		jcumins(at)jcis.net Guest
				 Posted: Sat Dec 20, 2008 8:28 pm    Post subject: HS attach bracket issue |
				BODY { font-family:Arial, Helvetica, sans-serif;font-size:12px; } Well all you rv10 buikders out there.  Looks like i finally mide my first big boo boo.  And I will call Vans Monday morning.
 When i final drilled the left and rt horv. stab fwd spar attach brackets i made sure to clamp both of them to a piece of angle stock so that they were final drilled parrallel to each other.
 Well when i went to rivit them on today all looked well and i did not think to reclamp them to a piece of angle stock.  Now here comes the probelm.  The Left bracket is about 1/32 of a inch oft of parallel to the other.  When i clap the angle stock to the rt bracket it contacts the inboard edge of the left bracket like it should.
 When i clamp the angle stock to the left bracket it misses the rt bracket by a bunch. so this telles me the left bracket is not parallel.
 I do think that it probable should be fixed, to prevent a twisting force on the bracket, rivits and HS fwd spar.
 My question is can i just shave a very small amount off the inboard side of the left bracket bottom to get them back parallel, would this be a ok repair or should i make new bracket and redo it.
 I do think i will order the material to make a new on or order one already made from the company that makes them on a cnc machine.
 Boy was this very upsetting to find when i was finished with the front spar.
 Word of advice would be greatly appreciated,
 Thanks.
 John
 Horz Stab build mode
 SN 40864
		pascal(at)rv10builder.net Guest
				 Posted: Sat Dec 20, 2008 8:44 pm    Post subject: HS attach bracket issue |
				send me the plans page and step so I can see where you are and  try to remember what I did at that point.
  Pascal
  Sent: Saturday, December 20, 2008 8:26 PM
  Subject: HS attach bracket issue
 Thanks.
 John
 SN 40864
 href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
		rene(at)felker.com Guest
				 Posted: Sat Dec 20, 2008 8:50 pm    Post subject: HS attach bracket issue |
				Just an Idea, but since it looks like they were parallel when you drilled them, just drill out the rivets…..clamp them down and re-rivet.
 Rene'
 801-721-6080
		tsts4
				 Posted: Sun Dec 21, 2008 4:23 pm    Post subject: Re: HS attach bracket issue |
				Another option would be to shim it back to level.  When you attach the HS to the tailcone, two 1/8 shims get match drilled and placed under each bracket anyway.  So adding a 3rd,  thin shim to the stack shouldn't be a problem.
  _________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
				 Posted: Sun Dec 21, 2008 10:32 pm    Post subject: HS attach bracket issue |
				Rene
 I did just that this afternoon and it looks like i am good to go.  Bracket is re-rivited and parralel to the other.
 thanks so much
   On Sat 20/12/08 8:50 PM , "Rene" rene(at)felker.com sent:
 Rene'
 801-721-6080
				 Posted: Mon Dec 22, 2008 4:38 pm    Post subject: HS attach bracket issue |
				Rene’
 Your idea worked great.  Thanks so much.  Next time I am in SLC I will look you up.
 John G. Cumins
 President
 JC'S Interactive Systems
 2499 B1 Martin Rd
 Fairfield Ca 94533
 707-425-7100
 707-425-7576 Fax
 Your Total Technology Solution Provider
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene
  Sent: Saturday, December 20, 2008 8:50 PM
  Subject: RE: HS attach bracket issue
 Rene'
 801-721-6080
