Roland Smith
Posted: Tue Dec 30, 2008 6:39 am Post subject: Dzus Grommets |
I'm using Dzus fasteners for my cowl. They came with the Skyshop firewall forward package for the 701. Do I need grommets to protect the fiberglass where the studs go through or can the studs be attached without grommets ? Grommets were not included in the FWF kit.
Roland Smith N701AA
_________________ 701 kit, Rotax 912 ULS, SensorNetics EFIS, Flying. |
klondike(at)megalink.net Guest
Posted: Tue Dec 30, 2008 8:47 am Post subject: Dzus Grommets |
I recommend grommets and also to make sure you have the correct length, so you have a nice tight fit. Many years ago on my 701, the Dzus fasteners didn't fit tight (I thought they did). The chaffing and vibration caused the holes to enlarge. On one flight, the left side of my top cowling came "undone" and popped up at about a 45 degree angle. I made an uneventful landing, actually looking "under the top left side of the cowling" it was so high up.
I was lucky it stayed with the airplane and that it didn't come off and hit something or someone on the ground.------ Looking back on the situation----- I should have used an aluminum backing "plate" where the grommet went through the fiberglass.
Hope this helps.
Fritz
lgold(at)quantum-associat Guest
Posted: Tue Dec 30, 2008 10:37 am Post subject: Dzus Grommets |
Roland,
I think that the grommets look really nice and probably protect the fiberglass. However, I didn’t know how to install them properly and so I left them out.
My 701 plane has been flying for over a year. I have not noticed any damage to the un-grommeted fiberglass even though I take the cowl off about once a week. If I start to see wear, I will try to install grommets but it does not look like I will need them.
Les
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of docponds
Sent: Tuesday, December 30, 2008 6:38 AM
Subject: Dzus Grommets
Roland Smith N701AA
| Quote: | | http://www.matronics.com/contribution | 01234567890123
Posted: Tue Dec 30, 2008 12:26 pm Post subject: Dzus Grommets |
Roland,
Also consider using thermoplastic grommets type GP rather than the
aluminum kind as they will secure the Dzus fasteners and you don't need
any special tools to
put them on or replace them. Important is the gap that accrues for grip
when turning the Dzus to secure the lid. The grommets can be helpful in
this as well.
Aircraft Spruce part number GP5B is likely but size your grommets to fit
the Dzus diameter. About .06 each.
Larry McFarland
fritz wrote:
[quote] I recommend grommets and also to make sure you have the correct
Hope this helps.
Fritz
Posted: Tue Dec 30, 2008 12:34 pm Post subject: Dzus Grommets |
Les and Roland,
I should mention that you can make Dzus grommets from milk jug material
if you're careful to punch out the correct inside diameter
and trim the outside diameter to less than the Dzus head. These work
well too so long as the inside diameter is snug to the Dzus stem.
The object is, of course to keep the Dzus from becoming loose parts and
being floppy in the hole. Insert Dzus thru the fiberglass and add
the plastic washer, that's it.
Les Goldner wrote:
Roland,
I left them out.
Les
*From:* owner-zenith701801-list-server(at)matronics.com
[mailto:owner-zenith701801-list-server(at)matronics.com] *On Behalf Of
*docponds
*Sent:* Tuesday, December 30, 2008 6:38 AM
*To:* zenith701801-list(at)matronics.com
*Subject:* Dzus Grommets
Roland Smith N701AA
NYTerminat(at)aol.com Guest
Posted: Tue Dec 30, 2008 5:11 pm Post subject: Dzus Grommets |
Roland,
Grommets would help protect the fiberglass. I did not use them and I am starting to see some wear after 160 hrs.on my SkyShop cowl.
Bob Spudis
N701ZX
In a message dated 12/30/2008 9:39:38 A.M. Eastern Standard Time, docponds(at)sover.net writes:
| Quote: | I'm using Dzus fasteners for my cowl. They came with the Skyshop firewall forward package for the 701. Do I need grommets to protect the fiberglass where the studs go through or can the studs be attached without grommets ? Grommets were not included in the FWF kit.
Roland Smith N701AA
One site keeps you connected to all your email: AOL Mail, Gmail, and Yahoo Mail. Try it now.
