Float Flyr
Posted: Tue Dec 23, 2008 5:37 pm Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
Leonard:
If you can get some profile pics of the skis front on, side on and top down.
This could be interesting. Also ask a few of the guys who fly them what
they think.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Tue Dec 23, 2008 6:55 pm Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
What I was trying to describe was the shape of the bottom of those
Wipaire Air Glide skis which (in the Aviat Husky picture on the cover
of Aircraft Owner http://www.aircraftowneronline.com/45/index.cfm
(or the picture that Randy posted)) seem to have a stepped bottom.
That is, it appears to have the outer half (from side-to-side) raised
higher than the inner half. I think this is a trick of the camera
angle. Try this: take a piece of paper and draw a square with a
pencil on it. Make the square about 1" on all sides. Now draw a
rectangle on the lower left side of the square. The rectangle should
be about 1 - 1/2" long and attached to the square. You're trying to
make it look roughly like the footprint of the ski pictured below:
Now cut out this shape, and curl the paper slightly in the long
dimension so that it becomes concave like the top of the ski. It
might help if you draw the wear bars onto the bottom of the ski like
the Husky picture shows. Now hold the paper ski up in front of you,
and closing one eye (so you eliminate the 3-dimensional aspect...this
is what the camera does after all) look at the very front of the
ski...the wide part....head on, just like in the *airplane's* left
ski in the Husky ad. Now rotate it slowly upwards as if the plane it
was on was taking off/rotating right toward you. At a very slight
angle above horizontal, you will perceive what appears to be a step
on the bottom, where the side where the wheel would be (the outside
of the ski) looks like it is raised above the inner half of the ski
bottom. I maintain that this isn't a step on the bottom, but an
illusion...like the "bent" propellor in the Husky picture.
I'm not really thinking that they SHOULD be stepped
On Dec 23, 2008, at 6:27 PM, akflyer wrote:
Quote: |
Lynn,
I will try and get you pics of the ski's tomorrow, I think they
have a few of them out at the airport.
You are thinking way too much on the shape of the bottoms and how
they actuate. It is much simpler, unless I am way off in left
field ( I spend alot of time there these days) and you lost me on
what you were trying to describe.
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
As done as any plane will ever be.... cause now the tinkeritis
takes over.
hander outer of humorless darwin awards
http://forums.matronics.com/viewtopic.php?p 20839#220839
Description: |
Filesize: |
360.14 KB |
Viewed: |
263 Time(s) |
Description: |
Filesize: |
42.94 KB |
Viewed: |
261 Time(s) |
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Wed Dec 24, 2008 11:10 am Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
My eyes are playing tricks on me... The wheels are retracted so that side
of the ski appears to be higher. The main gear not only moves up but
forward as well.
Noel
Kitfox III-A
Lynn Matteson
Posted: Wed Dec 24, 2008 12:20 pm Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
Actually, Noel, the main gear doesn't move at all. It is the ski that
moves down and rearward to make the wheels' new position of being
forward and above the ski.
Your eyes ARE playing tricks on you, but I don't think it's because
of what you think. I think...and this is only my view, with no proof
without seeing the ski...that, well, I've gone into much detail to
describe what I think..no point in repeating myself. Read and make
the little paper ski as I described yesterday, and you'll see.
Lynn Matteson
Jabiru 2200, #2062, 596+ hrs
Sensenich 62x46
flying again after rebuild, and new Electroair direct-fire ignition
system;
also building a new pair of snow skis
that side
forward as well.
Noel
N369LM |
rjdaugh
Posted: Wed Dec 24, 2008 1:34 pm Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
Man, I am anxious to see the actual ski or have someone describe them or
provide more pictures.
I still think that they are made for two levels of support. I will give you
the prop as optical illusion, but the shape of the tips of the skis says
that they are not symmetrical. I think that that is because of the two
levels.
Randy - Assuming I am correct until proven wrong....
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
Lynn Matteson
Posted: Wed Dec 24, 2008 2:55 pm Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
Me too, Randy.
As much as I think the two levels would be a good idea, I just don't
think they are built that way. Try this...look at the Aircraft Owner
picture and cover up the lower end of the ski....the "step"
disappears, because there is no reference to depth anymore. I'd love
to be proven wrong about this, because it would give me a new design
thing to worry about, but until then, I'm stickin' to my
guns....damn, I wish I had got down on the floor at Osh and really
looked those things over better.
Lynn Matteson
Sensenich 62x46
system;
On Dec 24, 2008, at 4:13 PM, Randy Daughenbaugh wrote:
<rjdaugh(at)rapidnet.com>
them or
give you
says
the two
levels.
N369LM |
akflyer
Posted: Thu Dec 25, 2008 8:53 am Post subject: Re: Skis - Solve the |
rjdaugh wrote: | Man, I am anxious to see the actual ski or have someone describe them or
levels.
The ski bottoms are NOT stepped, they are flat. I was going to get pics for you guys yesterday, but the hangar was locked up tight and the guy is on vacation in Hawaii.
Me thinks the pic is playing tricks on you guys lol.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Lynn Matteson
Posted: Thu Dec 25, 2008 9:33 am Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
The mind is a terrible thing to have tricks played on it.... : )
Lynn Matteson
Sensenich 62x46
system;
On Dec 25, 2008, at 11:53 AM, akflyer wrote:
Quote: |
> them or
> will give you
> skis says
> the two
> levels.
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
takes over.
http://forums.matronics.com/viewtopic.php?p 21066#221066
N369LM |
Lynn Matteson
Posted: Thu Dec 25, 2008 9:39 am Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
Not to gloat, but we weren't ALL tricked by the picture, were we? : )
Two optical illusions in one picture...Houdini would have been
proud...or Ansel Adams....
Lynn Matteson
Sensenich 62x46
system;
Quote: |
> them or
> will give you
> skis says
> the two
> levels.
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
takes over.
N369LM |
Float Flyr
Lynn Matteson
Posted: Sat Dec 27, 2008 12:44 pm Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
Yup...pretty sure he developed (no pun) the Zone System, but not sure
about the longer lens thing. He was big on large format...4x5, 8x10,
etc., and maybe even 11x16.
Lynn Matteson
Sensenich 62x46
system;
On Dec 27, 2008, at 10:10 AM, Noel Loveys wrote:
Funny you mention Ansel Adams... Wasn't he the one who developed
zone IV
and using longer lenses to try to get absloutly true
representations
Me I love to lie with the camera.
Noel
N369LM |
Float Flyr
