kearney
Posted: Fri Dec 26, 2008 10:33 am Post subject: Cleanup of Proseal |
Merry Christmas To All!
II have been looking through the archives for the best way to remove proseal. I would like to avoid the use of MEK as it seems like particularly nasty stuff. Is there anything else that that is effective and less toxic?
Cheers
Les
#40643 – Some assembly required
Posted: Fri Dec 26, 2008 11:19 am Post subject: Cleanup of Proseal |
Les,MEK is your best bet..not that nasty just use nitrile gloves and avoid the vapors..its biggest hazard is absorption (transdermal) and use in non ventilated confined spaces. It doesn't dissolve the proseal but transfers it to the cloth used to wipe it off...safety glasses are a plus if you're a splasher!!Rick S 40185
Sent via BlackBerry by AT&T
Date: Fri, 26 Dec 2008 11:31:58 -0700
Subject: RV10-List: Cleanup of Proseal
II have been looking through the archives for the = best way to remove proseal. I would like to avoid the use of MEK as it seems like = particularly nasty stuff. Is there anything else that that is effective and less = toxic?
Cheers
Les
#40643 – Some assembly required =
| Quote: | | _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D _-=3D -- Please Support Your Lists This Month -- _-=3D (And Get Some AWESOME FREE Gifts!) _-=3D _-=3D November is the Annual List Fund Raiser. Click on _-=3D the Contribution link below to find out more about _-=3D this year's Terrific Free Incentive Gifts! _-=3D _-=3D List Contribution Web Site: _-=3D _-=3D --> http://www.matronics.com/contribution _-=3D _-=3D Thank you for your generous support! _-=3D _-=3D -Matt Dralle, List Admin. _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - The RV10-List Email Forum - _-=3D Use the Matronics List Features Navigator to browse _-=3D the many List utilities such as List Un/Subscription, _-=3D Archive Search & Download, 7-Day Browse, Chat, FAQ, _-=3D Photoshare, and much much more: _-=3D _-=3D --> http://www.matronics.com/Navigator?RV10-List _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - MATRONICS WEB FORUMS - _-=3D Same great content also available via the Web Forums! _-=3D _-=3D --> http://forums.matronics.com _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D |
Kelly McMullen
Posted: Fri Dec 26, 2008 1:21 pm Post subject: Cleanup of Proseal |
Depends on whether it is cured or not. While it is wet, isopropyl
alcohol works, but not after curing. There is a solvent that is used
for removing it from tanks, but it is very pricey(perhaps $50 a gal).
If you just want it off a tool or part and they won't otherwise be
harmed by a dunk in carburetor cleaner, it will dissolve it.
http://www.berrymanproducts.com/Default.aspx?tabid=146
Probably good for cleaning clecos. MEK is not very effective on cured PRC.
On Fri, Dec 26, 2008 at 11:31 AM, Les Kearney <kearney(at)shaw.ca> wrote:
| Quote: | Merry Christmas To All!
Cheers
Les
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Fri Dec 26, 2008 1:44 pm Post subject: Cleanup of Proseal |
FWIW...there isn't any chemical that can thin or dissolve proseal...MEK allows the sealant to be transferred from the metal to the rag...Denatured alcohol...in the precure stage...or working time frame can clean it but it is not the most practical way to clean up..MEK is still the best and the stuff we used on fighters to wipe excess and clean areas that proseal didn't belong
Rick S
40185
Kelly McMullen
Posted: Fri Dec 26, 2008 1:55 pm Post subject: Cleanup of Proseal |
Yes, there is a variety of chemicals that disolve proseal. I don't
have the brand name handy. See:
http://www.willmarairservice.com/tank.php
On Fri, Dec 26, 2008 at 2:36 PM, <ricksked(at)embarqmail.com> wrote:
Rick S
40185
KCHD |
flysrv10(at)gmail.com Guest
Posted: Sat Dec 27, 2008 4:57 am Post subject: Cleanup of Proseal |
also try removing most of it with a plastic serrated knife and clean up with lacquer thinner.
Cheers
Les
| Quote: | http://www.matronics.com/contribution
style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?RV10-List
blue; text-decoration: underline; ">http://forums.matronics.com
kearney
Posted: Sun Dec 28, 2008 8:32 am Post subject: Cleanup of Proseal |
Hi Rob
Your suggestion worked like a charm. The lacquer thinner did a nice job of softening up the proseal so it could be wiped off (after removing all but the surface layer with a plastic putty knife).
Thanks for the advice
Les
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj
Sent: December-27-08 5:55 AM
Subject: Re: Cleanup of Proseal
Cheers
Les
| Quote: | | http://forums.matronics.com |
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
Posted: Sun Dec 28, 2008 4:03 pm Post subject: Cleanup of Proseal |
You are welcome.
On Dec 28, 2008, at 11:28 AM, Les Kearney wrote:
[quote]Hi Rob
Les
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Rob Kermanj
Cheers
Les
