				 Posted: Tue Nov 25, 2008 3:02 pm    Post subject: [Probable Spam] Re: Re: Spreading fear about the  XL |
				Hi Guys,
 This week, I tensioned my cables as the last thing done for the annual
 inspection and they were near 10 -15 lbs by the gage I made for the task.
 While adjusting the turnbuckles, I increased the tension to 15 rudder,
 20 elevator and 25 for the ailerons. I believe you confuse stretching
 with pulling
 the cable taut or perfectly straight, which will not happen unless you
 reach some ungodly tension that breaks things. At 25 lbs, the cables for my
 ailerons is still able to move and do not act like a guitar string.
 Anything past 30 lbs the ribs will deflect to some degree and I would
 worry about
 the deflection turning into bending and excessive wear on the bell crank
 bearings.  I had to replace the bushings at the rudder this year after
 125 hours.
  Larry McFarland 601`HDS at www.macsmachine.com
 japhillipsga(at)aol.com wrote:
 [quote] Gig, the great probability is that other than when first set by the
  AMD guy they never have been correct or even anywhere near correct. I
  had a landing 2 years ago next March in a 20 knot + crosswind landing
  that ballooned up even with full aileron pitch down on the wing and to
  save it I fought the stick and bumped the throttle and got it down. I
  know I stretched the cables then because I also bent some stuff I had
  to replace. When I reattached the cables and reset the tension, but it
  was without a meter. If you set the cables you will find that about
  one turn of the turnbuckle is 10-15 pounds and I don't believe anybody
  can tell much difference between 20 and 30 pounds by touch. Best
  regards, Bill.
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Ron Lendon
				 Posted: Tue Nov 25, 2008 7:49 pm    Post subject: Re: [Probable Spam] Re: Re: Spreading fear about the  XL |
				Larry,
 It was never my intention to intimate using the airframe to stretch the cables like guitar strings.  I will fixture something on my work table when I get to that point. The cables will be pre-stretched before assembly.
 Hope that clarifies things,
  _________________ Ron Lendon
CH 601 XLB
N601LT  - Flying
Corvair Engine Prints:
		Gig Giacona
				 Posted: Wed Nov 26, 2008 7:19 am    Post subject: Re: [Probable Spam] Re: Re: Spreading fear about the  XL |
				 	  | Ron Lendon wrote: | 	 		  Larry,
 Hope that clarifies things, |
 That's the thing. I can't find anything, anywhere that says we either should or can pre-stretch these cables. If you have a specific place where this is shown please show specific cites.
601XL Under Construction
		Ron Lendon
				 Posted: Wed Nov 26, 2008 6:55 pm    Post subject: Re: [Probable Spam] Re: Re: Spreading fear about the  XL |
				Gig,
 I haven't found anything written either, but I will test the theory and report the results.  My plan is to make up some cables,  tension them above the requirements and see what happens when I apply a little more pressure, think plucking a guitar string, then check the tension again.  If it doesn't change we will know then.
CH 601 XLB
N601LT  - Flying
		Gig Giacona
				 Posted: Thu Nov 27, 2008 2:13 pm    Post subject: Re: [Probable Spam] Re: Re: Spreading fear about the  XL |
				 	  | Ron Lendon wrote: | 	 		  Gig,
 I haven't found anything written either, but I will test the theory and report the results.  My plan is to make up some cables,  tension them above the requirements and see what happens when I apply a little more pressure, think plucking a guitar string, then check the tension again.  If it doesn't change we will know then. |
 Well get to work on that Ron. I'll be mounting wings shortly.
