Mozam
Posted: Fri Nov 21, 2008 1:33 pm Post subject: Dynon EFIS installation questons |
Guys/gals,
I am installing a Dynon D10A EFIS in my Yak. I know many of you have already done this, so may I ask for some help with the following:
-where did you put the remote compass?
-if you put it in the tail, how did you route the wiring from the cockpit area back thru the fuselage all the way to the tail?
-where did you put the OAT sensor?
-any other advice?
THANKS,
Steve Dalton
Posted: Mon Nov 24, 2008 8:56 am Post subject: Dynon EFIS installation questons |
I have installed one in a YAK-50 Steve, but not in my aircraft. Plan to
though, great unit. I think Tom Johnson and Doc did as well.
ANYWAY....With any flux valve, it is smart to locate it as far away from
the engine as possible. Hard iron causes what is called single cycle
errors. Further, anything that produces a magnetic field, such as a
generator, or even wire with electricity flowing through it produces
what is called "two cycle errors". Without boring you to death on the
details, the bottom line is that the further you put the "remote
compass" (which is in reality a flux valve) away from the above
described "bad things" the more accurate that little sucker is going to
be, and the easier job it will have of "self-nulling" these errors when
you perform the self-calibrate function.
If you pull the two fiberglass gap sealers at the fuselage side of the
horizontal stab, you can see a gap up high where the vertical stab
attaches. There is an area in there it will fit in. Aluminum is no
problem in this regard and although I would not want to put it in a
aluminum BOX for heavens sake, having some aluminum structure around is
no issue. You want to keep any steel screws away from it though if you
can. Use brass or even stainless steel for screws if you have to use
them. Of course, I am going a tad over-board here. In the aircraft I
am used to swinging, you can't have more than a degree of error before
it fails... But still, it never hurts to try and do it as best as
possible.
For the wiring, I made 90 degree L brackets, with an anchor nut riveted
on, then an ADEL clamp and then rivets that whole mess to the aircraft.
That was a lot of work. I am sure someone else might have a better way
than that.
Mark Bitterlich
N50YK
Mozam
Posted: Mon Nov 24, 2008 10:27 am Post subject: Re: Dynon EFIS installation questons |
Thanks Mark,
I think I'm going to mount the remote compass onto the factory built aluminum mounting bracket behind the backseater's head that Aerostar used to attach the ELT when they built the plane. The ELT has since been moved to below the baggage compartment and this leftover mounting bracket is perfect (level, STRONG and nothing magnetic around it). A couple rivets and it's done!
Also saves me from trying to fish the wire thru the aft fuselage and keep it away from the control cables. My big ass won't fit thru the baggage door to get in there to secure the wire!
Next question is the OAT probe. A couple guys have put it on top of the fuselage behind the canopy. My concern was the sun heating it up, but I'm told this location worked fine. Thoughts?
Thanks again
Steve
Posted: Mon Nov 24, 2008 11:18 am Post subject: Dynon EFIS installation questons |
Steve, I am hopefully confident that the location mentioned will work
just fine for you! These modern automatically compensated flux valves
are indeed amazing pieces of technology and will tolerate more than can
be imagined. However, mounting them down inside an actual instrument
panel is asking a lot, hence the remote flux valve they offer. I have
never done a 52, so I was not aware of your stated location for it. It
does really sound ideal! Rog on being big. Same here. I had to hire a
very small person, yank the seat, and give him a big shove.
I did not do the OAT probe Steve, sorry. As for the sun heating it up,
I have seen that happen myself on our EA-6B OAT probes, when sitting on
the deck... But once in the air, they all read perfectly. I doubt you
will have any problems, but my experience is limited in this regard to
military aircraft and not the YAK.
Mark
ReadeG(at)Cairnwood.com Guest
Posted: Mon Nov 24, 2008 11:33 am Post subject: Dynon EFIS installation questons |
Steve:
How about in one of the wheel wells? This location has worked well in
the IAR 823.
Reade Genzlinger
Cairnwood Cooperative Corporation
mailto:readeg(at)cairnwood.com
215.914.0370
Yak52w(at)aol.com Guest
Posted: Mon Nov 24, 2008 5:36 pm Post subject: Dynon EFIS installation questons |
I think the OAT probe actually plugs into the remote compass so you should consider putting it near there.
In a message dated 11/24/2008 2:34:25 P.M. Eastern Standard Time, ReadeG(at)Cairnwood.com writes:
Quote: | --> Yak-List message posted by: "Genzlinger, Reade" <ReadeG(at)Cairnwood.com>
Steve:
the IAR 823.
Reade Genzlinger
215.914.0370
I'm told this location worked fine. nbsp; sp; (And Get Some AWESOME FREE find you for -Matt Dralle, List es y - MATRONICS WEB FORUMS =========================
One site has it all. Your email accounts, your social networks, and the%26icid=aolcom40vanity%26ncid=emlcntaolcom00000001">AOL.com today![/b]
