				 Posted: Fri Jan 02, 2009 6:49 pm    Post subject: Wire cover needed |
				Happy New Year
 I need to somehow cover wires running along the fuse seam from baggage bulkhead forward.
 What solution have those flying come up with?
 What's thoughts on having a removable cover to allow extra wires added easier than trying to snake through a one piece raceway?
 How did you handle interior up to this raceway? Is raceway cover on top of interior or interior up to edge of raceway?
 Is raceway what is used to support wiring, or did you support wiring in another fashion and just install a cover? How then did you support wiring?
 Pics would be heplful.
 Thx.
 Ron Parigoris
 Visit -  www.EuropaOwners.org
		DuaneFamly(at)aol.com Guest
				 Posted: Fri Jan 02, 2009 8:08 pm    Post subject: Wire cover needed |
				Hi Ron,
  I installed a raceway made of three layers of BID permanently attached to  the each side wall of the fuselage. I keep a #18 wire inside the raceway in  order to pull, as well as push, any additional sets of wires that I need to run  through it. Just remember to add another #18 along side the new wires that you  leave inside the raceway for the next time. I upholstered over the top and it  looks fine.
  Mike Duane  A207A
 Redding, California
 XS Conventional Gear
 Jabiru  3300A
 Sensenich R64Z N
 Ground Adjustable  Prop
 Stay up-to-date on - from fashion trends to celebrity break-ups and everything in between.
		hagargs(at)earthlink.net Guest
				 Posted: Fri Jan 02, 2009 8:18 pm    Post subject: Wire cover needed |
				You can kill 2 birds with one stone here.  The bottom door sill is not very
 stiff.  Going in and out you tend to bend and stress it with your butt.  If
 you make up a flat layup of about 4 layers and make a triangular gusset
 tunnel under the door sill moulding you get a good raceway to run the
 wires and  stiffen up the  door sill immensly.  Run power on passenger side
 and  Rf on pilot side or visa  versa.
 Steve Hagar
 A143
 Mesa AZ
  	  | Quote: | 	 		   [Original Message]
  Date: 1/2/2009 7:52:20 PM
  Subject: Wire cover needed
 <rparigor(at)suffolk.lib.ny.us>
  Happy New Year
 bulkhead forward.
		budyerly(at)msn.com Guest
				 Posted: Sat Jan 03, 2009 9:20 am    Post subject: Wire cover needed |
				<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->  Make a hat section out of two layers of glass.  Tack on with super  glue and lay two layers over the seam.  You can use a 1x2 covered with  plastic for a form, or make a nice foam form like I did.
  Bud
  [quote]   ---
