Posted: Mon Dec 29, 2008 5:17 am Post subject: Can I log PIC time |
Folks,
I'm getting ready for my first flight in my RV6A. The plane's legal, the pilot's legal, now I want to work on the safe part...I'll be going to Georgia in a couple of weeks to get some refresher time with Pierre. Meanwhile, I'm trying to figure out if I can log PIC time in other pilots' 6/7/8/9...I don't have a tailwheel endorsement?!
I know that the most critical times are take-off and landings - I want to practice some stalls, turns, and slowing down for landing etc.
Experience is experience and I already have my type sign-off.
Ralph
N822AR (at) N06 0 hrs and chomping at the bit......
n395v
Posted: Mon Dec 29, 2008 5:35 am Post subject: Re: Can I log PIC time |
I would say you need the tail wheel endorsement to act as and log as PIC.
I know you are anxious to get started but do it right. In the long run there is no significant benefit to packing a few questionable hours in your logbook.
_________________ Milt |
etekberg(at)gmail.com Guest
Posted: Mon Dec 29, 2008 5:59 am Post subject: Can I log PIC time |
Short answer is yes, you can log PIC time w/o an endorsement as long as someone else is "acting" as the PIC.
61.31 prohibits you to "act" as PIC in a tailwheel plane without an endorsement. 61.51 allows you to "log" PIC time for that portion of the flight in which you are the sole manipulator of the controls in a plane in which you are rated (i.e. Airplane SEL in this case). I copied the far sections below for reference.
CFR Title 14, Part 61.31 excerpt
(i) Additional training required for operating tailwheel airplanes. (1) Except as provided in paragraph (i)(2) of this section, no person may act as pilot in command of a tailwheel airplane unless that person has received and logged flight training from an authorized instructor in a tailwheel airplane and received an endorsement in the person's logbook from an authorized instructor who found the person proficient in the operation of a tailwheel airplane. The flight training must include at least the following maneuvers and procedures:
(i) Normal and crosswind takeoffs and landings;
(ii) Wheel landings (unless the manufacturer has recommended against such landings); and
(iii) Go-around procedures. |
CFR Title 14, Part 61.51 excerpt:
(e) Logging pilot-in-command flight time. (1) A sport, recreational, private, or commercial pilot may log pilot-in-command time only for that flight time during which that person—
(i) Is the sole manipulator of the controls of an aircraft for which the pilot is rated or has privileges;
(ii) Is the sole occupant of the aircraft; or
(iii) Except for a recreational pilot, is acting as pilot in command of an aircraft on which more than one pilot is required under the type certification of the aircraft or the regulations under which the flight is conducted. |
On Mon, Dec 29, 2008 at 7:15 AM, Ralph E. Capen <recapen(at)earthlink.net (recapen(at)earthlink.net)> wrote:
[quote]--> RV-List message posted by: "Ralph E. Capen" <recapen(at)earthlink.net (recapen(at)earthlink.net)>
Folks,
Ralph
-Matt Dralle, List Admin.
target="_blank">http://www.matronics.com/Navigator?RV-List
MS -
Posted: Mon Dec 29, 2008 6:05 am Post subject: Can I log PIC time |
Milt said what I was thinking.....I wasn't planning to do this instead....I'm flying with Pierre regardless.
I already have my sign-off for the 6A - just not a tailwheel - which I probably should get regardless/eventually too!
Posted: Mon Dec 29, 2008 6:06 am Post subject: Can I log PIC time |
Not trying to be argumentative, but you are part right and part wrong. There is a difference between "acting" as PIC and "logging" PIC time as specified by the CFRs. You are correct in that you can not act as PIC, but you are wrong in that you can log PIC time as long as someone else is "acting" PIC. See my other post where I quoted the CFRs. Along the same lines, did you know you can log PIC time without a current medical?
Eric
On Mon, Dec 29, 2008 at 7:35 AM, N395V <Bearcat(at)bearcataviation.com (Bearcat(at)bearcataviation.com)> wrote:
[quote] --> RV-List message posted by: "N395V" <Bearcat(at)bearcataviation.com (Bearcat(at)bearcataviation.com)>
I would say you neeed the tailwheel endorsement to act as and log as PIC.
I know you ar anxious to get started but do it right. In the long run there is no significant benefit to packing a few questionable hours in your logbook.
Milt
2003 F1 Rocket
2006 Radial Rocket
[url=http://forums.matronics.com/viewtopic.php?p 21589#221589]http://forums.matronics.com/viewtopic.php?p 21589#221589[/url]
Rick Galati
Joined: 10 Jan 2006 Posts: 91 Location: Lake St. Louis MO.
Posted: Mon Dec 29, 2008 6:27 am Post subject: Re: Can I log PIC time |
I asked several pilots a similar question because I have no tail wheel experience much less an endorsement and my recently completed RV-8 awaits! Recently, an ex-instructor friend of mine has been teaching me to fly his Citabria with him "instructing" from the back seat and I have accumulated several hours to date. As far as he is concerned, I can now fly it solo BUT he cannot provide the endorsement because he let his instructor status lapse.
Surely, I thought I can log the time legally but quickly found out that one pilot said this, another pilot said that. A current and seasoned instructor could not give me a straight answer either. I finally decided to contact the AOPA which is what I should have done in the first place. No opinions, no hearsay, no urban legends, just the facts. The fact is this....YES you can legally log PIC time without a tail wheel endorsement as long as you are properly rated which means category and class. The AOPA has a full explanation detailing this often asked question on their website. Don't take my word for it or anybody else's. Check into it yourself. When you are done doing the research, feel free to log PIC for the amount of time you are the sole manipulator of the controls.
jsflyrv(at)verizon.net Guest
Posted: Mon Dec 29, 2008 9:33 am Post subject: Can I log PIC time |
| Quote: | Along the same lines, did you know you can log PIC time without a
current medical?
That is true, same as I can instruct without a current medical as long
as the pilot is qualified
to act as PIC. There are even some instructors that think you need a 2nd
class medical to
instruct, which you don't. You can instruct without a medical or only a
3rd class depending on the students
qualifications. FAA in their wisdom has determined that we as flight
instructors are not being paid
as pilots but as teachers.
Little OT but interesting.
Kellym
Posted: Tue Dec 30, 2008 5:52 am Post subject: Can I log PIC time |
No, you are misreading the FARs you quoted. No where does it say you
have to have an endorsement to "log" PIC, only to "act as PIC". It
states you can log the time if you are the sole manipulator of the
controls. Quoting the same 61.51 you included:
e) /Logging pilot-in-command flight time. /(1) A sport, recreational,
Being rated is single engine land airplane, not tailwheel endorsed. Some
of us are old enough to not have any of that endorsement junk, being
"grandfathered".
Eric Ekberg wrote:
| Quote: | Not trying to be argumentative, but you are part right and part wrong.
medical?
Eric
<mailto:Bearcat(at)bearcataviation.com>> wrote:
<Bearcat(at)bearcataviation.com <mailto:Bearcat(at)bearcataviation.com>>
as PIC.
Milt
2003 F1 Rocket
2006 Radial Rocket
KCHD |
Posted: Tue Dec 30, 2008 7:37 am Post subject: Can I log PIC time |
Ummm...that's exactly what I said??
On Tue, Dec 30, 2008 at 7:50 AM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
[quote]--> RV-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
No, you are misreading the FARs you quoted. No where does it say you have to have an endorsement to "log" PIC, only to "act as PIC". It states you can log the time if you are the sole manipulator of the controls. Quoting the same 61.51 you included:
e) /Logging pilot-in-command flight time. /(1) A sport, recreational, private, or commercial pilot may log pilot-in-command time only for that flight time during which that person—
Being rated is single engine land airplane, not tailwheel endorsed. Some of us are old enough to not have any of that endorsement junk, being "grandfathered".
Eric Ekberg wrote:
| Quote: | Not trying to be argumentative, but you are part right and part wrong. There is a difference between "acting" as PIC and "logging" PIC time as specified by the CFRs. You are correct in that you can not act as PIC, but you are wrong in that you can log PIC time as long as someone else is "acting" PIC. See my other post where I quoted the CFRs. Along the same lines, did you know you can log PIC time without a current medical?
Eric
On Mon, Dec 29, 2008 at 7:35 AM, N395V <Bearcat(at)bearcataviation.com (Bearcat(at)bearcataviation.com) <mailto:Bearcat(at)bearcataviation.com (Bearcat(at)bearcataviation.com)>> wrote:
as PIC.
Milt
2003 F1 Rocket
2006 Radial Rocket
http://forums.matronics.com/viewtopic.php?p=221589#221589
MS -
jfogarty(at)tds.net Guest
Posted: Tue Dec 30, 2008 8:47 am Post subject: Can I log PIC time |
How about this, "you are rated for a single engine land airplane, however, your endorsement to log time needs to be for a tailwheel on take off and landing." You can log the time in the air as PIC, but not the time for landings and/or takeoffs, because you don't have the endorsement for tailwheel, consequently, you need to have a rated and endorsed pilot with you. Plus, your insurance will not cover you for landings or takeoffs and you need to do that to get up and down with your single engine aircraft! I'm confused, how about you.
In the original post, the instructor wasn't certified, so he couldn't give the pilot an endorsement. I think the pilot knows how to fly a
tailwheel aircraft and he should go put in a few more hours with someone who is certified and can give him the endorsement. Just my two cents.
Jim
Kellym
I read your post to say the exact opposite. So perhaps I misunderstood what you thought you were saying?
Eric Ekberg wrote: [quote]Ummm...that's exactly what I said??
| Quote: | --> RV-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
Eric
as PIC.
Milt
2003 F1 Rocket
2006 Radial Rocket
MS -
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
| [b]
KCHD |
n395v
Posted: Tue Dec 30, 2008 9:27 am Post subject: Re: Can I log PIC time |
I think relative to this issue the best advice so far is Rick's in the form of "check into it yourself" then decide.
After looking over the FARs, definitions and AOPA interpretations I am convinced that the nebulosity of the FARs allow one to distinguish between "acting as PIC" and "logging PIC time" although this is illogical, to me, I am also convinced you cannot be successfully violated by the FAA for logging time as PIC based solely on being the sole manipulator of the controls.
I think, though, one must consider the purposes for which they are logging the flight time and the benefits and risks thereof.
I currently log flight time only for insurance and currency purposes and because I believe it is required. I am not going to obtain any more ratings and am never going to become an airline pilot so total hours are somewhat irrelevant to me.
If you want to become an airline pilot and currently have only a few hundred hours then you may consider every hour possible as precious especially hours of PIC, IMC, ME etc.
I have a friend that wanted to be an airline pilot and needed Multi Time.
I would let him fly with me in my Twin Commander. He flew from the right seat and for all or some of many flights he was the sole manipulator of the controls. He was a Commercial MEL pilot with an instrument rating and therefore qualified to act as pilot in command of the plane except he never had a high altitude endorsement.
From an insurance standpoint I clearly had to be acting PIC as on every flight but as a "sole manipulator of the controls" he elected to "log PIC time" for those hours he flew the plane.
He got an offer to fly a King Air and went through training and received his high altitude endorsement to qualify for insurance.
Eventually the day came and he was invited to an American Eagle interview. The high point of his life. It was a group interview by 3 captains.
The 1st part of the interview went well for him. They took a break and the Captains examined the candidates log books.
After the break they questioned him as to how he could log PIC hours in a pressurised aircraft before he received a high altitude endorsement. They also noted a training certificate for the King Air stapled in his logbook and lack of one for the Twin Commander. One of the capatains suggested he was packing his logbook with "questionable hours". his explanation of the FARs and the various interpretations did not help. His interview ended at that point, he was not invited back. H logged a totlal of 25 hrs in the Commander, and insignificant amount in the overall scheme of things.
bifft(at)xmission.com Guest
Posted: Tue Dec 30, 2008 9:29 am Post subject: Can I log PIC time |
On Tue, 30 Dec 2008, Jim Fogarty at Lakes & Leisure Realty wrote:
| Quote: | In the original post, the instructor wasn't certified, so he couldn't
cents.
This is what I did when learning to fly the Starduster, flew with other
partners in the airplane till I knew what I was doing, then flew with an
instructor to get the endorsement.
Brian Huffaker, DSWL (bifft(at)xmission.com)
RV-8A 80091 Mounting brake resevior
1/4 Starduster II N23UT flying
bjudge(at)gmail.com Guest
Posted: Tue Dec 30, 2008 8:24 pm Post subject: Can I log PIC time |
Ralph:
The question on Logging Time is directed at your insurance company not the Feds Provided the time is not going to count toward "Ratings & Currency"
I know people that were permitted by insurance to call any RV time "time in type"
Bill
N84WJ
RV-8.Blogspot.com
On Tue, Dec 30, 2008 at 2:58 AM, RV-List Digest Server <rv-list(at)matronics.com (rv-list(at)matronics.com)> wrote:
[quote]*
Today's complete RV-List Digest can also be found in either of the
of the RV-List Digest and can be viewed with a generic text editor
HTML Version:
[url=http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-12-29&Archive=RV]http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-12-29&Archive=RV[/url]
Text Version:
[url=http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-12-29&Archive=RV]http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-12-29&Archive=RV[/url]
RV-List Digest Archive
Total Messages Posted Mon 12/29/08: 10
Today's Message Index:
1. 05:17 AM - Can I log PIC time (Ralph E. Capen)
2. 05:37 AM - Re: Can I log PIC time (N395V)
3. 05:59 AM - Re: Can I log PIC time (Eric Ekberg)
4. 06:05 AM - Re: Re: Can I log PIC time (Ralph E. Capen)
5. 06:06 AM - Re: Re: Can I log PIC time (Eric Ekberg)
6. 06:30 AM - Re: Can I log PIC time (Rick Galati)
7. 08:55 AM - Re: RV-6A rudder trim tab (Jim Fogarty at Lakes & Leisure Realty)
8. 09:33 AM - Re: Re: Can I log PIC time (Jerry Springer)
9. 11:03 AM - RV-6 / 6a kits for sale (Scott Kuebler)
10. 02:29 PM - Fast 200HP RV-4 IFR For Sale $43,500 (Paul Besing)
Time: 05:17:25 AM PST US
From: "Ralph E. Capen" <recapen(at)earthlink.net (recapen(at)earthlink.net)>
Subject: Can I log PIC time
Folks,
Ralph
Time: 05:37:11 AM PST US
Subject: Re: Can I log PIC time
From: "N395V" <Bearcat(at)bearcataviation.com (Bearcat(at)bearcataviation.com)>
Milt
2003 F1 Rocket
2006 Radial Rocket
Time: 05:59:38 AM PST US
From: "Eric Ekberg" <etekberg(at)gmail.com (etekberg(at)gmail.com)>
(i) *Additional training required for operating tailwheel airplanes. *(1)
| Quote: | Except as provided in paragraph (i)(2) of this section, no person may act
as
| Quote: | pilot in command of a tailwheel airplane unless that person has received
and
| Quote: | logged flight training from an authorized instructor in a tailwheel airpl
ane
| Quote: | and received an endorsement in the person's logbook from an authorized
l
| Quote: | airplane. The flight training must include at least the following maneuve
rs
| Quote: | and procedures:
| Quote: | (ii) Wheel landings (unless the manufacturer has recommended against such
landings); and
| Quote: | (e) *Logging pilot-in-command flight time. *(1) A sport, recreational,
| Quote: | flight time during which that person=97
| Quote: | (ii) Is the sole occupant of the aircraft; or
n
| Quote: | aircraft on which more than one pilot is required under the type
s
On Mon, Dec 29, 2008 at 7:15 AM, Ralph E. Capen <recapen(at)earthlink.net (recapen(at)earthlink.net)>wrot
e:
Folks,
s'
| Quote: | 6/7/8/9...I don't have a tailwheel endorsement?!
Ralph
________________________________ Message 4 _____________________________________
Time: 06:05:05 AM PST US
Subject: Re: Re: Can I log PIC time
pcowper(at)webtv.net (Pet Guest
Posted: Wed Dec 31, 2008 11:03 am Post subject: Can I log PIC time |
Hmmm . . . I like the interpretation than despite not having a tailwheel
endorsement, signifying in my logbook that I have received sufficient
instruction in tailwheel aircraft operation to handle a tailwheel
airplane on my own as Pilot-In-Command, that I can fly a tailwheel
aircraft and log the time as long as I don't try to take off or land it.
So following this wishful interpretation of the FARs, as a single engine
pilot I could log time in a Boeing 747 as PIlot-In-Command as long as I
fly on only one engine and leave the other three shut down. I could get
in over an hour's flight time logged at a 500 foot per minute
underpowered loss of altitude descent from 35,000 feet before we hit the
ground.
Pete Cowper
RV8 #81139
Lawyer-Pilots Bar Association member
Posted: Wed Dec 31, 2008 12:17 pm Post subject: Can I log PIC time |
You are a lawyer and write that? A 747 Is not a single engine aircraft
even though you shut the other engines down, You are not rated to fly
it.
On Dec 31, 2008, at 11:02 AM, pcowper(at)webtv.net (Pete Cowper) wrote:
tailwheel
it.
engine
as I
get
the
ground.
Pete Cowper
RV8 #81139
AV8ORJWC
Posted: Wed Dec 31, 2008 12:56 pm Post subject: Can I log PIC time |
Jerry, great catch. A SEL is certainly different that an MEL and one
that requires a most specific type rating adds to the humor of Pete's
legalize. Busted Pete!
Happy New Year
John Cox
