lcfitt(at)sbcglobal.net Guest
Posted: Sat Nov 22, 2008 6:12 pm Post subject: Engine choice- O-200 or EJ 22 |
Chuck,
Don't be sorry. Welcome. Lots of informantion and lots of opinion.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL
Currently focusing on the Left Wing, Rudder Gap Seal Cuffs and Landing Gear
Fairing
Cmflyboy12(at)aol.com Guest
Posted: Sat Nov 22, 2008 6:16 pm Post subject: Engine choice- O-200 or EJ 22 |
Ok, I,m restoring a 108-3 flying station wagon with a 165 frankin on it stinson that is
One site has it all. Your email accounts, your social networks, and the things you lovm40vanity%26ncid=emlcntaolcom00000001">AOL.com today![/b]
Dick Maddux
Posted: Sun Nov 23, 2008 5:48 am Post subject: Engine choice- O-200 or EJ 22 |
Welcome aboard Chuck. Pretty flying up in West virginia !
Dick Maddux
Fox 4-1200
Pensacola,Fl
Check out smokin' hot deals on laptops, desktops and more from Dell. Shop Deals
Posted: Sun Nov 23, 2008 8:40 am Post subject: Engine choice- O-200 or EJ 22 |
thanks,yes it is. I got the chance to fly around Fl, during the SUN&FUN air show and it was a exper.
One site has it all. Your email accounts, your social networks, and the things=aolcom40vanity%26ncid=emlcntaolcom00000001">AOL.com today![/b]
Float Flyr
Posted: Sun Nov 23, 2008 9:52 am Post subject: Engine choice- O-200 or EJ 22 |
<<Snip>>
Hi
Subaru engine was created for cars.Continental O200 for airplanes.
I'm not so sure the above statement is 100% accurate.
There is no doubt the Continental is an aircraft engine...designed and built for aircraft. They are very light and reasonably easy to service. They have redundancy built in up the yin yang.
The Subaru engine as I read it was an aircraft engine that was modified for use in automobiles because of its reliability in Japanese war planes. Because it is a more modern design it is a bit more complex. Because it was modified to work in cars it is a bit heavier. Cars don't need redundancy or mags. All that can be undone, including the dual ignition and magneto drives. What you end up with is a reasonably high tech, reliable, aircraft engine... with a re-drive.
Nothing is perfect but the differences are minimal.
For ease of getting your toes back off the ground and into the sky, I figure it will be a lot faster, possibly cheaper to service the Conti.
Toss a coin (Only joking)
Noel Loveys
AME Intern, RPP
Kitfox III-A, 912 almost installed
Ivo IFA, Aerocet 1100 floats
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Sun Nov 23, 2008 10:02 am Post subject: Engine choice- O-200 or EJ 22 |
Lynn in my younger days I drove more junkyard specials than I can honestly
remember. Four cylinder and six cylinder cars that only occasionally ran on
all their cylinders was the order of the day. The funny thing is I can't
ever remember not getting where I wanted to go because of a breakdown on one
of those old beaters. All the problems I had were actually on newer more
expensive cars I owned.
I also have a fair bit of experience with outboard engines. Until recently
they were all multiple cylinder two stroke units. With them when a cylinder
refused to fire you might make it home on with a cylinder out but don't
count on it. Also when a two stroke cylinder goes dead you can count on
using a lot more gas to get home if the engine continues to run.
All the engine problems I've had with two stroke engines involved lack of
maintenance in replacing spark plugs except for the time I put a connecting
rod through a Mercury four cylinder 50 Hp two stroke outboard. That time I
was lucky the mate to it continued to operate perfectly.
Noel Loveys
AME Intern, RPP
Kitfox III-A
Float Flyr
Posted: Sun Nov 23, 2008 10:05 am Post subject: Engine choice- O-200 or EJ 22 |
Sorry Lynn I misread your post..
Corvair engines can also swap out a cylinder if needed... if you can find
one.
Noel
Kitfox III-A
occom
Posted: Sun Nov 23, 2008 10:45 am Post subject: Engine choice- O-200 or EJ 22 |
I think someone already addressed this myth. The subie engine is no more
related to aircraft than the corvair or original VW engine is. These legends
end up being repeated until they become accepted.
I keep on hearing how my BMW M/C engine is aircraft derived and that also is
false. Max Friz designed aircraft engines (inline) but designed the M/C
engine for that purpose. Nor is the BMW logo intended to look like a prop, a
legend that is very widely accepted even by many of their own dealers.
Car and for that matter M/C engines are intended to deliver on average about
30 % of their rated max. power and many go their entire lives never putting
out 100 %. Aircraft engines OTOH always are called on to deliver 100% and
seldom below 55%. That difference alone would cause a designer to make
vastly different motors even if weight and longevity and reliability were
not so different.
As far as the Subie engine coming from an aircraft, it doesn't seem likely
to me as all the engines I ever saw from japanese aircraft were inline or
radial copies of known engines and of a size and power far exceeding
anything a small car would require.
Not trying to start an arguement, and I'm sure the Subie engine and many
other car motors can be modified to make acceptable power for experimental
aircraft. But it's my opinion that they are not in any instance returning to
their roots.
KF IV, 582
MichaelGibbs(at)cox.net Guest
Posted: Sun Nov 23, 2008 11:17 am Post subject: Engine choice- O-200 or EJ 22 |
Dave sez:
Quote: |
The subie engine is no more related to aircraft than the corvair or
original VW engine is. These legends end up being repeated until
Yeah, you're probably right, Dave. I'm sure that FHI (which started
out as The Aircraft Research Laboratory in 1917 and by 1931 was
reorganized as Nakajima Aircraft Company, Ltd and soon became the
primary manufacturer of aircraft for Japan during World War II) hired
a bunch of guys who had never heard of airplanes to design their line
of automobile engines.
Disclaimers:
- Just kidding
- Who cares, the lineage has nothing to do with the here & now
- EVERYTHING in aviation is a compromise--there is no right solution
for everyone. Anyone who tells you there is, is wrong.
Mike G.
N728KF, Kitfox IV-1200 Speedster
Phoenix, AZ
aerobatics(at)aol.com Guest
Posted: Sun Nov 23, 2008 11:47 am Post subject: Engine choice- O-200 or EJ 22 |
this is fun.... ok ... can we agree that a turboprop is generally more
reliable than a piston.... and in the turbo prop world, the PT6 is
conciderd the most reliable of all turboprops that should make it very
reliable and it is...
but its heritage.... is ground based for the oil business... I could
be wrong but that's my understanding of the pt6 so lineage means? ))
Good is good....
maybe somebody will prove me wrong re the PT6 but I belive it to be
true...
gotta go fly my 582 BH kF sun is out!
Dave
occom
Posted: Sun Nov 23, 2008 12:15 pm Post subject: Engine choice- O-200 or EJ 22 |
Posted: Sun Nov 23, 2008 12:27 pm Post subject: Engine choice- O-200 or EJ 22 |
Dang it's hard to kill a topic that has wandered off in the weeds.
Mike G.
Phoenix, AZ
paul(at)eucleides.com Guest
Posted: Sun Nov 23, 2008 1:04 pm Post subject: Engine choice- O-200 or EJ 22 |
It's possibly a matter of semantics. It is true that the design life and functional
life (TBO) is much higher for the turbine, turbojet or turboprop than for a piston
engine. That doesn't imply anything to me about reliability. In other words, if you
have engine A with a TBO of X hours and engine B with a TBO of 10X hours, can you say
which one is more reliable? I don't think so.
Paul A. Franz
Aircraft/Engine/Prop - Merlin GT/Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
Float Flyr
Posted: Mon Nov 24, 2008 2:05 pm Post subject: Engine choice- O-200 or EJ 22 |
Because one of the factors in determining TBO is reliability I think you are
safe in inferring the turbine is more reliable all other things being
equal... Some of those things are over revving the engine, and hot
starts... either of those will destroy the turbine in seconds. And the
effects are cumulative so have to be logged.
Noel
Kitfox III-A
JetPilot
Posted: Tue Nov 25, 2008 10:08 am Post subject: Re: Engine choice- O-200 or EJ 22 |
It makes absolutely no difference if the Subaru was originally designed as an airplane engine 50 year ago or not. The reality is now that the Subuaru that the poster is thinking about using in his Kitfox is a CAR engine, designed and built to run in a car, not an airplane. Even IF it were true that some engines started life in aviation 50 years ago, the aviation engineering that were put into the engine would have long ago been taken out by an auto manufacturer. The modern Subaru engine parts were designed to be run in a car at around 20 % power for long periods, not at the long 100 % climbs and 70 % cruise power used in an airplane.
Bottom line, the history of the engine does not mean anything, the modern design is for a car, and you will have to do a lot of engineering to make it work at all in a plane, and chances are it will still probably never be reliable. Many people with a lot more talent and engineering resources than you have tried to make these engines reliable for aviation use and failed. It would be best to learn from their experiences.
Kolb MK-III Xtra, 912-S |
Posted: Tue Nov 25, 2008 1:16 pm Post subject: Engine choice- O-200 or EJ 22 |
In the case of the EJ22 rated at 130 HP maximum (at) sea level, then the cruise power
setting in the car is probably less than 10% of the maximum, since the car takes
around 12 HP to push it 60 mph on the level. But the engines in these cars last under
less that ideal operation with perhaps thousands of starts and stops and at low oil
temperature for 200,000 miles or more. That's probably more than 4000 hours of
operation since the average speed over the life is less than 50 mph.
In an airplane, the engine is nearly 100% of the time operated at ideal operating
temperature with preferred lubrication. It will more often be operated at 100% power
(sea level, WOT) and will be set to cruise at 65% to 80%. The engine in aircraft usage
will likely never be exposed to abuse such as over speed (operation in yellow and past
redline), and is equipped with more instrumentation to insure safe operation such as
cyl head temperature and EGT instrumentation. The operator will always observe the
tachometer whereas in a car, there is far more likelihood of abuse such as fouled air
cleaners, passing recommended oil change intervals limits and the over speeding the
engine.
Quote: | Bottom line, the history of the engine does not mean anything, the modern design is
I believe, that there is some debate, at least that I perceive in what reliability
means in terms of TBO. There are many factors that contribute to reliability including
redundancy and the design life of the required gear reduction units.
experiences.
The subject engine is the EJ22 but I think that given the success of a number of EA81
conversions that a 1000 hour TBO is realistic and that given electrical and fuel
system redundancies, the engine is, in fact, suitable for use in aircraft. There are
many installations where these engines have been used that have resulted in a
significant cost savings over Certified Aircraft Engines.
I would acknowledge that the redrives (reduction units) have the least known about
their reliability since the number built and the total number of hours of operation is
far less than for the engine.
Your point is well taken that you are assuming some design responsibility when
choosing this engine, especially as to creating reliable redundancies and the
selection of the redrive.
Paul A. Franz, P.E.
PAF Consulting Engineers
Office 425.440.9505
Cell 425.241.1618
Float Flyr
Posted: Wed Nov 26, 2008 9:49 am Post subject: Engine choice- O-200 or EJ 22 |
You have to admit there are a lot of them flying though... Subies, Mazda
Wankels and even Suzuki/Geo engines. I think I draw the line when I see B&S
engines but they are being tried too.
All aircraft engines are to an extent derated. That is why you get less
than 500 hp from a 500ci turbocharged engine. If I was going to use a Subie
I'd derate it by a good percentage and limit the rpm to no more than 5000.
You are right on the fact the engines are designed to be used in cars but
that particular application has to be just about the most punishing
application going. As you no doubt know highway driving is a lot easier on
a car than around town. To me is comes down to this what do I like better
1920's design and engineering... not to mention in some cases rebuilt parts
or Millenium engineering and production... except for the redundancy aspect
that's a no brainer. For the type of fluying most people do I think the
latter is not only sufficient but a good choice. However if you are the
pilot who ventures deep into the boonies then the redundancy of earlier
engines is the way to go.
That's why I could never suggest the use of automotive engines in certified
planes.
Noel
Kitfox III-A
