More on the XL grounding
Goto page 1, 2  Next
aerobat
PostPosted: Mon Dec 22, 2008 3:09 am    Post subject: More on the XL grounding Reply with quote
Since the grounding the UK have had their stress engineers and sophisticated computer software working very hard to address the situation. They have come across areas of concern that have been sent to the designer but as yet no reply is forthcoming.
Is this because he does not want to acknowledge any potential problem for fear of being sued over several wing failures ?
If there is a problem the sooner this is rectified the better - before another aeroplane for whatever causes has the wings drop off.
Rumour has it that if the designer does not respond to the LAAs very fair questions then in consultation with the FAA and European authorities the XL will be limited worldwide to the German limitations of Max 450kg ( 990lb ) VNE 97kts and no baggage.
alex_001
PostPosted: Mon Dec 22, 2008 4:38 am    Post subject: Re: More on the XL grounding Reply with quote
450kg MTOW that would mean for most 601xl that the aircraft would be a single seater plane ( i guess 330kg empty plus 85kg pilot leaves 35kg fuel) no allowance for pax.
Do you have any more info from the LAA?
BTW i looked a year ago at the CZAW sportcruiser wings and they did not look so different from the XL wings
psm(at)att.net
PostPosted: Mon Dec 22, 2008 4:54 am    Post subject: More on the XL grounding Reply with quote
I have a few questions for you "Aerobat".
1. Who are you, and where are you located? Apparently you are
ashamed of your name or just want to fool everyone without taking any
responsibility for your stupid comments. I presume you must be in
some Socialist or Communist country. Also, I would guess you are not
yet of legal age and probably don't own a Zodiac or any other airplane.
2. Where did you get the childish notion that the whole world could
agree on anything? In particular, what gives you the idea that a
plane can be grounded or limited to the same limits in every country
of the world?
3. Why do you continue to post such outrageous comments on the
Zodiac list? Surely, it is not because you think the list members
would be happy to hear your uninformed opinions.
Paul
XL getting close
Gig Giacona
PostPosted: Mon Dec 22, 2008 6:05 am    Post subject: Re: More on the XL grounding Reply with quote
Let's see, Aerobat has posted a total of 6 times recorded in the Matronics database. And guess what every single post has been about.
W.R. "Gig" Giacona
601XL Under Construction
jaybannist(at)cs.com
PostPosted: Mon Dec 22, 2008 6:40 am    Post subject: More on the XL grounding Reply with quote
Gig - Are you saying that Aerobat is really a Dingbat? (Dingbats do use "rumor has it" as an authentic information source)
jmaynard
PostPosted: Mon Dec 22, 2008 8:14 am    Post subject: More on the XL grounding Reply with quote
Indeed. His posts have the distinct odor of troll about them. Unless and
until he provides some facts that demonstrate he's actually got a real
interest in the Zodiac as an owner or pilot, I intend to ignore him, and
suggest the rest of us do the same. We need facts, not uninformed
speculation and rumor.
If the weather ever clears in Minnesota, I'm going to go flying in my XLi,
within the limits as set by the designer and factory, not as rumored by
someone who shows no evidence that he's not, say, a competitor trying to
destroy the Zodiac's reputation so he can sell more airplanes.
Jay Maynard, K5ZC, PP-ASEL http://www.conmicro.com
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC
rans6andrew
PostPosted: Mon Dec 22, 2008 8:25 am    Post subject: Re: More on the XL grounding Reply with quote
aerobat is the only poster in this thread whose location is in the text below his name on the left side of the page. It says UK. Sounds good enough for me.
Just to avoid confusion I am Andrew Cattell, I am located in the UK. I am building a 601UL. I have been told by the LAA (email end of November) that they don't have any concerns over the the UL and HD varients. They would not be drawn on what they might have found on the XL as it is not an issue for my build.
Reading this thread, and the others related to apparent XL wing failures, together with what they have told me directly, I would think that the LAA has found something with the XL wing but are not releasing the information to the world at large until the designer has had time to comment. This would seem to be a reasonable courtesy. It is for this reason that the "rumour has it" is employed.
I may be wrong, of course, but that's how it looks from my position.
Andrew.
A good way through building a 601UL with 912UL.
Still flying Rans S6 with 503.
GBzodiflyer
PostPosted: Mon Dec 22, 2008 10:36 am    Post subject: Re: More on the XL grounding Reply with quote
I have also heard this , but have not listed it because clearly all we get back for our concerns , is name calling , what is wrong with you people over there , we all have flying xl s, that we built .
when u guys get grounded or have a restriction slapped on your aircraft maybe you will see it from our point of view
I thought aviators and builders tended to stick together.
there are no bad remarks from competitors here . if you are still building a fix is not to much of an issue , If your done and flying , or not at the moment , it could be major work to tear it down again .
grow up the name callers .
Gary
psm(at)att.net
PostPosted: Mon Dec 22, 2008 11:22 am    Post subject: More on the XL grounding Reply with quote
Hi Gary,
I appreciate your comments and concerns.
For those of you in Europe and other "Foreign" countries, to my
knowledge there is no way American XLs can be grounded. There just
isn't any authority that can do that. The FAA could ground part 23
certified aircraft, but the XL isn't one of those. I refer to the
Experimental-Amateur Built certified planes. This might be different
for the few AMD built planes that are indeed certified. I have no
idea what authority the FAA has over LSA certificated planes.
As I understand the rules situation, once an experimental
airworthiness certificate is issued for an American plane the
government is mostly finished with it. It is the owner/operator who
must decide what limits to operate that plane under. The
airworthiness certificate does include operating limitations, but I
have never heard of the government here grounding an experimental
plane or suggesting speed limits or load limits for one. The
limitations issued with the certificate are "Boiler Plate" ones that
are issued without regard to the actual design model or builder of the plane.
I admit throwing a few stones at "Aerobat" over his highly
opinionated and misinformed posts. I hope we all try to
differentiate between facts and opinions and label our comments appropriately.
As I mentioned earlier, folks on these lists tend to include their
name and sometimes their location in their posts. Anyone who is
unwilling to include their name immediately attracts distrust.
Paul
XL getting close
Gary
paulrod36(at)msn.com
PostPosted: Mon Dec 22, 2008 12:15 pm    Post subject: More on the XL grounding Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Gig and Jay, there's the flaw in your logic. "rumor has it" has long been discredited. "Some Say" is the more authoritative source.
Merry Chistmas
Paul Rodriguez
DO NOT ARCHIVE
dougsire
PostPosted: Mon Dec 22, 2008 12:17 pm    Post subject: Re: More on the XL grounding Reply with quote
To our Zenith friends around the world,
On behalf of all Americans who realize that the UK is not filled with commies, please accept our apologies for the occasional "Ugly American" rants you will find on these forums. If it is any consolation, these tirades are usually nondiscriminatory in who they try to offend.
I too have seen a structural analysis of the 601XL wing which has given me enough concern that I won't go any further with my project without some structural enhancements.
This topic has been beaten to death and beyond on these lists, and I think everyone has some level of concern, even if they won't admit it (remember folks, denial isn't just a river in Australia....). I can understand that it must be very frustrating to have a completed aircraft that you can't fly. We sympathize with you and hope for a speedy resolution.
Doug Sire
Billings, MT
601XL
Doug Sire 601XL
pavel569
PostPosted: Mon Dec 22, 2008 12:44 pm    Post subject: Re: More on the XL grounding Reply with quote
Could you be more specific?
Pavel
CA
Zodiac 601XL
Stratus Subaru EA-81
Tail, flaps, ailerons, wings, fuselage, canopy done ...
"do not archive"
Gig Giacona
PostPosted: Mon Dec 22, 2008 2:59 pm    Post subject: Re: More on the XL grounding Reply with quote
Doug Sire
Billings, MT
601XL
First, I don't give a crap where aerobat is from. I'll be honest that I didn't even look to see. What I did look at is that he has posted 6 times to the Matronics lists and they have all been attack posts. He has never posted with a question or answer about building or flying a CH design (or any other design for that matter).
Second, where exactly did you see this information? Could it have been in a post from an anonymous poster like aerobat? By God man if you have information share it.
W.R. "Gig" Giacona
jmaynard
PostPosted: Mon Dec 22, 2008 3:01 pm    Post subject: More on the XL grounding Reply with quote
over there , we all have flying xl s, that we built . when u guys get
it from our point of view I thought aviators and builders tended to stick
together. there are no bad remarks from competitors here . if you are
Gary, you say "there are no bad remarks from competitors here" - but there
have indeed been such in the past. There's been a lot of mud slung at the XL
by folks who want to build up the competition and tear down the Zodiac.
The rumor was that "the FAA will restrict the XL to 450 kg and 97 knots".
First, we're talking about apples and oranges here: the American XL is
different from the European XL. The European aircraft was not designed to a
600 kg max gross in the firstplace, due to the European equivalent to the
light sport rule having that as a maximum limit. That leads to a lighter
airframe requirement. My Zodiac has an empty weight of 850 pounds (385 kg).
That would make it essentially impossible to fly with a 990 pound max gross,
especially since I weigh 200 pounds. Further, the American XL was designed
for a max gross of 1450 pounds (658 kg); its 1320 pound (600 kg) official
max gross is an artifact of the US LSA rules. In the US, I don't know if the
AD process applies to LSAs; if not, then such a directive would have to come
from AMD for factory LSA such as mine, and I'm not at all sure they'd agree
to it.
My name, aircraft registration number, and ham radio callsign are all in the
signature below. I stand behind my words, and it's easy to verify that I'm
who I say I am and that I do indeed own and fly a Zodiac XLi, N55ZC. There
have been lots of anonymous, or effectively anonymous, detractors posting on
the list. Why won't they stand behind their words? Why won't they tell us
who they are? That is severely damaging to their credibility. Yes, aviators
stick together, and need to - but I have no reason to believe that "aerobat"
is part of the community.
There may be a problem with the Zodiac's structure, and if so, I have every
confidence that Chris Heintz will own up to it and issue a fix. Until we get
real information, however, speculation - especially on the basis of the
Dutch grounding (and that they grounded the aircraft and promptly left on a
month's vacation speaks volumes about their professionalism) - helps nobody.
It doesn't help builders, it doesn't help owners, it doesn't help pilots, it
doesn't help the authorities, and it doesn't help Zenair and its affiliated
companies. The only folks it does help are the folks building aircraft and
kits that compete with the Zodiac, and, as far as I'm concerned, they can
damned well fend for themselves in the marketplace without the help of dirty
tricks.
Jay Maynard, K5ZC
jmaynard
PostPosted: Mon Dec 22, 2008 3:05 pm    Post subject: More on the XL grounding Reply with quote
FWIW, I don't care where someone posts from. Uninformed speculation and
rumormongering is harmful whether it comes from the UK, the US, or
elsewhere.
The only structural analysis I've seen (the preliminary report from the
ZBAG) shows that the wing is adequately designed to meet the stated loads.
It's not as overbuilt as some, but the nature of light sport aircraft limits
how much overbuilding is possible.
I agree. If my aircraft were grounded by some governmental official who
couldn't be bothered to do his job instead of taking off on vacation and
leaving nobody to resolve the issue, as the Dutch did, I'd be furious.
However, I wouldn't be spreading derogatory rumors about it, especially
without standing behind my words.
Jay Maynard, K5ZC
eldenej(at)yahoo.com
PostPosted: Mon Dec 22, 2008 3:17 pm    Post subject: More on the XL grounding Reply with quote
"I, too, have seen a structural analysis that has given me...concern..." I suspect nearly all of us would much appreciate an elaboration of this.
Elden Jacobson
xl/3300
--- On Tue, 12/23/08, dougsire <dsire(at)imt.net> wrote:
Subject: Re: More on the XL grounding
Date: Tuesday, December 23, 2008, 4:17 AM
<dsire(at)imt.net>
aerobat
PostPosted: Mon Dec 22, 2008 4:05 pm    Post subject: Re: More on the XL grounding Reply with quote
The reason my posts are all on the same subject is quite simple, I own a Czech 601XL.
An aeroplane that I am extremely fond of, over the years I have had a dozen or more different types but the XL is my favourite.
The only problem is wings keep falling off them and I really want to know why.
I am just a fifteen thousand hour pilot with no in depth engineering knowledge but our UK LAA is a highly respected professional body and if they are worried about the wing then so am I.
I treat this forum like when I go to the bar with my friends, we discuss things we have heard, not everything is a hard fact but but maybe passed on second hand and an awful lot of rumours do turn out to be fact.
A lot of people here seem to suffer from head in the sand syndrome, all I want is a fix for the XL before it kills anyone else.
If another one crashes and the designer is found to have received information from the LAA and ignored, it how much do you think he will be sued for ?
ggower_99(at)yahoo.com
PostPosted: Mon Dec 22, 2008 4:42 pm    Post subject: More on the XL grounding Reply with quote
Paid Spammer by a "Competitor"... This simple.
--- On Mon, 12/22/08, jaybannist(at)cs.com <jaybannist(at)cs.com> wrote:
[quote]From: jaybannist(at)cs.com <jaybannist(at)cs.com>
Subject: Re: Re: More on the XL grounding
Date: Monday, December 22, 2008, 9:39 AM
rsteele(at)rjsit.com
PostPosted: Mon Dec 22, 2008 4:53 pm    Post subject: More on the XL grounding Reply with quote
I'm curious how long the LAA has been analyzing this problem. Have
they found a problem in a few weeks that others have been spending
months if not years searching for? If so I'm really impressed, and
they won't confirm it. I'm just as concerned about this as anyone
else, but this scenario just doesn't add up. My head isn't in the
sand, but my BS meter is pegged.
The more people vetting a design the better. The problem here is that
the only people who actually have confirmed having done an analysis
haven't found a problem.
Ron
On Dec 22, 2008, at 7:05 PM, aerobat wrote:
<rhood2000(at)hotmail.com>
own a Czech 601XL.
know why.
to be fact.
will be sued for ?
http://forums.matronics.com/viewtopic.php?p 20645#220645
Gig Giacona
PostPosted: Mon Dec 22, 2008 5:03 pm    Post subject: Re: More on the XL grounding Reply with quote
So it is your habit to walk into bars and say nothing but negatives and rumors about the key interest of the rest of the customers.
Man, I bet you get beat up a lot.
W.R. "Gig" Giacona
Goto page 1, 2  Next
Page 1 of 2
