Rexwinkle
Posted: Mon Dec 01, 2008 2:19 pm Post subject: Aileron flutter |
Has anyone experienced aileron/wing flutter. What were your indications? Where was it felt? In the stick? In the floor? If you could please share your experiences with me I would appreciate it.
Thank you,
Scott
chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Mon Dec 01, 2008 7:12 pm Post subject: Re: Aileron flutter |
I see you only just joined did you just buy a kit? .. no offense but its already talked about and there would be no more new talk as yet. read the zenith site for all the info. What's your plans number?? or are you sniffing trying to turn up talk? for the opposition? newspapers?
Chris
Do not archive.
Rexwinkle
Posted: Tue Dec 02, 2008 8:44 am Post subject: Re: Aileron flutter |
I have purchased plans for a Zodiac CH 601 XL S/N: 6-7391. I am trying to gather information on this potential problem that I have been reading about and determine whether or not to proceed. All of the post that I have read talk about the cable tensions and what may happen if they are not correct. I am wondering what the warning signs of aileron flutter are, if any. If I am flying along are there going to be symptoms that I should recognize so that I can land the aircraft and rectify the problem before it becomes catastrophic? Have there been any design changes in the aircraft as a result of these accidents? As for your other questions, yes I am trying to turn up talk. I don't really know what you mean by opposition but I would have to guess no, and I do not work for any newspaper, magazine, website or any other type of periodical. Any help that I can get would be greatly appreciated.
Scott
psm(at)att.net Guest
Posted: Tue Dec 02, 2008 9:06 am Post subject: Aileron flutter |
Hi Scott,
I understand your request to be a reasonable one from your
perspective. The problem is there have been many unpleasant
discussions and indeed experiences on this issue so many list members
are overly sensitive. Let me try to give you a quick summary of the
facts as I understand them.
There have been a number of in flight structural failures on Zodiac
XLs. Oddly, I believe most of them have occurred with two people
aboard. The number of really suspicious ones is something between 3
and 5 world wide in the last few years. That accounts for perhaps
one percent of the XLs flying.
One of the suspicious accidents has just had a "Factual report" done
by the NTSB. I am anxiously awaiting the "Probable Cause" report
which should follow.
There has been a lot of attention lately to aileron cable
tension. With the latest "AD" from Europe and other notifications
from other sources, all XL flyers and builders should be well aware
of this issue. Time will tell if this makes any change in the accident rate.
My knowledge of flutter is not authoritative, but I will give you the
best answers I can. Flutter is a deadly problem in airplanes. It
happens when one of the controls starts flapping like a flag in a
high wind. In many cases this leads quickly to general structural
failure. When flutter happens the pilot knows something is going on
from both noise and vibration but he may not know what it is. The
only thing he can do is change the flight situation very quickly and
hope the flutter stops. The normal approach is to pull up to reduce
airspeed but unloading the wings by entering a steep bank might also work.
You must decide for yourself whether to go on with the XL. Some
builders have quit while others have continued on. The Zodiac XL is
an ideal design from many perspectives. The problem rate has been
high enough to be alarming but low enough that it doesn't suggest
that all XL flyers are taking an unreasonable risk.
Good luck,
Paul
XL getting close
At 08:44 AM 12/2/2008, you wrote:
| Quote: | I have purchased plans for a Zodiac CH 601 XL S/N: 6-7391. I am
Scott
z601(at)anemicaardvark.co Guest
Posted: Tue Dec 02, 2008 9:08 am Post subject: Aileron flutter |
On Tuesday 02 December 2008 10:44, Rexwinkle wrote:
<scottrexwinkle(at)yahoo.com>
Scott, this whole issue is in its infancy, as far as the Zenith 601XL is
concerned. It is not certain that aileron flutter is at fault, although some
things point that way.
For instance, there have been accident(s) in which the aileron separated from
the aircraft. That is a possible indicator of aileron flutter. A number of
the aircraft not involved in accidents have been found to have improperly
tensioned (too loose) control cables. That could be a cause of aileron
flutter.
But if there has been an official finding of aileron flutter in any of the
accidents, I'm not aware of it. The most recent preliminary finding of the
NTSB in the case of one accident (suspected by some to have been aileron
flutter) cites so many things done incorrectly by the operator, that it is
going to be difficult to fix the blame, IMHO. Sad, but that's how the report
appears to read.
Since the only firm indication of a problem that could point in this direction
has been the loose control cables, the designer has released a service
bulletin asking owners to check their cable tensions regularly, which they
should probably have been doing anyway. That's more of a precautionary move
than anything else.
Without knowing what, if anything, in the design, is causing this spate of
problems, it is probably premature to make design changes. Or too firm a set
of judgements of any type.
As for the rest of your question, the usual sign of aileron flutter is exactly
that: the aileron begins moving rapidly on its own. I would expect to sense
significant vibration in the airframe and the controls.
What do you do if this happens? An obvious thing is to slow down, if you can
do it quickly enough. Without energy being pumped into the system, it is
going to be harder to sustain the flutter. Try to get into slow, straight and
level flight, and land as soon as practical.
As for whether or not you should proceed, all I can tell you is that I'm just
starting on the kit, and I don't plan to stop based on these reports. They're
just too fragmentary and inconclusive. Like you, I would like to know the
cause of the problems, if there is a common cause, and what we can do to
prevent it.
Those who can, do. Those who can't, sue.
Jim B. Belcher
BS, MS Physics, math, Computer Science
A&P/IA
Instrument Rated Pilot
General Radio Telephone Certificate
Posted: Tue Dec 02, 2008 9:15 am Post subject: Aileron flutter |
Scott,
Work to keep your aircraft in good shape. Inspect the normal things like
you would any other aircraft. Do keep your cables tensioned as per spec.
and
don't fly over max speeds, over-load the aircraft or pull excessive G
loads and you'll be fine. Zenith XL is a good aircraft. Do these things
and you'll
never see flutter and probably wouldn't have anyway.
Rexwinkle wrote:
Scott
http://forums.matronics.com/viewtopic.php?p 17353#217353
ggower_99(at)yahoo.com Guest
Posted: Tue Dec 02, 2008 10:02 am Post subject: Aileron flutter |
My only advice to date:
Like any other homebuilt airplane. Build to plans, rig correcty, do a good preflight every time, fly the plane inside parameters and give a good mantainance.
Also not to forget: Once you have it glying, Check the weather, and plan carefully your gasoline range.
Enjoy your building and later your flying.
Saludos
Gary Gower,
Flying from Chapala, Mexico,
--- On Tue, 12/2/08, Rexwinkle <scottrexwinkle(at)yahoo.com> wrote:
| Quote: | From: Rexwinkle <scottrexwinkle(at)yahoo.com>
Subject: Re: Aileron flutter
Date: Tuesday, December 2, 2008, 11:44 AM
| Quote: | --> Zenith601-List message posted by: "Rexwinkle"
Scott
chris Sinfield
Posted: Wed Dec 03, 2008 4:00 am Post subject: Re: Aileron flutter |
welcome Scott to XL building.
Sorry if my first response sounded cold. As someone else said there is a person who has joined a lot of lists of late and its almost like a mass email message badmouthing the XL and all things Zenith.
I for one think the XL is a great plane and am 3/4 the way through building. Am I going to continue, yes. why..
1. The Hinze family believe it is safe, Chris lets his own kids fly in the planes he designed. what parent would not put the safety of their kids first.
2. the XL plane has been looked at intensely by a number of organizations FAA LAA RAA ect ect. if it passes their design criteria without a major change then to me thats going to be a great safety advertising and selling point. if they find something even better, as once the change is made it is been checked and safe to fly..
3. reality check, I saw a Cesnna crashed the other day. all planes may crash if flown outside the design envelope.
4. Flutter.. saw it happen on a balanced C130 Aileron, plane nearly crashed .
Build it fly it learn it and enjoy it. .
Chris.
ashontz
Posted: Thu Dec 04, 2008 5:05 am Post subject: Re: Aileron flutter |
The fact that the factory plane is flying with no problems (as well as many other XLs) points to sloppy building/maintenance/piloting in incident airplanes. The XL is basically high performance plane which when poor piloting and sloppy building are combined could lead to a problem. Again, not the plane, but poor building, maintenance, and piloting are what I believe to be the suspicious factors in the accidents that did occur.
Rexwinkle
Posted: Thu Dec 04, 2008 8:13 am Post subject: Re: Aileron flutter |
Actually in the US two of the crashes were factory built and two were home built.
Posted: Thu Dec 04, 2008 8:19 am Post subject: Aileron flutter |
On Thursday 04 December 2008 10:13, Rexwinkle wrote:
built.
Which might, repeat, might, suggest the problem is one of maintenance rather
than construction.
Jim B. Belcher
A&P/IA
planecrazydld(at)yahoo.co Guest
Posted: Thu Dec 04, 2008 8:24 am Post subject: Aileron flutter |
Hi Andy;
Completely agreed, but I think the sentence should have said something like: "The XL is basically a high performance plane being sold in a low performance arena (LSA) which when poor pilot judgement/skill and less than optimal building techniques are combined could lead to a problem.
The very slippery design can easily exceed all of the LSA limits imposed on it - and under those conditions all bets are off.
David L. Downey
Harleysville (SE) PA, USA
--- On Thu, 12/4/08, ashontz <ashontz(at)nbme.org> wrote:
[quote]From: ashontz <ashontz(at)nbme.org>
Date: Thursday, December 4, 2008, [quote][b]
ashontz
Posted: Thu Dec 04, 2008 8:27 am Post subject: Re: Aileron flutter |
Exactly. I suggested 3 possible areas (a 4th could be the plane itself, but I didn't list that because that's most likely NOT the problem as evidenced by the fact that the factory demonstrator as well as many other XLs have experienced NO problems). So the 3 possible areas are, builder error, maintenance error, pilot error.
| z601(at)anemicaardvark.co wrote: | On Thursday 04 December 2008 10:13, Rexwinkle wrote:
<scottrexwinkle>
built.
than construction.
Jim B. Belcher
A&P/IA
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Thu Dec 04, 2008 8:38 am Post subject: Aileron flutter |
On Thu, Dec 04, 2008 at 10:20:09AM -0600, Jim Belcher wrote:
> built.
than construction.
Might. Note also that the two factory aircraft were built by two different
factories: one by AMD, one by CZAW.
Jay Maynard, K5ZC, PP-ASEL http://www.conmicro.com
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
jmaynard
Posted: Thu Dec 04, 2008 8:41 am Post subject: Aileron flutter |
On Thu, Dec 04, 2008 at 08:24:03AM -0800, David Downey wrote:
| Quote: | The very slippery design can easily exceed all of the LSA limits imposed
What LSA limits can it exceed? The only one that matters in this discussion
is a Vh of 120 knots, and that's not a speed of anything other than
regulatory interest. *ANY* airplane can exceed Vno easily; this is hardly
limited to the Zodiac. I've never gotten close to Vne, even in a power-on
descent in still air.
The LSA limits aren't ones relating to structural strength; they're there to
make sure the aircraft can be safely flown by pilots with limited
experience.
Gig Giacona
Posted: Thu Dec 04, 2008 8:45 am Post subject: Re: Aileron flutter |
| jmaynard wrote: |
factories: one by AMD, one by CZAW. |
And only God knows what how CZAW built them considering the financial issues that have come out about them.
601XL Under Construction
