1st Flight Test Plan?
riffeljl(at)gmail.com
PostPosted: Wed Dec 10, 2008 6:38 pm    Post subject: 1st Flight Test Plan? Reply with quote
I'd appreciate any constructive input on my plan for my 1st Flight:
____________________
  1. Ground
    1. Equipment:
      1. Fire extinguisher
      2. Hatchet
      3. Knife
      4. Gloves
      5. Phillips screwdriver
    2. monitor freq: 122.85
    3. Record Launch Time: __________________________________
    4. Prompt/record:
      Elapsed
      Oil Press
      Oil Temp
      EGT1
      EGT2
      EGT3
      EGT4
      CHT1
      CHT2
      CHT3
      CHT4
      2 min
      5 min
      10 min
      15 min
      20 min
      25 min
      30 min
    5. IF CHT => 400°F, advise LANDING
    6. 30 Minutes
      1. Prompt for
        1. RPM: ______________
        2. MAP: ______________
        3. AIRSPEED: _________
      2. Remind to LAND
    7. Record Landing Time: _______________
    8. IF CRASH:
      1. Dial 911 & give location
      2. Save Pilot – aircraft is secondary
      3. Gloves, knife, hatchet, Fire Extinguisher
      4. Canopy latch rotates CLOCKWISE to OPEN
      5. MASTER OFF (lower left panel)
      6. Fuel Selector: (center, front of spar)
        1. OFF (aft left)
      7. Seat belts: PULL FLAP
      8. Shoulder Harness: PULL TABS to LOOSEN
      9. Cowl:
        1. Oil Door for top cowl hinge wires on firewall
        2. Phillips screwdriver for hinge wires on cowl halves
      10. Battery located on pilot side firewall
  2. Chase
    1. Monitor 122.85
    2. Com check: Ground/TestFlight
    3. Depart first; take station EAST of runway
    4. Take up ½ mile trail
    5. Check Fluids/Flapping Parts
    6. If TestFlight rocks wings:
      1. Come up on right wing till TestFlight acknowledges
      2. Fly under to left wing, then over top to right wing
      3. Signal TestFlight:
        1. OK: Thumbsup
        2. Problems: cut Throat to land
    7. Emergencies:
      1. Com Failure:
        2. Point to Ears
      2. Parts/Fluid/fire:
        2. Cut Throat to indicate landing
        3. Remind pilot:
          1. Master Off
          2. FUEL OFF
          3. Canopy Unlatched – but closed
      3. Crash:
        1. Tell Ground location
        2. Circle till Ground arrives
  3. TestFlight
    1. Equipment:
      2. Hatchet
      3. Knife
    2. Com: 122.85
    3. Com Check: Ground/Chase
    4. Ensure EIS configuration set for oil temp
    5. Retest Brakes on taxi/runup
    6. Depart after Chase
    7. TAKEOFF:
      1. FULL POWER, FULL RICH (lean only to smooth engine)
      2. 70-75% power
        1. 3000', 2400/24"
    8. Verify Airspeed registering
    9. Boost Pump Off
    10. Orbit, traffic pattern direction, ½ mile radius of airport
    11. IF CHT => 400°F, LAND
    12. Tasks
      1. Straight & Level:
        1. Both trims in neutral
        2. Record vsi/roll: _____________________________________________________
        3. Adjust for level
      2. Tell Ground OilT/P, EGTs, CHTs
      3. Check w/ Chase that area is clear
      4. Stall
        1. Slow to mushy controls/buffet
        2. Airspeed: _________
        3. Check: OilT/P, EGTs, CHTs
        4. Flaps: 20% (two marks)
        5. Airspeed: _________
        6. Check: OilT/P, EGTs, CHTs
        7. Flaps: FULL
        8. Airspeed: _________
        9. Check: OilT/P, EGTs, CHTs
      5. Airspeed Check:
        1. Setup Airspeed to 120 kts
        2. Call Chase to right side
        3. Compare airspeeds with Chase
      6. Land
        1. Downwind: 1.5 times clean stall (80-90 kts?)
        2. Base: 20° flaps
        3. Stay on mains if possible
    13. Signals:
      1. Ears: com failure
      2. Cut Throat: Land
      3. Rock Wings: Chase come up to look over TestFlight
HCRV6(at)comcast.net
PostPosted: Wed Dec 10, 2008 8:00 pm    Post subject: 1st Flight Test Plan? Reply with quote
In my experience if your engine is new or newly overhauled your 400 Deg limit for CHT on the first flight is overly conservative. On my first flight with a new O-360 from Van's the CHT's, which now approach 400 deg only in a hot day full power climb at near gross, went over 400 deg on the initial climb out. Since Lycoming sets 450 deg as the NTE if I recall correctly, you can safely use that temp as your limit. Just my opinion.
Harry Crosby
RV-6 N16CX, 530 hours
Kellym
PostPosted: Wed Dec 10, 2008 8:17 pm    Post subject: 1st Flight Test Plan? Reply with quote
IMHO, 400 degrees should be a take action point, either add airspeed, fuel or reduce power, as appropriate to the situation. I would use 425 as a never exceed limit, as metal deformation can occur above that. Lycoming's numbers are WAY too hot if you want your cylinders and rings to survive. This time of year there shouldn't be any problem staying below 400. Initial climb out should be as flat and fast as terrain and obstacles permit for max cooling during first high power run.
Kelly McMullen
A&P/IA
Tech Counselor
HCRV6(at)comcast.net (HCRV6(at)comcast.net) wrote: [quote] p { margin: 0; } In my experience if your engine is new or newly overhauled your 400 Deg limit for CHT on the first flight is overly conservative.  On my first flight with a new O-360 from Van's the CHT's, which now approach 400 deg only in a hot day full power climb at near gross, went over 400 deg on the initial climb out.  Since Lycoming sets 450 deg as the NTE if I recall correctly, you can safely use that temp as your limit.  Just my opinion.
Harry Crosby
Kelly McMullen
KCHD
rv8a2001(at)yahoo.com
PostPosted: Wed Dec 10, 2008 8:22 pm    Post subject: 1st Flight Test Plan? Reply with quote
My personal opinion, and I know people will disagree....... that is WAY to much to be concerned about on your first flight, you should be doing nothing more than flying the plane and monitoring temps. Scope out off field landing places prior to flight but then again why would you fly further than gliding distance from the field.........
so just fly 2o minutes, land, check for leaks, celebrate and then ease into the below. I do like the "chase" portion though.
The first flight will be exciting enough with out having a check list a mile long to deal with..........unless of course your a former test pilot.........my comments above are for Joe average pilot.
Scott
RV-8a
To: rv-list <rv-list(at)matronics.com>
Sent: Wednesday, December 10, 2008 6:37:44 PM
Subject: 1st Flight Test Plan?
  1. Ground
    1. Equipment:
      2. Hatchet
      3. Knife
      4. Gloves
    4. Prompt/record:
      Elapsed
      Oil Press
      Oil Temp
      EGT1
      EGT2
      EGT3
      EGT4
      CHT1
      CHT2
      CHT3
      CHT4
      2 min
      5 min
      10 min
      15 min
      20 min
      25 min
      30 min
    6. 30 Minutes
      1. Prompt for
      2. Remind to LAND
    8. IF CRASH:
        1. OFF (aft left)
      9. Cowl:
  2. Chase
    1. Monitor 122.85
        1. OK: Thumbsup
    7. Emergencies:
      1. Com Failure:
        2. Point to Ears
        3. Remind pilot:
          1. Master Off
          2. FUEL OFF
      3. Crash:
  3. TestFlight
    1. Equipment:
      2. Hatchet
      3. Knife
    2. Com: 122.85
    7. TAKEOFF:
      2. 70-75% power
        1. 3000', 2400/24"
    9. Boost Pump Off
    12. Tasks
        3. Adjust for level
      4. Stall
        7. Flaps: FULL
      5. Airspeed Check:
      6. Land
        2. Base: 20° flaps
    13. Signals:
      2. Cut Throat: Land
ronlee(at)pcisys.net
PostPosted: Wed Dec 10, 2008 8:34 pm    Post subject: 1st Flight Test Plan? Reply with quote
Hopefully someone else will record all that data. Not the test pilot.
Ron Lee
sbuc(at)hiwaay.net
Wow! I've been flying my RV-6 for 900 hrs and don't think I'd have the
presence of mind to punch half the stuff on that list. Smile
Sam Buchanan
http://thervjournal.com
1.
*Ground*
1.
Equipment:
1.
Fire extinguisher
2.
Hatchet
3.
Knife
4.
Gloves
5.
2.
monitor freq: *122.85*
3.
*Record Launch Time: __________________________________*
4.
Prompt/record:
*Elapsed*
*Oil Press*
*Oil Temp*
*EGT1*
*EGT2*
*EGT3*
*EGT4*
*CHT1*
*CHT2*
*CHT3*
*CHT4*
*2 min*
*5 min*
*10 min*
*15 min*
*20 min*
*25 min*
*30 min*
5.
*IF CHT => 400°F, advise LANDING*
6.
*30 Minutes*
1.
Prompt for
1.
RPM: ______________
2.
MAP: ______________
3.
AIRSPEED: _________
2.
Remind to LAND
7.
*Record Landing Time: _______________*
8.
IF CRASH:
1.
2.
*Save Pilot – aircraft is secondary*
3.
4.
Canopy latch rotates *CLOCKWISE* to OPEN
5.
*MASTER OFF (lower left panel)*
6.
*Fuel Selector: (center, front of spar)*
1.
*OFF (aft left)*
7.
Seat belts: P*ULL FLAP*
8.
Shoulder Harness: *PULL TABS* to LOOSEN
9.
Cowl:
1.
2.
10.
2.
*Chase*
1.
Monitor *122.85*
2.
3.
Depart first; take station *EAST *of runway
4.
5.
6.
*If TestFlight rocks wings:*
1.
2.
3.
Signal TestFlight:
1.
OK: Thumbsup
2.
7.
*Emergencies:*
1.
Com Failure:
1.
2.
Point to Ears
2.
Parts/Fluid/fire:
1.
2.
3.
Remind pilot:
1.
*Master Off*
2.
*FUEL OFF*
3.
3.
Crash:
1.
2.
3.
*TestFlight*
1.
Equipment:
1.
Fire extinguisher
2.
Hatchet
3.
Knife
2.
Com:* 122.85*
3.
4.
5.
6.
Depart after Chase
7.
TAKEOFF:
1.
2.
70-75% power
1.
3000', 2400/24"
8.
9.
Boost Pump Off
10.
11.
*IF CHT => 400°F, LAND*
12.
Tasks
1.
Straight & Level:
1.
2.
Record vsi/roll:
3.
Adjust for level
2.
3.
4.
Stall
1.
2.
Airspeed: _________
3.
4.
5.
Airspeed: _________
6.
7.
Flaps: FULL
8.
Airspeed: _________
9.
5.
Airspeed Check:
1.
2.
3.
6.
Land
1.
2.
Base: 20° flaps
3.
13.
*Signals:*
1.
*Ears:* com failure
2.
*Cut Throat:* Land
3.
*Rock Wings:* Chase come up to look over TestFlight
PostPosted: Wed Dec 10, 2008 8:49 pm    Post subject: 1st Flight Test Plan? Reply with quote
EGT is not very important on the first flight
Ron
timb
PostPosted: Thu Dec 11, 2008 5:58 am    Post subject: 1st Flight Test Plan? Reply with quote
I completely agree with another post; this is way more than you need to worry about on your first and even the second flight.  Focus on how the plane feels, and try some slow flight before landing.  Don’t venture too far from the airport, keep it short maybe 15 or 20 minutes and then land and go celebrate.  The 25 – 40 hours after this will provide plenty of time to figure out the rest in small chunks.  Your complete attention is needed to verify controllability and landing potential on your first flight.
Just my .02 cents worth.
Tim Bryan
RV-6 Flying
N616TB over 120 hours now
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of J Riffel
Sent: Wednesday, December 10, 2008 8:38 PM
To: rv-list
<![if !supportLists]>1. <![endif]>Ground
<![if !supportLists]>1. <![endif]>Equipment:
<![if !supportLists]>1. <![endif]>Fire extinguisher
<![if !supportLists]>2. <![endif]>Hatchet
<![if !supportLists]>3. <![endif]>Knife
<![if !supportLists]>4. <![endif]>Gloves
<![if !supportLists]>5. <![endif]>Phillips screwdriver
<![if !supportLists]>2. <![endif]>monitor freq: 122.85
<![if !supportLists]>3. <![endif]>Record Launch Time: __________________________________
<![if !supportLists]>4. <![endif]>Prompt/record:
Elapsed
Oil Press
Oil Temp
EGT1
EGT2
EGT3
EGT4
CHT1
CHT2
CHT3
CHT4
2 min
5 min
10 min
15 min
20 min
25 min
30 min
<![if !supportLists]>5. <![endif]>IF CHT => 400°F, advise LANDING
<![if !supportLists]>6. <![endif]>30 Minutes
<![if !supportLists]>1. <![endif]>Prompt for
<![if !supportLists]>1. <![endif]>RPM: ______________
<![if !supportLists]>2. <![endif]>MAP: ______________
<![if !supportLists]>3. <![endif]>AIRSPEED: _________
<![if !supportLists]>2. <![endif]>Remind to LAND
<![if !supportLists]>7. <![endif]>Record Landing Time: _______________
<![if !supportLists]>8. <![endif]>IF CRASH:
<![if !supportLists]>1. <![endif]>Dial 911 & give location
<![if !supportLists]>2. <![endif]>Save Pilot – aircraft is secondary
<![if !supportLists]>3. <![endif]>Gloves, knife, hatchet, Fire Extinguisher
<![if !supportLists]>4. <![endif]>Canopy latch rotates CLOCKWISE to OPEN
<![if !supportLists]>5. <![endif]>MASTER OFF (lower left panel)
<![if !supportLists]>6. <![endif]>Fuel Selector: (center, front of spar)
<![if !supportLists]>1. <![endif]>OFF (aft left)
<![if !supportLists]>7. <![endif]>Seat belts: PULL FLAP
<![if !supportLists]>8. <![endif]>Shoulder Harness: PULL TABS to LOOSEN
<![if !supportLists]>9. <![endif]>Cowl:
<![if !supportLists]>1. <![endif]>Oil Door for top cowl hinge wires on firewall
<![if !supportLists]>2. <![endif]>Phillips screwdriver for hinge wires on cowl halves
<![if !supportLists]>10. <![endif]>Battery located on pilot side firewall
<![if !supportLists]>2. <![endif]>Chase
<![if !supportLists]>1. <![endif]>Monitor 122.85
<![if !supportLists]>2. <![endif]>Com check: Ground/TestFlight
<![if !supportLists]>3. <![endif]>Depart first; take station EAST of runway
<![if !supportLists]>4. <![endif]>Take up ½ mile trail
<![if !supportLists]>5. <![endif]>Check Fluids/Flapping Parts
<![if !supportLists]>6. <![endif]>If TestFlight rocks wings:
<![if !supportLists]>1. <![endif]>Come up on right wing till TestFlight acknowledges
<![if !supportLists]>2. <![endif]>Fly under to left wing, then over top to right wing
<![if !supportLists]>3. <![endif]>Signal TestFlight:
<![if !supportLists]>1. <![endif]>OK: Thumbsup
<![if !supportLists]>2. <![endif]>Problems: cut Throat to land
<![if !supportLists]>7. <![endif]>Emergencies:
<![if !supportLists]>1. <![endif]>Com Failure:
<![if !supportLists]>2. <![endif]>Point to Ears
<![if !supportLists]>2. <![endif]>Parts/Fluid/fire:
<![if !supportLists]>2. <![endif]>Cut Throat to indicate landing
<![if !supportLists]>3. <![endif]>Remind pilot:
<![if !supportLists]>1. <![endif]>Master Off
<![if !supportLists]>2. <![endif]>FUEL OFF
<![if !supportLists]>3. <![endif]>Canopy Unlatched – but closed
<![if !supportLists]>3. <![endif]>Crash:
<![if !supportLists]>1. <![endif]>Tell Ground location
<![if !supportLists]>2. <![endif]>Circle till Ground arrives
<![if !supportLists]>3. <![endif]>TestFlight
<![if !supportLists]>2. <![endif]>Com: 122.85
<![if !supportLists]>3. <![endif]>Com Check: Ground/Chase
<![if !supportLists]>4. <![endif]>Ensure EIS configuration set for oil temp
<![if !supportLists]>5. <![endif]>Retest Brakes on taxi/runup
<![if !supportLists]>6. <![endif]>Depart after Chase
<![if !supportLists]>7. <![endif]>TAKEOFF:
<![if !supportLists]>1. <![endif]>FULL POWER, FULL RICH (lean only to smooth engine)
<![if !supportLists]>2. <![endif]>70-75% power
<![if !supportLists]>1. <![endif]>3000', 2400/24"
<![if !supportLists]>8. <![endif]>Verify Airspeed registering
<![if !supportLists]>9. <![endif]>Boost Pump Off
<![if !supportLists]>10. <![endif]>Orbit, traffic pattern direction, ½ mile radius of airport
<![if !supportLists]>11. <![endif]>IF CHT => 400°F, LAND
<![if !supportLists]>12. <![endif]>Tasks
<![if !supportLists]>1. <![endif]>Straight & Level:
<![if !supportLists]>1. <![endif]>Both trims in neutral
<![if !supportLists]>2. <![endif]>Record vsi/roll: _____________________________________________________
<![if !supportLists]>3. <![endif]>Adjust for level
<![if !supportLists]>2. <![endif]>Tell Ground OilT/P, EGTs, CHTs
<![if !supportLists]>3. <![endif]>Check w/ Chase that area is clear
<![if !supportLists]>4. <![endif]>Stall
<![if !supportLists]>1. <![endif]>Slow to mushy controls/buffet
<![if !supportLists]>2. <![endif]>Airspeed: _________
<![if !supportLists]>3. <![endif]>Check: OilT/P, EGTs, CHTs
<![if !supportLists]>4. <![endif]>Flaps: 20% (two marks)
<![if !supportLists]>5. <![endif]>Airspeed: _________
<![if !supportLists]>6. <![endif]>Check: OilT/P, EGTs, CHTs
<![if !supportLists]>7. <![endif]>Flaps: FULL
<![if !supportLists]>8. <![endif]>Airspeed: _________
<![if !supportLists]>9. <![endif]>Check: OilT/P, EGTs, CHTs
<![if !supportLists]>5. <![endif]>Airspeed Check:
<![if !supportLists]>1. <![endif]>Setup Airspeed to 120 kts
<![if !supportLists]>2. <![endif]>Call Chase to right side
<![if !supportLists]>3. <![endif]>Compare airspeeds with Chase
<![if !supportLists]>6. <![endif]>Land
<![if !supportLists]>1. <![endif]>Downwind: 1.5 times clean stall (80-90 kts?)
<![if !supportLists]>2. <![endif]>Base: 20° flaps
<![if !supportLists]>3. <![endif]>Stay on mains if possible
<![if !supportLists]>13. <![endif]>Signals:
<![if !supportLists]>1. <![endif]>Ears: com failure
<![if !supportLists]>2. <![endif]>Cut Throat: Land
<![if !supportLists]>3. <![endif]>Rock Wings: Chase come up to look over TestFlight
Tim Bryan
RV-6 Flying
N616TB
Dale Ensing
PostPosted: Thu Dec 11, 2008 5:59 am    Post subject: 1st Flight Test Plan? Reply with quote
A system I have used as a Flight Advisor that keeps the test pilot attention on flying the airplane and not trying to read the flight plan and record data:
A person on the ground with handheld radio w/ headset and clip board with the flight plan/check list.The ground person calls out the items. Test pilot checks the insurments/airplane and responds to the ground member. Ground person records the data and flight time.
A preflight briefing between test pilot and ground crew helps all this take place.
Dale Ensing
Dale Ensing
RV-6A
Aero Plantation
Weddington NC
pitts_pilot(at)bellsouth.
PostPosted: Thu Dec 11, 2008 6:34 am    Post subject: 1st Flight Test Plan? Reply with quote
Good advice Tim! My first flight in my Pitts started with a couple dozen
of my friends around the hangar. I was gone for an hour .... because I
think I was too scared to land ..... y'all probably know that the Pitts
has a reputation for doing wild ballet during landing .... but the
landing was a no-brainer. Only a few die-hards remained when I returned
to the hangar, and it was a small celebration. In that hour I don't
think I got the Pitts outside the airport boundary!!! Having learned
from others over the years, a short (15-20 minutes) is long enough to
get the engine operating temps up and to uncover any oil leaks that may
crop up. Becoming comfortable with the amount of control necessary to
control the airplane is probably the biggest variable between planes. I
think we become more 'ham fisted' with the adrenaline rush .... and
there certainly is a big rush .... Smile
Linn
*Tim Bryan*
*RV-6 Flying*
*N616TB over 120 hours now*
lifeofreiley2003(at)yahoo
PostPosted: Thu Dec 11, 2008 7:41 am    Post subject: 1st Flight Test Plan? Reply with quote
Very well said Tim... And no big crowd necessary!
Darrell
--- On Thu, 12/11/08, Tim Bryan <n616tb(at)btsapps.com> wrote:
Subject: RE: 1st Flight Test Plan?
To: rv-list(at)matronics.com
Date: Thursday, December 11, 2008, 7:57 AM
you need to
Focus on how the
then land and go
plenty of time to
flight.
Tim Bryan
RV-6 Flying
Riffel
To: rv-list
1st Flight:
1. Ground
1. Equipment:
2. Hatchet
3. Knife
4. Gloves
4. Prompt/record:
Elapsed
Oil Press
Oil Temp
EGT1
EGT2
EGT3
EGT4
CHT1
CHT2
CHT3
CHT4
2 min
5 min
10 min
15 min
20 min
25 min
30 min
6. 30 Minutes
1. Prompt for
2. Remind to LAND
8. IF CRASH:
1. OFF (aft left)
9. Cowl:
2. Chase
1. Monitor 122.85
1. OK: Thumbsup
7. Emergencies:
1. Com Failure:
2. Point to Ears
3. Remind pilot:
1. Master Off
2. FUEL OFF
3. Crash:
3. TestFlight
1. Equipment:
2. Hatchet
3. Knife
2. Com: 122.85
7. TAKEOFF:
2. 70-75% power
1. 3000', 2400/24"
9. Boost Pump Off
airport
12. Tasks
2. Record vsi/roll:
3. Adjust for level
4. Stall
7. Flaps: FULL
5. Airspeed Check:
6. Land
2. Base: 20° flaps
13. Signals:
2. Cut Throat: Land
craigtxtx(at)yahoo.com
PostPosted: Thu Dec 11, 2008 8:27 am    Post subject: 1st Flight Test Plan? Reply with quote
I did this about two weeks ago and agree with previous comments. Your total focus needs to be on flying the airplane and monitoring engine performance to the extent you assure that it continues to make noise. Plenty of time to record stuff later. Keep it simple. Keep it short. Stay focused on the airplane. Have fun.
Craig Gallenbach
RV8A N184CG
5 hours
To: "rv-list" <rv-list(at)matronics.com>
Date: Wednesday, December 10, 2008, 8:37 PM
  1. Ground
    1. Equipment:
      2. Hatchet
      3. Knife
      4. Gloves
Prompt/record:
Elapsed
Oil Press
Oil Temp
EGT1
EGT2
EGT3
EGT4
CHT1
CHT2
CHT3
CHT4
2 min
5 min
10 min
15 min
20 min
25 min
30 min
30 Minutes
  1. Prompt for
    Remind to LAND
      IF CRASH:
        1. OFF (aft left)
      9. Cowl:
          Chase
          1. Monitor 122.85
              1. OK: Thumbsup
            Emergencies:
            1. Com Failure:
              2. Point to Ears
            Parts/Fluid/fire:
            3. Remind pilot:
              1. Master Off
              2. FUEL OFF
                Crash:
                      TestFlight
                      1. Equipment:
                        2. Hatchet
                        3. Knife
                        Com: 122.85
                        Depart after Chase
                        TAKEOFF:
                        2. 70-75% power
                          1. 3000', 2400/24"
                          Boost Pump Off
                          Tasks
                            3. Adjust for level
                            Stall
                            7. Flaps: FULL
                              Airspeed Check:
                                Land
                                2. Base: 20° flaps
                                    Signals:
                                    2. Cut Throat: Land
                                          t=_blank rel=nofollow>http://www.matronics.com/Navigator?RV-List
                                          rv9jim(at)juno.com
                                          PostPosted: Thu Dec 11, 2008 10:06 am    Post subject: 1st Flight Test Plan? Reply with quote
                                          You did not say what type of instrumentation you are using to tell you
                                          the info you want. I have the EIS from Grand Rapids that has limits
                                          (both high and low) set in the unit. If any of these are exceeded, the
                                          "big red light" turns on and tells you what is the offending parameter.
                                          That way, on my first flight, and the rest of them, I could concentrate
                                          on flying the plane. There is enough stress on the pilot for the first
                                          flight with out taking your attention off the flying. CHT's are the
                                          most important thing to watch. I kept my airspeed on take off in the
                                          110K range. This gave me good cooling as well as good visibility. It
                                          also gives you many options if things get sticky. Airspeed is life as
                                          the air force jocks will tell you. The biggest problem will be to loose
                                          the airspeed on downwind. That means that I need to reduce power as soon
                                          as I get to downwind altitude. Tough to do with the slippery RV's. In
                                          thirty seconds you will be ready to turn cross wind and then thirty
                                          seconds later, to down wind. It all happens fast !!!!!!
                                          Jim
                                          Criminal Lawyers - Click here.
                                          http://thirdpartyoffers.juno.com/TGL2141/fc/PnY6rw3dDC4Q87ZKvBGgg4A5PcYwRy849yHbAS7GIRAAEo9AZMtTd/
                                          khorton01(at)rogers.com
                                          PostPosted: Thu Dec 11, 2008 3:35 pm    Post subject: 1st Flight Test Plan? Reply with quote
                                          Three comments:
                                          1. I'd drop the formation airspeed check. Doing a 120 kt airspeed
                                          check just adds more low power time, which detracts from the engine
                                          break-in, but it doesn't tell you anything that can't wait a few
                                          flights. Take your IAS at the full flap stall, and multiply by about
                                          1.5, and do a very quick controllablity evaluation at that speed. If
                                          it feels good, use that for the initial approach speed. You can work
                                          on dialing that down a bit slower on subsequent flights.
                                          2. I'd restrict the duration to 20 minutes, or less. There are a lot
                                          of things that can be happening ahead of the firewall on the first
                                          flight, and it is best to keep the duration short, and then do a very
                                          detailed inspection before flying again. I know of several RV owners
                                          who had the alternator pulley wear through the cowling on the first
                                          flight. I thought I had enough clearance between the alternator
                                          pulley and the cowling, but apparently the air loads push the lower
                                          cowling aft. I did a 20 minute first flight, and my alternator pulley
                                          put a very deep gouge in the cowling. I think it may have worn all
                                          the way through in 30 minutes. It is a lot easier to fill in a gouge,
                                          that it is to repair it if it comes all the way through. I also had
                                          an issue with heat stress on the throttle cable, as it was too close
                                          to the exhaust.
                                          3. I wouldn't record EGT. It tells you nothing useful. CHTs, oil
                                          temperature and oil pressure should be monitored. Recording them is
                                          optional.
                                          I like the detailed notes on ground items, chase briefing, etc.
                                          Good luck,
                                          Kevin Horton
                                          Ottawa, Canada
