jpx(at)Qenesis.com Guest
Posted: Mon Nov 24, 2008 7:36 pm Post subject: Z13/8 Battery Contactor Failure |
A friend of mine noticed something when looking at my wiring diagram tonight.
If the battery contactor opens in flight, say due to the internal coil
failing, or the control wiring open circuiting, then the alternator
will be alive, but without the battery to stabilize the voltage.
That sounds to me like a bad thing. I expect I would know about it
immediately, due to a buzz in the intercom, but would I (or my wife)
recognize the fault in time to shut of the main switch before damage
is done ?
Will the overvoltage circuitry react well to this scenareo and open
the field drive soon enough ?
Obviously many aircraft are wired this way, and presumably, this is an
unlikely fault, but ...
Is there a way to improve on the design ?
Thanks !
Jeff Page
Dream Aircraft Tundra #10
Eric M. Jones
Posted: Tue Nov 25, 2008 8:20 am Post subject: Re: Z13/8 Battery Contactor Failure |
| Quote: | Obviously many aircraft are wired this way, and presumably, this is an
unlikely fault, but ...Is there a way to improve on the design ? |
Jeff,
Racecars use a mechanical battery switch. The FAA demands a "one-hand operable battery disconnect and this complies. Even though this may be difficult to arrange compared to a contactor, it is probably worth the effort. (Google: Flaming River Battery Switch).
"The problem with the world is that only the intelligent people want to be
smarter, and only the good people want to improve."
- Eolake Stobblehouse
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
nuckolls.bob(at)cox.net Guest
Posted: Tue Nov 25, 2008 9:29 am Post subject: Z13/8 Battery Contactor Failure |
At 09:35 PM 11/24/2008, you wrote:
When I revise the chapters on alternators and regulators, I'm
going to have to revise advice based on to-long and deeply-held
beliefs that the battery carries a major role in voltage stabilization
for a battery/alternator power system.
There IS a role for the battery but it's a more of a firewall
against (1) system collapse under large transient loads that cause
the alternator to "stall" and (2) mitigation of surge voltage
amplitude during large load dumps. This is pretty easy to
understand:
Consider that a battery needs 14.0 volts or so to take significant
charge. It delivers energy at 12.5 volts and below. So if the bus
is wiggling around between these two values (read alternator
ripple voltage) how much can the battery participate in smoothing
this perturbation? Not much. Battery ability to 'stabilize'
bus perturbations within the bounds of 12.5 to 14.0 volts is
nil.
| Quote: | That sounds to me like a bad thing. I expect I would know about it
is done ?
Loss of battery is not a recipe for over-stressed electro-
whizzies . . .
| Quote: | Will the overvoltage circuitry react well to this scenareo and open
Any source of 3-phase power rectified to produce DC power
has an inherent "ripple" or noise component on the order
of 5% of the DC component. A 14v alternator may be expected
to have a strong ripple voltage of 0.7 volts with lower energy
but higher voltage components consisting of harmonics and diode
switching transients.
The bible for crafting DC power generation systems for vehicles
is Mil-Std-704 which allows 3 volts pk-pk noise on 28v systems,
1.5 volts pk-pk noise on 14v systems. This is allowed because it
is EXPECTED from a normally operating alternator or generator. See
Figure 15 of . . .
http://www.aeroelectric.com/Reference_Docs/Mil-Specs/Mil-Std-704_excerpts.pdf
Okay, take these values a compare them with the battery's ability
to accept or deliver energy. That 1.5 volt, 'window' of compliance
described above is almost exactly the same as an expected pk-pk
noise value delivered by the alternator.
Here's a couple of 'scope traces taken from my dearly departed
Safari van a couple of years ago . . .
http://www.aeroelectric.com/Pictures/Curves/Safari_Bus_Noise_1.gif
http://www.aeroelectric.com/Pictures/Curves/Safari_Bus_Noise_2.gif
The trash on the bus is in keeping with expected performance
of the alternator as a potential noise source and the battery
as a wish-it-were-a-better-filter.
Doesn't need it. Electro-whizzies for aircraft are EXPECTED
to perform as advertised when powered from systems not unlike
that measured in the traces above and quantified in mil-std-704.
There are certified aircraft (including A36 Bonanza and B58
Baron) that have independent alternator and battery switches.
The alternators on these aircraft will come on line without
benefit of external battery. Further, the noise on the bus
is affected very little by the presence of a battery. Operation
without battery is not prohibited in the AFM.
Short answer: Don't loose any sleep over it.
