Jim Berry
Posted: Fri Dec 26, 2008 8:30 am Post subject: Aileron and rudder trim position indicators |
To all of you flying with aileron and/or rudder trim, do you have trim position indicators and do you find then useful? Thanks.
Jim Berry
40482
rene(at)felker.com Guest
Posted: Fri Dec 26, 2008 2:53 pm Post subject: Aileron and rudder trim position indicators |
I use my GRT EFIS for elevator and aileron trim indication. Work great and
they are very useful....preflight being the most useful time. I have a
separate indicator for the rudder trim......not sure it is as useful. The
rudder trim does not have much authority and I just center the ball with it
once I get into a steady state....climb, decent or level flight.
Also, I did not put in a flap indicator and I regret it. I am doing it this
annual. I put markers on my flaps and use the P-1 LOT device (pilot..me),
but don't like having to turn my head to see the flaps during pre landing
checks. I have a flap positioning system, but like to check flap position on
final......
Rene'
801-721-6080
Tim Olson
Posted: Fri Dec 26, 2008 5:04 pm Post subject: Aileron and rudder trim position indicators |
You probably don't need anything on the rudder trim, but it's actually
nice to see where it's set for the aileron trim.
Jim Berry wrote:
Jim Berry 40482
http://forums.matronics.com/viewtopic.php?p 21213#221213
Jim Berry
Posted: Fri Dec 26, 2008 5:09 pm Post subject: Re: Aileron and rudder trim position indicators |
Rene'
Thanks for the info. Your response prompts another question. I am just finishing up my rudder trim a la Tim, Vic and others. They both used 11" of hinge for their tab. If you do not have enough rudder trim authority, how much tab do you have and how much do you think it would take to have enough authority? If I am going to need more tab, now would be the ideal time to change it.
Jim Berry
40482
Tim Olson
Posted: Fri Dec 26, 2008 5:21 pm Post subject: Aileron and rudder trim position indicators |
Jim,
I HOPEFULLY will get this right for Rene', but I don't think he
meant to say it doesn't have ENOUGH authority, more that it
doesn't TAKE much authority. The amount of trim required
is pretty small. With the 10-11" of hinge that I have, it
doesn't need to move very far, and you can easily see the effect
with the skid ball.
Jim Berry wrote:
Rene'
Jim Berry 40482
http://forums.matronics.com/viewtopic.php?p 21282#221282
Posted: Fri Dec 26, 2008 6:36 pm Post subject: Aileron and rudder trim position indicators |
Jim. Tim got it right. I have enough authority to do what I want, it will
center the ball in climb, decent and cruse, I just meant to say that it did
not exert a lot of force and no matter what position it is in I have no
trouble using the rudder. I can not remember how many inches I used, but I
think it was 11 - 12 inches. Now for the elevator trim that is another
story, take off with it in the wrong position and you will need two hands to
fly the plane....don't ask how I know..........
Rene'
801-721-6080
dmaib@me.com
Posted: Sat Dec 27, 2008 3:43 am Post subject: Aileron and rudder trim position indicators |
I recently finished my phase one flying and I found that I did not
pay much attention to the rudder trim indicator. The aileron trim
indicator was something I would reset after refueling, but did not
really need it.. Pitch trim indicator, I used every takeoff. All
three indicators are shown on the Vertical Power display in my airplane.
David Maib
40559
On Dec 26, 2008, at 11:30 AM, Jim Berry wrote:
Jim Berry
40482
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
