				 Posted: Tue Dec 16, 2008 12:35 pm    Post subject: Brake lines |
				John H.,
   The brake lines furnished to me for free from Bonaco, Inc were their
 offering, not my choice.  He asked for dimensions and these were what I got.
 I agree these would be more appropriate to put on my GlaStar (when I get back
 to working on it someday).
   The truth is I intended to use plastic tubing, like you have, until this offer came about.
   I have looked for the 1/4" plastic tubing, but I'm not sure what I have found is
 appropriate for brake lines.  Icemaker water line just doesn't sound right!!!!
   Does anyone know where to get the CORRECT 1/4" plastic tubing, that would work well
 for brake lines on Matco calipers?  (Yes, I need 1/4", that's the size of my fittings).
 Mike Welch
 MkIII
 Still, it was a hellava nice present for free.
 Suspicious message? There’s an alert for that.
 http://windowslive.com/Explore/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_broad2_122008
		Dana
				 Posted: Tue Dec 16, 2008 4:34 pm    Post subject: Brake lines |
				At 03:34 PM 12/16/2008, Mike Welch wrote:
  found is
  would work well
 my fittings).
 No, icemaker tubing is usually polyethylene.  You want the hard nylon
 tubing, which is rated for much higher pressure... I got mine from
 McMaster-Carr.  You need to know the inside diameter too; they have it in
 several different ID's.
 -Dana
   "The difference between death and taxes is death doesn't get worse every
 time Congress meets." -- Will Rogers
				 Posted: Tue Dec 16, 2008 5:11 pm    Post subject: Brake lines |
				 	  | Quote: | 	 		   No, icemaker tubing is usually polyethylene. You want the hard nylon
  -Dana
 Dana,
   Yeah, I know icemaker tubing wouldn't do.  Polyethylene and polyurethane tubing
 are not strong enough for the job.  I was being facetious.
   I have found a few sources that do sell the high pressure nylon tubing.  Thanks
 for the McMaster-Carr tip.  I'll check with them.
 Mike Welch
 MkIII
 Send e-mail faster without improving your typing skills.
 http://windowslive.com/Explore/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_speed_122008
		ulflyer(at)verizon.net Guest
				 Posted: Tue Dec 16, 2008 6:31 pm    Post subject: Brake lines |
				Aircraft Spruce sells the stuff you need, line & connectors.  You are
 aware that most aircraft brake assembles use red transmission fluid
 not the very corrosive clear hydraulic fluid like used in
 automobiles.  They package cans labeled for aircraft use.
 jerb
 At 06:31 PM 12/16/2008, you wrote:
 > I have found is
 >sound right!!!!
 nylon tubing, which is rated for much higher pressure... I got mine
 from McMaster-Carr.  You need to know the inside diameter too; they
 have it in several different ID's.
 -Dana
				 Posted: Tue Dec 16, 2008 7:16 pm    Post subject: Brake lines |
				 	  | Quote: | 	 		   Aircraft Spruce sells the stuff you need, line & connectors. You are
  jerb
 Thanks Jerb for the Aircraft Spruce reference.  I looked and looked for it there,
 but could never seem to come up with it. I found it, thanks.
   Yes, I'm very much aware of the differences in brake fluid between an airplane
 and a car.  I still have some of my red brake fluid left over from topping off my
 Cessna's brakes.
 Mike Welch
 MkIII
		aslsa.rng(at)gmail.com Guest
				 Posted: Wed Dec 17, 2008 7:50 am    Post subject: Brake lines |
				Mike, You'll need to put a UV shield over it where it's out in the light and it's good for 20 years.
 Rick
 On Tue, Dec 16, 2008 at 2:34 PM, Mike Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)> wrote:
  [quote]--> Kolb-List message posted by: Mike Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)>
  John H.,
  Mike Welch
  MkIII
  Suspicious message? There's an alert for that.
				 Posted: Wed Dec 17, 2008 8:15 am    Post subject: Brake lines |
				Rick:
  If you are referring to the clear plastic brake  line like I am using, mine has no UV shield and it is pushing 18 years  service.
  [quote]   -----
    Rick
  _________________ John Hauck
Titus, Alabama |
		ElleryWeld(at)aol.com Guest
				 Posted: Wed Dec 17, 2008 2:43 pm    Post subject: Brake lines |
				Aircraft Brake fluid is not transmission oil it is  MIL-H-5606 A not anywhere near the same stuff just because it is red in color,  some brake systems have seals that cannot take to oil  like ATF it will  swell the seals up and make them fail
  Use the right fluid for manufacture recommendation  with the brake system you have
  Ellery
   In a message dated 12/16/2008 9:31:41 P.M. Eastern Standard Time,  ulflyer(at)verizon.net writes:
   	  | Quote: | 	 		  -->    Kolb-List message posted by: jerb <ulflyer(at)verizon.net>
 jerb
  	  | Quote: | 	 		  --> Kolb-List message posted by: Dana Hague    <d-m-hague(at)comcast.net>
 > I have found    is
 >sound right!!!!
 -Dana
 time Congress meets."    -- Will  sp;             (And Get Some AWESOME FREE   find  you for                          -Matt Dralle,    List    es  y                 - MATRONICS WEB FORUMS  =========================
 One site keeps you connected to all your email: AOL Mail, Gmail, and Yahoo Mai=emlcntaolcom00000025">Try it now.
				 Posted: Wed Dec 17, 2008 3:07 pm    Post subject: Brake lines |
				 	  | Quote: | 	 		  >>Aircraft Brake fluid is not transmission oil it is MIL-H-5606
 Ellery>>>
 Ellery,
   Important point, and you are correct.  Just because it's red, doesn't mean it is
 okay to use as aircraft brake fluid.  As I stated, though, I do have the correct brake fluid
 for certified aircraft.  Expensive stuff...(always is!!)
   But, your best advice of all is to call the manufacturer and ask what they recommend.
 I have Matco hydraulic brakes and cylinders, and will call them tomorrow.  Thanks.
 Mike Welch
 MkIII
		Dana
				 Posted: Wed Dec 17, 2008 4:38 pm    Post subject: Brake lines |
				At 05:42 PM 12/17/2008, ElleryWeld(at)aol.com wrote:
   	  | Quote: | 	 		  Aircraft Brake fluid is not transmission oil it is MIL-H-5606 A not anywhere near the same stuff just because it is red in color, some brake systems have seals that cannot take to oil  like ATF it will swell the seals up and make them fail
  Use the right fluid for manufacture recommendation with the brake system you have  |
  Part of the confusion may be from the fact that some non certified aircraft brakes (like the Free Bird brakes on my UltraStar) do indeed specify Dexron II or III automatic transmission fluid, which is also red.  ATF must also be compatible with the Hegar master cylinders that control the brakes on my plane, since I've had no trouble.  I can't speak for other types.
  -Dana
   Clothes make the man.  Naked people have little or no influence on society.    [quote][b]
				 Posted: Wed Dec 17, 2008 5:18 pm    Post subject: Brake lines |
				 I know that, that is why i said this
  In a message dated 12/17/2008 7:38:58 P.M. Eastern Standard Time,  d-m-hague(at)comcast.net writes:
   	  | Quote: | 	 		  | Use the right fluid for manufacture recommendation with the    brake system you have  |
  Ellery
 One site keeps you connected to all your email: AOL Mail, Gmail,40vanity&ncid=emlcntaolcom00000025">Try it now.
				 Posted: Wed Dec 17, 2008 6:34 pm    Post subject: Brake lines |
 -Dana
  Dana:
  I have always used ATF in Hegar and Matco  brakes.  However, recently I saw a spec sheet that called for aviation red  fluid for Matco.  I have never had a problem with the ATF, but that is what  both systems called for when I installed them some time ago.
Titus, Alabama |
		Dana
				 Posted: Wed Dec 17, 2008 7:43 pm    Post subject: Brake lines |
				At 09:34 PM 12/17/2008, John Hauck wrote:
  I have always used ATF in Hegar and Matco brakes.  However, recently I saw a spec sheet that called for aviation red fluid for Matco.  I have never had a problem with the ATF, but that is what both systems called for when I installed them some time ago. |
  Both MIL-H-5606 aviation hydraulic fluid and Dexron III ATF are petroleum based fluids (the MSDS's list them as "highly refined oils" with additives).  Both are compatible with Buna-N seals (the most common generic seal material), although there may be other reasons not to use one or the other.  However, there are other types of ATF (ATF+4, Ford Type F, and others) that may have a different base, I don't know.  OTOH, DOT3 and DOT4 automotive brake fluids are a mixture of various glycols, which don't like Buna but are compatible with EPDM rubber seals (but EPDM doesn't like petroleum oils), while DOT5 brake fluid is a silicone base fluid (I once owned a surplus postal Jeep that used DOT5).  Older British cars used a mineral based brake fluid and you could screw them up by using DOT3.
  -Dana
   The greatest threat to western civilization are people whose fear of other people's liberty exceeds the love of their own.    [quote][b]
		Dennis.Kirby(at)kirtland. Guest
				 Posted: Mon Dec 22, 2008 11:40 am    Post subject: Brake lines |
				<Classification:  UNCLASSIFIED
 < Aircraft Brake fluid is not transmission oil … not anywhere near the same stuff just because it is red in color,  Use the right fluid for manufacture recommendation  with the brake system you have. Ellery >>
 Ellery, and Kolb Friends –
 Am happy to report that Matco Mfg (in Utah) recommends automotive Automatic Transmission Fluid for use in their brake systems.  I know this because I called them and asked this very question.  Many of our Kolbs have Matco brakes, including mine.  Being able to use ATF makes it convenient.
 Dennis Kirby
 Cedar Crest, NM
		herbgh(at)nctc.com Guest
				 Posted: Mon Dec 22, 2008 12:08 pm    Post subject: Brake lines |
				the only trouble in using the "right Stuff" ; is ..that it can be and maybe, usually is,  a  generic product with "for aircraft use" written on it at 10 times the price....!! ...    frugal   Herb
  At 01:38 PM 12/22/2008, you wrote:
  [quote]<Classification: UNCLASSIFIED
  Dennis Kirby
  Cedar Crest, NM
				 Posted: Mon Dec 22, 2008 12:32 pm    Post subject: Brake lines |
				Considering this thread, I wondered why cars use glycol-based fluid instead of a straight mineral oil.It must have to do with early seal rubber longevity.  The boiling point  difference between ATF and glycol can't be large.
 Mineral would seem to be superior if only for the lack of hygroscopic quality.
 BTW, I changed the seals in my matco wheel cylinders so I could use car fluid in them and my dune buggy master cylinder.
 BB
 On 22, Dec 2008, at 3:07 PM, herb wrote:
  the only trouble in using the "right Stuff" ; is ..that it can be and maybe, usually is,  a  generic product with "for aircraft use" written on it at 10 times the price....!! ....    frugal   Herb
   	  | Quote: | 	 		  <Classification: UNCLASSIFIED
  Dennis Kirby
  Cedar Crest, NM
  | 	  [b]
		Dana
				 Posted: Mon Dec 22, 2008 3:44 pm    Post subject: Brake lines |
				At 03:31 PM 12/22/2008, robert bean wrote:
  	  | Quote: | 	 		  Considering this thread, I wondered why cars use glycol-based fluid
 I don't know for sure, but perhaps for flammability issues?  Oil could burn
 if it springs a leak on hot brake components?  Pretty sure glycol isn't
 flammable.
 -Dana
   To Be Old And Wise You Must First Be Young And Stupid
				 Posted: Mon Dec 22, 2008 8:10 pm    Post subject: Brake lines |
				Dennis I know that some Brake systems  use ATF I  was just pointing out that ATF and aircraft brake fluid 5606-A are both Red in  color but not The same liquid  Make sure you all use the correct Fluid  for your system
  Ellery in Maine
   In a message dated 12/22/2008 3:08:25 P.M. Eastern Standard Time,  herbgh(at)nctc.com writes:
 Dennis      Kirby
 Cedar Crest, NM
 ://www.matronics.com/contribution">http://www.matronics.com/contribution
 ="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
 .matronics.com/">http://forums.matronics.com
 One site keeps you connected to all your email: AOL Mail, Gmail, and Yahoo Md=emlcntaolcom00000025">Try it now.
		by0ung(at)brigham.net Guest
				 Posted: Tue Dec 23, 2008 8:09 am    Post subject: Brake lines |
				Interesting that they tell you that on the phone…..   and still the document that come with the master cylindars for matco say “This assembly requires  MIL-H-5606 red aircraft fluid”
 Maybe the post that says that the BUNA N orings tolerate either the MIL or the ATF  equally well.
 Boyd
 MKIIIC
 Utah
 Dennis Kirby
 Cedar Crest, NM
				 Posted: Tue Dec 23, 2008 9:17 am    Post subject: Brake lines |
				Sorry I hit send with only ½ a thought there….
 Maybe the post a week or so ago, that said that the BUNA N o rings tolerate either the MIL H 5606 or the ATF  equally well,        has a lot of merit.
 Interesting that they tell you that on the phone…..   and still the document that come with the master cylinders for Matco say “This assembly requires  MIL-H-5606 red aircraft fluid”
 Maybe the post that says that the BUNA N o rings tolerate either the MIL or the ATF  equally well.
 Boyd
 MKIIIC
 Utah
 Dennis Kirby
 Cedar Crest, NM
