		pascal(at)rv10builder.net Guest
				 Posted: Thu Dec 18, 2008 8:59 am    Post subject: canopy top smoothing/priming |
  Sent: Thursday, December 18, 2008 8:57 AM
  Subject: canopy top smoothing/priming
  Looking for a good way to smooth (aka fill pin holes) on the  canopy top as well as prime. I know there is Smooth Prime but that is a  "smoother" than requires another coat of actual primer. Many reasons I am trying  to avoid doing the multiple layers.
  Also any suggestions for how I should go about doing the  canopy top. I gather based on my review of the top that laying a filler primer  wont get it all, is the idea to do a coat of .5/.5 acetone/epoxy with some  balloons before spraying filler needed? anything else I should be  considering?
  Thanks!
  Pascal
		Jim Berry
				 Posted: Thu Dec 18, 2008 9:40 am    Post subject: Re: canopy top smoothing/priming |
				Pascal,
 On the recommendation of a buddy who does composite work full-time, I used PPG acrylic urethane primer K36 with K201 catalyst. Applied with a 3" Shur-line roller( about $1.50 ea from Home Depot; get several). Apply the first coat with moderate pressure to work the primer into the pin holes. By the time you finish the first coat you can go back to your starting point and apply another coat. You want 3-4 coats total. The roller will start to disintegrate and leave little pieces of foam in the primer, which is no problem as you will be sanding almost all of the primer off. Let the primer cure for 2-3 days, depending on your shop temperature. Block sand to remove orange peel, bits of roller foam, etc. Spray a final coat of primer, and you are done. I think I wound up with 6 pin holes that had to be filled individually. I also used this method on all other composite pieces.
 Jim Berry
 40482
		jcumins(at)jcis.net Guest
				 Posted: Thu Dec 18, 2008 9:41 am    Post subject: canopy top smoothing/priming |
				Pascal
 There is a product that is designed for just that I will try and look it up and send it to you .  It is not a filler primer but a filler then you pay the primer on top of that.
 John G. Cumins
 President
 JC'S Interactive Systems
 2499 B1 Martin Rd
 Fairfield Ca 94533
 707-425-7100
 707-425-7576 Fax
 Your Total Technology Solution Provider
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pascal
  Sent: Thursday, December 18, 2008 8:58 AM
  Subject: Re: canopy top smoothing/priming
 Thanks!
 Pascal
    	  | Quote: | 	 		  |   http://www.matronics.com/contribution  | 	  01234567890123
		msausen
  Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
				 Posted: Thu Dec 18, 2008 10:02 am    Post subject: canopy top smoothing/priming |
				Pascal,
   You left out a critical part of the name below.  It’s actually called UV Smooth Prime and also acts as a UV blocker for composite parts which is critical.  UV WILL breakdown our composites eventually making them brittle.  Whatever you use make sure it has a UV inhibitor in it or you put it on thick enough to have enough solids to do the job.
 Michael
  Sent: Thursday, December 18, 2008 10:58 AM
 Thanks!
 Pascal
		ricksked(at)embarqmail.co Guest
				 Posted: Thu Dec 18, 2008 10:13 am    Post subject: canopy top smoothing/priming |
				Having filled way too many glass parts now and before I find one of the biggest time saving steps is to clean the part with soap and water, wipe clean with acetone, sand any gloss off the surface, clean with acetone again then apply epoxy resin to the entire surface using a playing card, they are abundunt here in Vegas   or old credit cards (they last longer) to press the epoxy into all the pinholes, scrape the entire surface with the cards. Once it is cured sand the rmove the gloss and fuzz. Apply any of the high fill epoxy primers, use the same brand as the top coat you are planning to use, sprayed then sanded almost all the way off will start the process. I don't recommend rolling/brushing because the first coats should be almost sanded away, rolling applies more than you need and the epoxy process seals and fills the pinholes so minimal primer is usually needed. Once the pinholes have disappeared fill any exposed weave and imperfections with micro/epoxy prime and sand until you acheive the smoothness you desire or just say that's good enough, I quit. It sounds like more work than it is but that's the process that has worked well for me. There is no looks great with minimal work method I have found, sanding-priming-sanding-priming always made for the best prep. This works well on the pants, cowl, doors, top, all the parts.
 Rick Sked
 40185
		dlm46007(at)cox.net Guest
				 Posted: Thu Dec 18, 2008 10:33 am    Post subject: canopy top smoothing/priming |
				spread and spray by Sherman Williams is the primer/filler  used by Piper and their fiberglass starts pretty rough (about like  Vans).
 Sent: Thursday, December 18, 2008 9:58 AM
 To:  rv10-list(at)matronics.com
  Thanks!
  Pascal
 href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
				 Posted: Thu Dec 18, 2008 10:38 am    Post subject: canopy top smoothing/priming |
				Good point, I'll be using a paint that has the UV protection  in it, Same one used for corvettes and such.
  Thanks for pointing that out.
  Pascal
   From: RV Builder (Michael Sausen) (rvbuilder(at)sausen.net)
  Sent: Thursday, December 18, 2008 9:59 AM
  Subject: RE: Re: canopy top  smoothing/priming
 Pascal,
 Michael
 Thanks!
 Pascal
 4   [quote][b]
				 Posted: Thu Dec 18, 2008 10:44 am    Post subject: canopy top smoothing/priming |
				Rick and all that responded, thank you for the guidance with this. I had an
 idea and your feedback has allowed me to use my brain cells to think about
 something else now.
 Thanks all!
 Pascal
 Sent: Thursday, December 18, 2008 10:12 AM
 Subject: Re: Re: canopy top smoothing/priming
  imperfections with micro/epoxy prime and sand u!
  Rick Sked
  40185
				 Posted: Thu Dec 18, 2008 10:57 am    Post subject: canopy top smoothing/priming |
				pascal wrote:
  *Sent:* Thursday, December 18, 2008 8:57 AM
  *To:* rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>
  *Subject:* canopy top smoothing/priming
 If you really want it to come out nice, you need the multiple layers
 .... you'll be sanding most all of it off, but it really needs to be done.
  	  | Quote: | 	 		   Also any suggestions for how I should go about doing the canopy top. I
  considering?
 I wouldn't do the epoxy route because it won't be smoother than the top
 is now, and you do not want to trap air in the pinholes .... the chances
 of them creating bubbles down the road is high.  Sanding out the Smooth
 Prime is much easier than sanding the epoxy.
 It's a lot of work and it's messy (dusty) but the Smooth Prime is my
 choice, followed by a urethane primer for the paint to adhere to.
 Linn
  	  | Quote: | 	 		   Thanks!
  Pascal
		toaster73(at)embarqmail.c Guest
				 Posted: Thu Dec 18, 2008 11:03 am    Post subject: canopy top smoothing/priming |
				Van's and Loehle aviation were raving about the Loehle product called
 Wonderfil to take care of the pinholes, there was an article in the latest
 RVator. I plan to try it.
 -Chris Lucas
  #40072
				 Posted: Thu Dec 18, 2008 11:08 am    Post subject: canopy top smoothing/priming |
				I agree with almost all Rick says here ..... but instead of the epoxy,
 use the card to apply the first one (or maybe two) coat of _UV_ Smooth
 Prime (thanks Michael for the reminder) and roll the subsequent layers.
 That epoxy gets hard and I'm a little on the lazy side!!!  You can also
 lightly (really lightly, like a mist) spray black paint on top of the UV
 Smooth Prime which will really highlight the highs and lows when you
 start to sand.  Alternate with another dark color (such as blue) between
 successive coats.
 Linn_
 _Rick Sked wrote:
  Having filled way too many glass parts now and before I find one of the biggest time saving steps is to clean the part with soap and water, wipe clean with acetone, sand any gloss off the surface, clean with acetone again then apply epoxy resin to the entire surface using a playing card, they are abundunt here in Vegas   or old credit cards (they last longer) to press the epoxy into all the pinholes, scrape the entire surface with the cards. Once it is cured sand the rmove the gloss and fuzz. Apply any of the high fill epoxy primers, use the same brand as the top coat you are planning to use, sprayed then sanded almost all the way off will start the process. I don't recommend rolling/brushing because the first coats should be almost sanded away, rolling applies more than you need and the epoxy process seals and fills the pinholes so minimal primer is usually needed. Once the pinholes have disappeared fill any exposed weave and imperfections with micro/epoxy prime and sand u!
  Rick Sked
  40185
		gengrumpy(at)aol.com Guest
				 Posted: Thu Dec 18, 2008 3:46 pm    Post subject: canopy top smoothing/priming |
				That was my RV 10 in the picture, and I can personally attest to the
 superb qualities of Mike Loehle's products!
 Grumpy N184JM
  called Wonderfil to take care of the pinholes, there was an article
  in the latest RVator. I plan to try it.
  -Chris Lucas
  #40072
