		saolesen(at)sirentel.net Guest
				 Posted: Thu Nov 20, 2008 9:10 am    Post subject: Control surface balance |
				I've got my wings on and hopefully the tail will go on this
 weekend.  I'm puzzled over the lack of information on the balancing
 of the control surfaces.  Other than the max/min deflection numbers
 and what I assume are the torque values  in the final assembly
 section  I found nothing that tells me how to determine if the
 flutter prone surfaces are properly balanced.   When I built my Long-
 EZ,  Burt Rutan was adamant  about how much each control surface
 should weigh and how to measure if it was in spec for balance.  This
 airplane is even faster and no mention of this subject.   Any help or
 illumination would be greatly appreciated.
 Sheldon Olesen
 N475PV -- not a project for long
		orchidman
  Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
				 Posted: Thu Nov 20, 2008 9:17 am    Post subject: Re: Control surface balance |
				I am at work so I can't get the page # but in the 8.5" x 11" pages you received with the rest of the plans, there is a page with a table that gives you the specific values for balancing your surfaces.
 The info you are asking about is in VAN's documentation, you just have to scrounge around.  If I recall, look just before or just after where the check out procedures are documented.
 You should also be able to find this reference in a previous thread probably about 3 months ago when Tim asked for the values.  Come to thing of it, he may have them posted now on his site also.
  _________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
		eagerlee
				 Posted: Thu Nov 20, 2008 2:40 pm    Post subject: Re: Control surface balance |
				I think there is a Vans Publication that deals with finishing and first flight checks. The maximums are published for all the control surfaces.
		orchidman
				 Posted: Fri Nov 21, 2008 8:24 am    Post subject: Re: Control surface balance |
				Sheldon,
 The specs are on page 2 "Flight Controls" of the RV-10 "Final Inspection and Flight Tests".
RV10 - # 40674
(N2GB Flying) |
