ideaz1(at)sbcglobal.net Guest
Posted: Tue Nov 25, 2008 12:28 pm Post subject: Lets look at the specs |
Per Juan Vega:
| Quote: | pull up the archives, i brought up the issue of VNE and Max manauvering speeds over one year ago, but the back room engineers ignored it.
Fly it and follow the specs. My guess is the guys flying and that augered in ignored the flight envelope of the aircraft. BUILD IT TO PLANS AND FLY IT TO SPECS.
Ok. The zenith website listssome specs for the XL and now the 650as:
Max cruise (at)sea level 138 mph
75% cruise (at)8000' 160 mph
VNE 180 mph
G load (ultimate) +/- 6 g
However when I received my plans the VNE is listed as 160 mph
this is an excerpt from the specs page:
Vigorous performance:
"My evaluation of cruise speed showed about 140 mph at 2800-2900 rpm, however, the company plans a different prop for Sport Pilot.
If we look at these numbers and keep in mind that part of testing a newly built aircraft is to prove these numbers, how many of you feel safe taking your XL up to 180 mph?
How about the g load testing. At +/- 6 that should mean a safe limit of +/- 4 (why doesn't zenith state this) with a 50% margin. would you feel safe at a +4g steep turn? A typical loop produces about 3.8 to 4 gs How about inverted pushing up at -4g?
How do we decide whether VNE is 160 or 180. if it's 160 what about this 75% cruise of 160.
I'm sorry but something is wrong here and we deserve factual answers, not this garbage expecting blind faith. I'm building my XL. I like almost everything about the design, but I will gladly sacrifice an extra 50lbs. of weight making it seriously strong. When the day comes that I fly it for the first time I want to know without reservation that it isn't coming apart, period.
Dirk Z
Gig Giacona
Posted: Tue Nov 25, 2008 1:13 pm Post subject: Re: Lets look at the specs |
[quote="ideaz1(at)sbcglobal.net"]Per Juan Vega:
VNE 180 mph
Dirk Z
That 160 (at) 8000' is TAS not IAS.
Ultimate means Ultimate
If you want factual answers regarding the accidents then you are going to have to wait until the FAA and NTSB finish the reports and then the answers still might not be there.
Even in certified aircraft there are accidents that don't get fully explained. In our situation there may not be a design issue that can be singled out. It might well be a repeatable building issue of the type that will be made by one out of x number of builders and it is at a point where the evidence of it doesn't remain after a crash. It all boils down to the fact that the FAA/NTSB/some random European aviation agency might not have an answer.
There is one FACT that we do know. There are lots of 601XLs out there flying there little hearts out and hundreds of them have not had a problem.
601XL Under Construction
Posted: Tue Nov 25, 2008 1:49 pm Post subject: Lets look at the specs |
Gig, the big number everyone keeps missing, is Max manauvering- only 103.
You cannot yank and bank at full gross over the Max manauvering. The rest is moot. G load is utility at predetermine weights again not an ecuse to fly at max speed at Max load and do 6 gs.
There are alot of short time piloits on here that I think fall in the trap thinking great 6 gs max load 1320 two dudes and full fuel , lets yank and bank. There are quite a few 601s flying and someone is bound to 1- do a crap job of keeping the mainentance up (cable tension and torquing)
2- build not to specs.
3- fly out of specs.
I gues what I am saying is build you plane to specs, and fly it to specs, and make sure you know the real limitations (e.i max gross at each speed factor).
EVEN AN EXTRA 300 L WHICH I FLY HAS A WEIGHT LIMIT AND FUEL LIMT FOR YANKING AND BANKING.
No conspiracies here in my book.
Lets move on.
Juan
Posted: Tue Nov 25, 2008 1:51 pm Post subject: Lets look at the specs |
Max Manauvering Speed is 103mph IAS. This is a differnt number than Vne,
everyone keeps missing that, i dont know why. There rest is moot.
Juan
bryanmmartin
Posted: Tue Nov 25, 2008 1:52 pm Post subject: Lets look at the specs |
I would feel quite save flying my 601 XL to 180 mph or pulling 4 Gs at
gross weight. I've done that in phase 1 testing. I've never pulled -4
gs, mainly because I don't have inverted fuel or oil systems installed
and don't particularly like standing on my head. The way the wing
attachments are designed, if they will take +4 g, there's no reason
they won't take -4. I don't have a G meter installed now so I would be
leery doing high G maneuvers, but pushing it to Vne in smooth air
wouldn't worry me much.
Vne is stated in CAS. When somebody states 75% cruise speed at 8,000
feet, you can assume they are talking about TAS. Under standard
conditions, 160 mph TAS at 8000 feet equates to 138 mph CAS, so you
are still a long way from the 160 mph Vne.
On Nov 25, 2008, at 3:18 PM, Dirk Zahtilla wrote:
VNE 180 mph
Dirk Z
_________________ --
Bryan Martin
do not archive. |
hills(at)sunflower.com Guest
Posted: Tue Nov 25, 2008 5:02 pm Post subject: Lets look at the specs |
Howdy all,
I called Zenith a year back to ask about how they determine the vne of their planes. I was told that the speed assigned was the speed that the
plane has been tested to in flight (at sea level), and not an actual “failure speed”, which they don’t have a way of determining and don’t test too.
Also, regarding the 6g design load, both Zenith and Sonex told me the same thing, the wings on the HD and the Sonex are designed to an ultimate of 9 g’s ,
So technically they are aerobatic category stressed, but for legal reasons they don’t state this in writing as they don’t want folks doing aerobatic maneuvers in them.
Note: The HD does stand for Heavy Duty.
I register my 601 HDS as “Utility” class after I swapped out the engine.
Roger
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Dirk Zahtilla
Sent: Tuesday, November 25, 2008 2:19 PM
Subject: Lets look at the specs
Per Juan Vega:
VNE 180 mph
[i]However [/i]when I received my plans the VNE is listed as 160 mph
[b]Vigorous performance[/b]:
Dirk Z
| Quote: | | http://www.matronics.com/contribution | 01234567890123
Gig Giacona
Posted: Wed Nov 26, 2008 7:15 am Post subject: Re: Lets look at the specs |
| hills(at)sunflower.com wrote: | Howdy all,
Roger
While you may have written Utility some where on the registration I doubt the FAA noticed or cared. Utility class is a Part 23 thing that really effects EX-HB not a bit.
Just writing utility on the registration doesn't make the plane any stronger.
