shaking when you shut down too?
With a clutch on the prop it wouldn't drive the engine so lubrication would still be
maintained correctly.
Just a thought. Id like to know.
Guy Buchanan
San Diego, CA
Paul A. Franz, P.E.
PAF Consulting Engineers
Office 425.440.9505
Cell 425.241.1618
Guy Buchanan
Posted: Wed Nov 19, 2008 7:26 pm Post subject: A Fun Flight |
At 04:01 PM 11/19/2008, you wrote:
| Quote: | With a clutch on the prop it wouldn't drive the engine so
The clutch is strictly centrifugal. Any time the engine's
above 2700 rpm it's locked solid, regardless of whether the engine's
doing the pushing or the prop. In order to get it to disengage in the
air you have to slow to below about 50 mph, then it will disengage
and you can descend with the engine at idle. I try not to do this
because I worry about the instantaneous heating associated with
re-engagement, when the engine rpm doesn't match the prop rpm very well.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
Posted: Wed Nov 19, 2008 9:18 pm Post subject: A Fun Flight |
On Wed, November 19, 2008 5:48 pm, Guy Buchanan wrote:
I didn't know that. I thought it was a dog and pawl setup. Anyway, it sounds to me as
long as the rpm difference is less than 2700 rpm then you'd be OK as apparently that's
what it's designed for. So, as an example, assume you slowed the engine and prop to
less than 2700 rpm so the clutch would disengage then let the engine go to idle, then
the resume descent then the prop rpm might go over 2700 rpm but wouldn't go so fast
that the tips went supersonic. You'd really hear that. You could calculate that rpm
given the diameter and assume that the speed of sound is 1100 fps.
Supersonic RPM = (1100 FPS * 60 Sec/Min) / (Dia [FT] * PI)
then say you had a 68" dia prop,
Supersonic RPM = (1100 * 60) / ((68/12) * 3.14159)
= 3707 RPM
So, it would seem to me that as soon as you hit the throttle, the engine would not
engage the clutch until something just below 2700 rpm and the prop would not be going
more than 1000 rpm or so faster than that. You'd know for sure it was supersonic by
the really loud beating noise that happens when the prop tips go supersonic. You'd be
safe since you know the rpm difference can be 2700 as that is what you have when you
start the engine to begin with. Prop is going zero rpm and the engine gets close to
2700 rpm when the centrifugal clutch engages and that's apparently the design so I
don't think you'd have to worry about re-engaging the clutch when the rpm difference
is that low, albeit in this case the prop is going faster than the engine rather than
the engine going faster than the prop as in the case of start up. (Whew, long
sentence, should break it up)
My point is, that if you release the clutch in flight then re-engage, the load on the
clutch isn't going to be nearly as high as it is at start-up.
It would bother me to have the prop disengaged from the engine in flight because then
you're depending on the starter to work in case the engine dies and the windmilling
prop would be no assistance what-so-ever.
So, if you don't do your technique of descending in steps, what is the maximum descent
rate you can have to stay within recommended EGT and Cyl Hd temperatures at some low
power setting such as 25%? I could live with 1000 fpm descent fine and even 500 fpm
would be workable given the relatively low ground speed.
Some time back, actually many years ago, there was a debate about using pre-mix vs
auto oil injection. I thought that the auto oil injection was rpm dependent vs air
flow so that this effect would be automatically compensated for. Apparently not
because the EGT still is rising too high and the only way to control that is by adding
excess fuel. But maybe, when the engine isn't under load, the allowable EGT can be a
little higher. You're probably saying "not with my pistons!"
Paul A. Franz, P.E.
Office 425.440.9505
Cell 425.241.1618
Guy Buchanan
Posted: Thu Nov 20, 2008 9:17 am Post subject: A Fun Flight |
At 09:18 PM 11/19/2008, you wrote:
| Quote: | My point is, that if you release the clutch in flight then
Your analysis is accurate as far as it goes, but there is a
potentially significant difference between the two cases. In flight
the prop is "loaded"; meaning it is "mechanically" connected to a
fast moving air stream. It will resist any variation from it's
equilibrium rpm. When you're on the ground there is no load at idle
and little load at, say, 3000 rpm. I have never quantified the
difference so I avoid testing in that regime.
| Quote: | It would bother me to have the prop disengaged from the engine in
flight because then
the windmilling
You are anyway. With the 3:1 gearing and the wimpy Warp drive blades
you'd have to loose all compression to turn the engine with the prop.
I think there are several in the list who have shut down in flight
and discovered this.
| Quote: | So, if you don't do your technique of descending in steps, what is
the maximum descent
and even 500 fpm
I think I can do around 400-500 fpm, but it's a cruise speed descent
and slow relative to my fly-mates.
| Quote: | I thought that the auto oil injection was rpm dependent vs air
It is, but not by much. The main variation is that the oil injection
reduces dramatically at idle. I've never seen the curve, but that's
what I've been told.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
Lynn Matteson
Posted: Fri Nov 21, 2008 7:15 am Post subject: A Fun Flight |
This is comparing apples with icicles, but just for kicks I shut my
newly rebuilt engine (I mention this because it was still tight from
the rebuild) off at a good altitude, and it wouldn't stop the prop,
so I pointed the plane up until it did stop. Then I pointed it down
to see if the wind would crank it over...it didn't, and I was not
about to point it any more down or for very much longer, so I engaged
the starter for the restart. Now this is a direct-drive engine, so
the geared engines will take even more effort from the wind to get
them to turn over. So we're comparing a stiff direct drive with a
broken in geared drive, so there's no comparison, just food for thought.
Lynn Matteson
Jabiru 2200, 591hrs
Sensenich 62x46
flying again after rebuild, and new Electroair direct-fire ignition
system
On Nov 20, 2008, at 12:09 PM, Guy Buchanan wrote:
blades you'd have to loose all compression to turn the engine with
the prop. I think there are several in the list who have shut down
in flight and discovered this.
Guy Buchanan
San Diego, CA
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Tom Jones
Posted: Fri Nov 21, 2008 7:54 am Post subject: Re: A Fun Flight |
At 45 mph on the trailer my prop rotates slowly. It stops for a few seconds while the compression is evidently overcome then rotates and stops again for a few seconds on the next compression etc. 503 Rotax 3:1 gear box, 72 inch warp drive 2 blade prop. I tie a rope to it to prevent the rotation.
Classic IV
Ellensburg, WA |
Lynn Matteson
Posted: Fri Nov 21, 2008 8:16 am Post subject: A Fun Flight |
You might consider getting new piston rings, Tom....just kidding. : )
Lynn Matteson
Jabiru 2200, 591hrs
Sensenich 62x46
system
On Nov 21, 2008, at 10:54 AM, Tom Jones wrote:
I know not may 503's on a kitfox, not enough power.
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p 15544#215544
N369LM |
matronics(at)bob.brennan. Guest
Posted: Fri Nov 21, 2008 8:44 am Post subject: A Fun Flight |
I have the same thing happen when I trailer my KF2. The only problem for me
is that the clearance on my barn door [erstwhile hanger] isn't enough if one
blade is up, so I have to do a pre-hanger check lest I need to explain to my
insurance company how I had a prop strike on a barn door...
Also pre-trailer inspection includes mags OFF, throttle closed, and fuel
off; unless you want to start playing tug-of-war, tow-vehicle vs airplane,
in traffic!
Bob Brennan - N717GB
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
hlang(at)bluewin.ch Guest
Posted: Sat Nov 22, 2008 1:01 am Post subject: A Fun Flight |
Hello all
Just to mention my own experience: Kitfox IV with 582 and 3:1 gear, switching off the engine and descending with 60 mph does turn the prop, but very slowly.
Heinz Lang
HB-YFS
