jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Tue Nov 25, 2008 3:39 pm Post subject: Airflow Performace - Throttle Cable & Purge Valve Contro |
Today while routing the throttle cable to our Airflow Performance servo, we just couldn't find any way the stock cable could be long enough. We have a vertical draft induction. After double and triple checking all positions were correct, we ordered a new cable from Van's. The throttle cable for the RV-7 is 3" longer (50.5") than the throttle cable for the RV-10 (47.5"). Has anyone else had this issue, am I missing something?
The next step is to route the cable to operate the fuel purge valve located on the top of the engine. I would appreciate seeing how others routed and connected this cable. Pictures would be very helpful.... I will most likely add a spring return to this control that would hold the valve open if the cable were to fail.
Thanks, Jason Kreidler
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
raddatz
Posted: Tue Nov 25, 2008 7:16 pm Post subject: Re: Airflow Performace - Throttle Cable & Purge Valve Co |
I have built a couple 10's and the throttle cable has been short every time, I always have to order the 50.5 also, please call Van's and brief them about the problem because I already have and the more people that bring it to the attention maybe they will change it.
Steve
