Deems Davis
Posted: Thu Nov 27, 2008 6:33 am Post subject: Airflow Performace - Purge Valve Control |
Jason, here's a link to some pics about how I routed my AFP purge valve
cable :
http://deemsrv10.com/album/Sec%20FF3%20Control%20Cables/slides/DSC05372.html
use 'next image' on left side of page to see 6 more pics
I used rod ends instead of a wire and "B" nut I thought about a return
spring, but really couldn't conjure a way to do it. Don Rivera (at) Airflow
reviewed the install pics and said that it was the way they would do it
if they installed it in his shop.
I used an ACS cable with push button 'lock'
http://deemsrv10.com/album/Sec%20The%20Home%20Stretch/slides/DSC05530.html
Deems Davis # 406
'Its all done....Its just not put together'
The next step is to route the cable to operate the fuel purge valve located on the top of the engine. I would appreciate seeing how others routed and connected this cable. Pictures would be very helpful.... I will most likely add a spring return to this control that would hold the valve open if the cable were to fail.
Thanks, Jason Kreidler
Lew Gallagher
Posted: Thu Nov 27, 2008 7:37 am Post subject: Re: Airflow Performace - Purge Valve Control |
Hey Deems,
Your pictures are worth THOUSANDS of words! Thanks so much. (nice rudder pedals!)
While I'm at it, and it being Thanksgiving Day -- I am truly amazed and thankful that the "older" guys on this forum who are way ahead of us, or even flying for awhile, take the time to check the forum and respond to issues they've long since resolved. And sometimes they even respond several times on the same topic as newbies (as myself) stumble along.
Thanks to all and have a good one.
Later, - Lew
Painting more today between feasting since it's supposed to get up to 62.
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
