Lynn Matteson
Posted: Wed Nov 26, 2008 8:11 am Post subject: Kitfox mishap in Colorado |
Nobody seems to have mentioned the Kitfox that crash-landed in
Boulder, Colorado. I got the alert from Google a couple of days ago.
They said it was an engine problem that caused the pilot to put it
down...he wasn't hurt. Anybody near there know what kind of engine
problem, and what kind of engine?
Lynn Matteson
Jabiru 2200, 593hrs
Sensenich 62x46
flying again after rebuild, and new Electroair direct-fire ignition
system;
also building a new pair of snow skis
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
matronics(at)bob.brennan. Guest
Posted: Wed Nov 26, 2008 8:36 am Post subject: Kitfox mishap in Colorado |
"The propeller went in reverse, and he realized he couldn't stop the plane
before it went beyond the boundaries of the airport," Hauser said.
From
http://www.coloradodaily.com/news/2008/nov/24/plane-crash-reported-boulder-m
unicipal-airport/
Propeller went in reverse?? Maybe he used a car engine with 4-on-the-floor
and shifted wrong... [kidding of course]
Bob Brennan - N717GB
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
Lynn Matteson
Posted: Wed Nov 26, 2008 10:09 am Post subject: Kitfox mishap in Colorado |
Well, being that nobody was hurt, and we can have a little fun (with
this poor guy's mishap), I've already come to the conclusion that it
must've been a Rotax because none of you guys are mentioning it. : )
Hell, if it had been a "J" engine, you guys would be all over it. : )
Lynn Matteson
Jabiru 2200, 593hrs
Sensenich 62x46
system;
On Nov 26, 2008, at 11:29 AM, Bob Brennan wrote:
<matronics(at)bob.brennan.name>
the plane
From
boulder-m
unicipal-airport/
the-floor
Wrightsville Pa
N369LM |
Posted: Wed Nov 26, 2008 10:27 am Post subject: Kitfox mishap in Colorado |
Not that I have nothing better to do... But I like doing research in cases
like this. The best I can tell is that the pilot is from Guatamala, had just
bought the airplane and was flying it for the first time to another airport
where he was going to put it on a trailer and take it home. So no info as to
the registered owner or N number. There was only one Classic IV Kitfox
registered in that county and it is listed as Engine Type: reciprocating,
Make and Model: Rotax(all), whatever that means! Also apparently the pilot
left the scene very quickly with no comment, refusing treatment.
Again, no offense to the poor guy and his mishap, but I'm guessing it had
nothing to do with the airplane or the engine. Just my opinion[smirk] on a
day when I should be doing something more productive...[smirk again]
Wrightsville Pa
jdmcbean(at)kitfoxaircraf Guest
Posted: Wed Nov 26, 2008 11:11 am Post subject: Kitfox mishap in Colorado |
NSI with a CAP 140
Fox5flyer Guest
Michel
Posted: Wed Nov 26, 2008 12:02 pm Post subject: Kitfox mishap in Colorado |
| Quote: | From: Bob Brennan [matronics(at)bob.brennan.name]
When I got my heart attack in July and lost my pilot license, I was preparing my big annual trip to Belgium planned for the 6th of Sept. Then a Finnish friend told me he would come and pick me up with his homebuilt Europa plane. As September can close and I didn't hear from him; knowing he was already on an European tour, the news came in:
His propeller went into reverse as he took off from an Austrian airfield and crashed at the end of the runway. His plane bursted in flames and he made it but ... suffered severe third degree burns and lost an eye.
So yes, apparently those things can happen with in-flight pitch adjustable props.
.. and no, Lynn, it was surely not a Jabiru engine; we can't have variable pitch props.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 - flying sometimes as a PAX
Posted: Wed Nov 26, 2008 12:07 pm Post subject: Kitfox mishap in Colorado |
CAP stands for "Cockpit Adjustable Propeller" for those like me who have to
look it up.
Sounds like the first-time pilot may have adjusted the prop too flat for
takeoff? Can those props be feathered?
Wrightsville Pa
Lynn Matteson
Posted: Wed Nov 26, 2008 12:50 pm Post subject: Kitfox mishap in Colorado |
Good thing us "minorities" have thick skins, eh, D? : )
Lynn Matteson
Jabiru 2200, 593hrs
Sensenich 62x46
system;
On Nov 26, 2008, at 2:25 PM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
...or a soobie
D
N369LM |
Lynn Matteson
Posted: Wed Nov 26, 2008 1:07 pm Post subject: Kitfox mishap in Colorado |
Of all the repots that were posted in all the newspapers, there was
no mention of engines (other than "it failed") or of propellors...in-
flight adjustable or otherwise. Sounds like JD probably has the best
answer, as I would bet that the press has kept his phone busy trying
to find out all the "dirty laundry" on this incident, although all
the reports that Google came up with sound like a rehash of the same
old, same old....
Speaking of adjustable propellors....maybe the FAA made a good
decision barring us Sport Pilots from adjusting props, at least while
in the air, or even allowing us to have "automatic shift" props. I
can just hear their arguments: "Give 'em a twisted piece of wood, and
that's all they get! Those low-hour trainees will have all they can
do to wiggle the stick."
Wait a minute, Michel.....Sensenich now makes a ground-adjustable
prop for the Jabiru AND the Rotax. It's been out for a couple of
years now, so Sensenich tells me, although their website says (as of
August 2008) that this new prop is "in flight testing." I pointed
this out to a guy at their booth at Oshkosh, and he was slightly
chagrined at this news....he's in charge of the website. It
apparently uses composite blades that are centrifugally cast, if I
recall the blurb correctly.
Lynn Matteson
Jabiru 2200, 593hrs
Sensenich 62x46
system;
On Nov 26, 2008, at 3:01 PM, Michel Verheughe wrote:
| Quote: | > From: Bob Brennan [matronics(at)bob.brennan.name]
the news came in:
and lost an eye.
adjustable props.
... and no, Lynn, it was surely not a Jabiru engine; we can't have
Michel Verheughe
Norway
www.matronics.com/contribution</a>
List">http://www.matronics.com/Navigator?Kitfox-List</a>
forums.matronics.com</a>
</b></font></pre>
N369LM |
Posted: Wed Nov 26, 2008 1:21 pm Post subject: Kitfox mishap in Colorado |
Maybe I should elaborate a little..
Talked with the FAA yesterday.. It was a NSI with a CAP 140 IFA (In Flight
Adjustable) Prop.
Fox5flyer Guest
Posted: Wed Nov 26, 2008 2:05 pm Post subject: Kitfox mishap in Colorado |
In-Flight adjustable props are really no big deal, but it is one more
control function that is added to the normal mix of things that have to paid
attention to during critical phases of flight, especially during takeoff.
Take an inexperienced pilot, in an unfamiliar airplane, at an unfamiliar
airport, possibly having never used a cockpit adj prop before, you have a
recipe for a situation that can quickly get out of control. But, not
having all the facts in this case, we're just speculating and arm chair
quarter backing. The fortunate thing here is that he walked away from it
and there was no property or people damage, nor much left of that airplane!
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Lynn Matteson
Posted: Wed Nov 26, 2008 4:16 pm Post subject: Kitfox mishap in Colorado |
I'm a rookie...why would you have to adjust the pitch of the prop
during takeoff? Seems like you'd set it for takeoff and go, then
change it to cruise when you get there....no?
Lynn Matteson
Jabiru 2200, 593hrs
Sensenich 62x46
system;
On Nov 26, 2008, at 5:04 PM, fox5flyer wrote:
more control function that is added to the normal mix of things
that have to paid attention to during critical phases of flight,
especially during takeoff. Take an inexperienced pilot, in an
unfamiliar airplane, at an unfamiliar airport, possibly having
never used a cockpit adj prop before, you have a recipe for a
situation that can quickly get out of control. But, not having
from it and there was no property or people damage, nor much left
of that airplane!
Deke Morisse
N369LM |
MichaelGibbs(at)cox.net Guest
Posted: Wed Nov 26, 2008 5:32 pm Post subject: Kitfox mishap in Colorado |
Lynn sez:
| Quote: | I'm a rookie...why would you have to adjust the pitch of the prop
I had a Rotax 912S with an Ivo medium in-flight adjustable prop on my
model IV, Lynn. With no prop pitch indication you can't precisely
set the pitch for best takeoff power beforehand. If I ran it all the
way flat then added full power, the RPM would go too high, so I knew
I had to pull the pitch in a little bit from that point. After a
while you could get pretty close with cranking it all the way flat
then pressing the switch the other way and counting, "One thousand
one, one thousand two..."
That said, it wasn't unusual for me to be rolling (even though the
ground roll was very short) and tapping the switch up or down a
little to get takeoff RPM after fully opening the throttle. As your
speed picks up the RPM tends to go up a bit also, so I'd often tap it
back down to redline after establishing my initial climb.
The Ivo mechanism has stops that limit both the fine and coarse pitch
settings so it can't reverse or feather. Even if you had it all the
way flat or all the way coarse, with full throttle you'd still have a
significant amount of thrust happening. The NSI CAP hub had an
option for full reversing intended to simplify float-plane
maneuvering on the water. It had several mechanical and electrical
interlocks to prevent inadvertent reversing in flight but I suppose
if you were having a really, really bad day...
Mike G.
N728KF, Kitfox IV-1200 Speedster
Phoenix, AZ
paul(at)eucleides.com Guest
Posted: Wed Nov 26, 2008 5:34 pm Post subject: Kitfox mishap in Colorado |
On Wed, November 26, 2008 4:16 pm, Lynn Matteson wrote:
These props aren't constant speed props that you probably used in your certified
experience. So, you don't control them the same way.
With a cockpit adjustable (not-constant speed) prop, at run-up, you set the prop to
maximum horsepower rpm, WOT. As soon as you begin to roll, you're going to either have
to increase the pitch or pull back the power to control the rpm. Best practice is
normally to keep adding pitch as required until until you reach best angle or best
rate speed. When you reach traffic pattern altitude then you reduce power as you would
in a fixed pitch propeller configuration. At this point you might need to adjust the
pitch again for best economy.
Paul A. Franz, P.E.
PAF Consulting Engineers
Office 425.440.9505
Cell 425.241.1618
Lynn Matteson
Posted: Wed Nov 26, 2008 8:01 pm Post subject: Kitfox mishap in Colorado |
Thanks, Mike and Paul-
The closest I ever got to having to deal with a prop was 3+ hours one
day in a 180 Cessna, during my catch-as-catch-can flight
training....good thing too, as what you both describe sounds like it
*could* ruin your day, and did for the Colorado guy, if that's what
really happened. Glad I don't have to do anything like adjusting a
prop on takeoff. Maybe the FAA/EAA were right in excluding this
operation for Sport Pilots, time will tell.
Lynn Matteson
Jabiru 2200, 593hrs
Sensenich 62x46
system;
On Nov 26, 2008, at 8:33 PM, Paul A. Franz, P.E. wrote:
your certified
On Nov 26, 2008, at 8:29 PM, Michael Gibbs wrote:
<MichaelGibbs(at)cox.net>
Lynn sez:
my model IV, Lynn. With no prop pitch indication you can't
precisely set the pitch for best takeoff power beforehand. If I
ran it all the way flat then added full power, the RPM would go too
high, so I knew I had to pull the pitch in a little bit from that
point. After a while you could get pretty close with cranking it
all the way flat then pressing the switch the other way and
counting, "One thousand one, one thousand two..."
your speed picks up the RPM tends to go up a bit also, so I'd often
tap it back down to redline after establishing my initial climb.
pitch settings so it can't reverse or feather. Even if you had it
all the way flat or all the way coarse, with full throttle you'd
still have a significant amount of thrust happening. The NSI CAP
hub had an option for full reversing intended to simplify float-
plane maneuvering on the water. It had several mechanical and
electrical interlocks to prevent inadvertent reversing in flight
but I suppose if you were having a really, really bad day...
Mike G.
Phoenix, AZ
N369LM |
gary.algate(at)sandvik.co Guest
Posted: Wed Nov 26, 2008 8:16 pm Post subject: Kitfox mishap in Colorado |
You are right Lynn,
On my IFA IVO prop I would actually trim for take off when on final approach. Then it was always set for the next take off and also prepared should you have to make a go-around. On take off I would establish the climb out and then trim for cruise.
With my 70" two bladed medium prop and a 582 to this basically meant trim for 6500 on take off and approach and then trim for about 6100 WOT for cruise.
When you become more familiar with it there are plenty of other smaller changes that you can make during the flight envelope ie) Trim for improved EGT / Trim for improved coolant temps / trim for higher rpm take offs with floats etc.
Gary
Gary Algate
Kitfox Classic / Jab 2200
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
Lynn Matteson <lynnmatt(at)jps.net>
Sent by: owner-kitfox-list-server(at)matronics.com
27/11/2008 10:53 AM
Please respond to
kitfox-list(at)matronics.com To
kitfox-list(at)matronics.com cc
Subject
Re: Kitfox mishap in Colorado
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Lynn Matteson
Jabiru 2200, 593hrs
Sensenich 62x46
system;
> --> Kitfox-List message posted by: "fox5flyer"
> of that airplane!
> Deke Morisse
Posted: Wed Nov 26, 2008 10:26 pm Post subject: Kitfox mishap in Colorado |
On Wed, November 26, 2008 8:01 pm, Lynn Matteson wrote:
Most of my flying time has been in aircraft with fold up feet and a constant speed
prop so I feel really short changed with a cockpit adjustable.
There is no danger of putting in reverse Beta in a constant speed prop. You just set
it to the rpm you want. On take-off you set it at 2700 and the engine won't go any
faster than that. And it'll only go slower if you've set part throttle. The only
danger you have is lugging the engine if you pull the prop back before you reduce
power or the converse, say you're cruising at 2250 rpm at say 23" Hg manifold pressure
then you need to advance the rpm before you add power. The rule to remember is the
prop control sets rpm and the throttle sets power with a constant speed prop setup.
A constant speed prop is ideal but the governor mechanism is more complex than simple
cockpit adjustable and hence more expensive.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
Michel
Posted: Wed Nov 26, 2008 11:48 pm Post subject: Kitfox mishap in Colorado |
| Quote: | From: Lynn Matteson [lynnmatt(at)jps.net]
Yes Lynn, but I still prefer my Jabiru propeller, made in one piece from the finest Australian wood, hand-carved by a master Aboriginal boomerang craftsman. ... what? They are made out of wooden banana crates, by Chinese children in a sweatshop of Kuala Lumpur? ... Man! No wonder now why mine attracts so many insects!
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 --- flying as PAX
Fox5flyer Guest
Posted: Thu Nov 27, 2008 4:56 am Post subject: Kitfox mishap in Colorado |
Good question, Lynn. You're correct, but unless the prop has a pitch
indicator--most NSI units don't-- one sets it by a simple process prior to
takeoff, but sometimes it needs a bit of a tweak during the takeoff process
to get the correct takeoff rpm. Not a big deal at all, but for someone who
hadn't used one previously, it could be. Again, it's just speculation. I
have no idea what actually happened. As for the prop going into reverse, I
doubt it. That prop has built in interlocks so that it cannot go into beta
above a certain rpm. I think it's about 1200 prop rpm to be exact, but I'd
have to check.
Deke Morisse
Mikado Michigan
- Joseph Joubert
