Sam
Posted: Fri Nov 21, 2008 5:08 am Post subject: Thermocouples connected to Dynon EGT CHT |
Please help me work through this.
1. I am reusing my old Westach EGT/CHT thermocouples, type J & K. They appear to be shielded and have 48" leads and will need new terminals.
2. I have a pre-fab TC harness from Stein Air (for Dynon), which is made from a non-copper wire. It seems to be pretty stiff. The EGT lead wires, under the sheath, are rust/yellow. The CHT wires are rust/white. This harness wire is way too long and needs to be shortened.
My questions are:
A. Due to the crazy airframe, it is not uncommon to pull the engine at annual inspection time. What would be the best connector to use? Could I use a D-sub? The connection to the D180 is a 25 pin D-sub.
B. For temperature accuracy purposes, would it be better to position the connector forward or aft of the firewall? The most convienient would be forward.
Thanks, in advance.
Sam
www.samhoskins.blogspot.com
_________________ Sam Hoskins
www.samhoskins.blogspot.com |
rampil
Posted: Fri Nov 21, 2008 8:58 am Post subject: Re: Thermocouples connected to Dynon EGT CHT |
Hi Sam,
If you are talking about a connector on the firewall, use a metal
circular connector i.e., AMP. Do not use a a db submini for three
reasons: They are not deep enough to pass through most firewalls,
they provide no thermal insulation and are not rated for constant hi temp environment, and they are not gas tight against carbon monoxide etc.
AMP makes special pins for TC connections, but I have never seen
anyone ever use them. Just live with the relatively tiny errors due to
the extra junction
mrspudandcompany(at)veriz Guest
Posted: Fri Nov 21, 2008 9:05 am Post subject: Thermocouples connected to Dynon EGT CHT |
[quote]My questions are:
Thanks, in advance.
Sam
The 25 pin d-sub is a good choice. Use the ones with the crimped pins, since soldering of thermocouple wires is not recommended. You can use these forward of the firewall with very little degradation of accuracy. The important thing with using a nonthermocouple material connector is that both sides of the connector should be at the same temperature, otherwise greater error will be introduced. Roger[b]
nuckolls.bob(at)cox.net Guest
Posted: Sat Nov 22, 2008 8:42 am Post subject: Thermocouples connected to Dynon EGT CHT |
At 11:04 AM 11/21/2008, you wrote:
| Quote: | My questions are:
A d-sub with MACHINED crimped pins is fine.
http://www.aeroelectric.com/Pictures/Connectors/D-Subminature/D-Sub_20AWG_Pin.jpg
http://www.aeroelectric.com/Pictures/Connectors/D-Subminature/D-Sub_20AWG_Socket.jpg
http://www.aeroelectric.com/Pictures/Connectors/D-Subminature/D-Sub_4-quad-crimp.jpg
| Quote: | B. For temperature accuracy purposes, would it be better to
Forward is fine. Just don't mount the connector
THROUGH the firewall with an expectation of
maintaining firewall integrity. I'd recommend
you wrap the mated pair of connectors with silicone
self-fusing tape to help keep them clean in service.
These are NOT environmentally robust with respect
to dirt, oils, etc.
Alternatively, you could consider a mil-spec
connector like the MS3470 series. These can be
installed with the same crimp tool as the d-subs
if you manually position the pins in the tool.
But a mated set in low quantities will cost you
about $50. The d-subs wrapped with silicone tape
is the more economical.
Effects on thermocouple readings will be
small and insignificant.
( -Thomas Paine 1776- )
Iberplanes
Joined: 10 Dec 2007 Posts: 174 Location: Igualada - Barcelona - Spain
Posted: Sat Nov 22, 2008 10:16 am Post subject: Thermocouples connected to Dynon EGT CHT |
si claro. Si Marta me deja sacar fotos pues lo haré, sino no pasa nada. Rercuerda que no tengo ganas de crear problemas ni mucho menos lastimar sentimientos de esta gente, que es bastante trajico todo.
un abrazo
2008/11/21 rampil <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
| Quote: | --> AeroElectric-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
Hi Sam,
the extra junction
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=215559#215559
-Matt Dralle, List Admin.
ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
MS -
Alberto Martin
www.iberplanes.es
Zodiac 601 XL Builder
Serial: 6-7011
Tail Kit: Finished
Wings: Not Started
Fuselage: Ordered
Engine: Jabiru 3300
_________________ Alberto Martin
601 XL - Jabiru 3300
http://www.iberplanes.es
Igualada - Barcelona - Spain |
