lbgjb10
Posted: Sat Nov 22, 2008 1:42 pm Post subject: panel labeling |
Need to label my panel. Don't want to use any kind of 'stick' on labels--any suggestions and/or pictures?? thanks. lbb
_________________ Larry and Gayle N104LG |
bcondrey
Posted: Sat Nov 22, 2008 2:21 pm Post subject: Re: panel labeling |
Silk screen! I used the same vendor as Tim O. and it worked great. You'll see a lot of pictures on his site so I won't take up bandwidth with more. I also posted an "after action" report on here that you should be able to find with a search, but here are a few highlights.
- cost is nominal for a screen to be made. exact cost depends on type of frame and size. My recollection is that a couple years ago it was around $35 with an aluminum frame.
- you can email a variety of formats to the vendor and have the screen back in a week. I used .pdf since he couldn't deal with Visio.
- print the file to overhead viewfoils, cut apart and tape on to panel for test fitting. this allows you to "test drive" before commiting to a screen.
- you can use just about any type of ink including the $1 per bottle stuff if you clear coat. I went with an epoxy based ink (same stuff Tim used but in black) which is tough as nails when cured.
- if you purchase the solvent recommended for the type of ink it's really easy to just wipe off and try again if you aren't happy with the results.
Bob
RV-10 N442PM Flying
n801bh(at)netzero.com Guest
Posted: Sat Nov 22, 2008 7:26 pm Post subject: panel labeling |
I took my panel down to the local trophy engraving shop, set it up and had the nice lady look at what I was doing, I had the whole thing thought out and she made nice engraved labels for everything, scaled them to fit and it took about an hour. She gave me a bill for 75 bucks and I paid that and added a 50 dollar tip.. I considered it a great buy for a plane that costs tens of thousands of dollars..
Pics are at www.haaspowerair.com..
closeups in a video are at http://video.google.com/videoplay?docid=-7272451917550730841&hl=en
Ben Haas
N801BH
-- "lbgjb10" <lbgjb(at)gnt.net> wrote:
--> RV10-List message posted by: "lbgjb10" <lbgjb(at)gnt.net>
http://forums.matronics.com/viewtopic.php?p=215786#215786
[url=_blank]Click to find local singles for dating, romance and fun.[/url]
