Thrust line?
heisan
PostPosted: Thu Dec 11, 2008 12:35 am    Post subject: Thrust line? Reply with quote
Hi all,
I will soon be the owner of a partially complete HDS kit, and am busy engine shopping.
I have found an 80hp AeroVee engine that was removed from a HD. It flew the aircraft reasonably well, but take-off performance was really bad.
I was considering buying the engine and fitting a reduction drive and in flight adjustable Ivo Prop to make the most out of the engine.
Now the question is, how sensitive is the HDS to thrust line? I can keep the existing engine mount, which will move the thrust line up 130mm (5") from the standard position, or I can invest a bit more in a new engine mount.
I see from the photo's on Zeniths website that there is at least one HD out there with a redrive and a high thrust line, so it can't be all bad?
If anybody knows how good/bad a 130mm higher thrust line will be, I would appreciate any feedback!
Justin
larry(at)macsmachine.com
PostPosted: Thu Dec 11, 2008 6:45 am    Post subject: Thrust line? Reply with quote
Hi Heisan,
I'd reconsider the 80-hp AeroVee on the HDS. 80-hp is marginal on the
wing area of the HDS where the HD would only be adequate.
I've a Subaru which delivers 100 hp and an a friends HD with the same
engine setup could out climb the HDS making my aircraft feel
completely anemic. I could go faster, but climb with 80-hp in an HDS
isn't a good thing unless you intend to keep it under 650 lbs empty.
heisan wrote:
Hi all,
Justin
http://forums.matronics.com/viewtopic.php?p 18844#218844
Jeyoung65(at)aol.com
PostPosted: Thu Dec 11, 2008 8:05 am    Post subject: Thrust line? Reply with quote
Justin, I would not move the thrust line up 5" without changing engine mount. It will change you aircraft stability. I do not know where the CG (that POINT were the aircarft will hang level on a string) is on a HDS. I think it is just below the thrust line so you would be moving it above the CG. Jerry of GA
In a message dated 12/11/2008 3:36:27 A.M. Eastern Standard Time, justin(at)expertron.co.za writes:
--> Zenith601-List message posted by: "heisan" <justin(at)expertron.co.za>
Hi all,
Justin
http://forums.matronics.com/viewtopic.php?p=218844#218844
One site keeps you connected to all your email: AOL Mail, Gmail, and Yahoo Mail=emlcntaolcom00000019">The NEW AOL.com.
heisan
PostPosted: Thu Dec 11, 2008 8:06 am    Post subject: Re: Thrust line? Reply with quote
I am a bit worried about that. My empty weight should be well under 300lbs though. Also, the VP prop will allow me to climb at max continuous RPM (3400), so it will climb a lot better than a stock 80hp setup.
The problem with the subies is the price. I have gotten quotes from RAM and Stratus, and both were ridiculous - once shipping and duties are added, they cost substantially more than a brand new 120hp Jab!
The only cost effective engine I can lay my hands on is the VW.
Gig Giacona
PostPosted: Thu Dec 11, 2008 8:23 am    Post subject: Re: Thrust line? Reply with quote
Check out a corvair. www.flycorvair.com
W.R. "Gig" Giacona
601XL Under Construction
heisan
PostPosted: Thu Dec 11, 2008 8:32 am    Post subject: Re: Thrust line? Reply with quote
WW hasn't responded to any of my emails, but I am chatting to the guys at Aeromax now.
Spares are a problem though, as no corvair cars were ever sold in South Africa, so all spares need to be imported. Cost is also very high for what you get (only 20% cheaper than a Jab 3300).
I really want to pust that 120hp Jabiru in, but just can't afford it...
bryanmmartin
PostPosted: Thu Dec 11, 2008 9:31 am    Post subject: Thrust line? Reply with quote
You might want to consider obtaining or building a set of HD wings for
your airplane, that will significantly improve climb rate with
whatever engine you put in it. You will lose some speed but that will
just give you more time to enjoy the flight. Smile
As I recall, the 601HD was originally designed around a 65 HP engine,
so if you can actually get 80 HP out of a VW conversion and your
density altitude isn't too bad, you should do OK. Fight the urge to
add any unnecessary accessories, keep that empty weight down.
80hp setup.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
